Seat Belt Issue (one plate faces in opposite direction)
Discussion in '3rd Gen Tundras (2022+)' started by Harris5270, May 22, 2024.
  1. May 22, 2024 at 9:48 AM
    Harris5270
    Harris5270 [OP] New Member
    3 of my seat belt plates face inside (so they go and clamp in straight up) but the right back side faces towards the door (so I have to turn it around to clamp). Anyone else has this issue? Any idea how I can switch the plate to face towards inside?
  2. May 22, 2024 at 11:11 AM
    Hella Krusty
    Hella Krusty New Member
    Have you tried yanking it all the way out to see if the belt is twisted on the roller ?
    j-utah, 2mchfun and Colotundie like this.
  3. May 22, 2024 at 1:06 PM
    Harris5270
    Yes I did. Thanks for the idea though. Just wondering if it’s a one off issue or others had this issue too. Don’t know how I can switch it around unless it’s dismantled from the top roller.
  4. May 22, 2024 at 1:12 PM
    tundramh
    tundramh New Member
    OHIO
    Just fold a small part of the belt over and slide the plate slot up over it and start working it around.
  5. May 22, 2024 at 1:29 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have to do this often in my work tractors..
    Being folded over drives me up the wall..:eek::cool:
    Wynnded likes this.
  6. May 22, 2024 at 2:42 PM
    Harris5270
    The slot if too skinny for the folded part to pass
    1lowlife likes this.
  7. May 22, 2024 at 3:24 PM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    So you’re saying yours is too big? :)
    Hella Krusty likes this.
  8. May 22, 2024 at 4:59 PM
    303Gen3
    303Gen3 Old enough to know better. Young enough to try
    Golden Colorado
    '23 MGM SR5 CrewMax 4x4
    Nitrogen filled tires!
    Sounds like they used a left
    handed screw driver to install it.
  9. May 22, 2024 at 5:07 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    Aren’t the ends of the slots rounded to allow the belt to be pass over itself back into the correct position?
  10. May 22, 2024 at 5:14 PM
    Hella Krusty
    Fold it over and get it started, then get it wet , then yank on that bitch like it's your kid in quick sand.........it will come
    j-utah likes this.
  11. May 22, 2024 at 6:14 PM
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    The jokes are getting easier… :)
  12. May 22, 2024 at 6:44 PM
    Hella Krusty
    I never read it that way LOL
  13. May 23, 2024 at 5:56 AM
    tundramh
    tundramh New Member
    OHIO
    Fold about a third of it over above the plate and pull the plate up so you have the full tension of the fixed belt at the bottom. Pull the plate over the fold; don't try to fold it in the slot. Keep the belt squeezed between your fingers while pulling the plate up. It will pass over it and then just keep sliding the belt over to flip it. Oh, getting it wet is optional but only if you want to talk dirty to it.
  14. May 23, 2024 at 9:50 AM
    Harris5270
    Thanks!! It worked :)
