Have someone installed a OEM power step on a 3rd Gen Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by Libagui, May 23, 2024.
  1. May 23, 2024 at 11:33 AM
    Libagui
    Libagui [OP] New Member
    Librado
    2024 midnight black Toyota Tundra Limited, TRD offroad
    Inspecting the wiring diagram, it shou20240523_142852~2.jpg ldn't be difficult to wire a a OEM controler to the main body ecu and build any additional harnesses needed for the steps and OEM switch.
  2. May 23, 2024 at 11:39 AM
    Libagui
    Librado
    Well, I've gather some parts for the cheap. I can easily do it per wiring diagrams, but if there's any successfull history to follow it'll be much better. Maybe I'll be the first.
  3. May 23, 2024 at 12:47 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    thats funny right there. Well let er rip tater chip, make sure to take lots of good pictures and document the part numbers.....
  4. May 23, 2024 at 1:04 PM
    Libagui
    Librado
    Parts needed to build the harness, plus some pins That I have to include. The last doubt I have is if the Main body ECU is programmed to send and receive packages from and to the step controller.
  5. May 23, 2024 at 2:19 PM
    Libagui
    Librado
  6. Apr 11, 2025 at 9:40 AM
    PDXrefurb
    PDXrefurb New Member
    25 Blueprint Platinum Hybrid TRD OR
    3" TRD lift kit
    I am trying to figure out if the platinum trim comes pre-wired from factory with the harness that would connect to the Power Step ECM
  7. Apr 11, 2025 at 12:01 PM
    teab
    Ty
    Denver
    It does not.
    sudobash likes this.
