2011 toyota tundra 5.7 4x4
Discussion in 'General Tundra Discussion' started by Hardin43087, May 22, 2024.
  1. May 22, 2024 at 11:40 AM
    Hardin43087
    Hardin43087 [OP] New Member
    Joseph
    2011 toyota tundra 5.7 4x4 remote start bypass after removing aftermarket alarm won't start dose a single click that's all it will do
  2. May 22, 2024 at 11:46 AM
    2mchfun
    Welcome from OKC! Problem started after removal? Sounds like an open circuit somewhere. Click on forums, scroll to garage and then to electrical to find wire diagrams for all models.
  3. May 22, 2024 at 11:57 AM
    Hardin43087
    Joseph
    I checked for open wires every thing looks good now the battery died from the key being left on and I jump started it just fine but after I shut off the truck I could not get it to do any thing but a single click even with a new battery or trying to jump It I get nothing but that click
  4. May 22, 2024 at 12:02 PM
    2mchfun
    Maybe you blew a fuse when messing around with jumper cables. Turn on ignition and lets see if lights and more importantly do turn signals work? There is an ignition fuse that also operates turn signals. Are you aware of fuse box way up under dash above parking brake?
  5. May 22, 2024 at 12:06 PM
    2mchfun
    When you try to jump it, put a meter on the battery posts and check voltage, make sure the clamps are making good contact.
  6. May 22, 2024 at 12:17 PM
    Hardin43087
    Joseph
    Turn signals are working I checked the fuse panel every thing is good I'll double check them again to make sure there all good I see the relay under the hood making a spark when trying to turn over the engine what would cause that I have never had a issue with starting the truck before and this issue didn't occur until the battery died and I had to jump start it so makes me wonder if the alarm has engaged some how and the only wire I see that has Ben cut was a green one on the ignition switch they had the aftermarket alarm hooked up to it but I put a connector to the wire and it's making good connection
  7. May 22, 2024 at 12:18 PM
    Hardin43087
    Joseph
    Checked the battery with meetand it's making good connection
    2mchfun likes this.
  8. May 22, 2024 at 12:29 PM
    2mchfun
    Relay sparking?? Not good, nothing should be sparking. Check that relay and see if it is cracked or damaged. Is there a like relay right there to swap it with temporarily? Sort of as a troubleshooting substitute.
  9. May 22, 2024 at 12:33 PM
    2mchfun
    It started once already after you connected the green wire, right? Does it have telescoping column(high end models)?
  10. May 22, 2024 at 12:34 PM
    2mchfun
    Do you have a second factory key? Try it?
  11. May 22, 2024 at 12:52 PM
    Hardin43087
    Joseph
    I swapped the relay out with another one same issue no spark so maybe its a relay going bad I'll get a new one now after disconnecting there aftermarket wire that was tied to the green and reconnecting the green wire it has nit started but the wire that I took off was not going to anything it was going to the remote start but I disconnected that a few months ago I just decided to eliminate all the excess wiring they did since I wasn't using the remote start could there have Ben a bypass done that I wasn't seeing when I took out the aftermarket remote start
  12. May 22, 2024 at 12:53 PM
    Hardin43087
    Joseph
    I do not have a secondary factory key
  13. May 22, 2024 at 12:55 PM
    Hardin43087
    Joseph
    I'm not sure what telescoping model means I can snap a pic
  14. May 22, 2024 at 12:57 PM
    Hardin43087
    Joseph
    I hear a click on the passenger side any clue what that is
  15. May 22, 2024 at 1:00 PM
    2mchfun
  16. May 22, 2024 at 1:01 PM
    2mchfun
    Starter solenoid maybe. Maybe just not enough juice. Can you swap in batt from different vehicle temporarily?
  17. May 22, 2024 at 1:08 PM
    Hardin43087
    Joseph
    I swapped the battery out but I will get a new one right now and see what happens I'm going to go pick one up right now
    2mchfun likes this.
  18. May 22, 2024 at 1:11 PM
    2mchfun
    If you already tried with a known good battery, getting a new one will not get it started.
  19. May 22, 2024 at 1:14 PM
    2mchfun
    Studying the wire diagrams and verifying all is correct, having good fuses, relays, grounds, battery cables, etc. is all key.
