Bed lights out
Discussion in '2.5 Gen Tundras (2014-2021)' started by DaveInTexas, May 22, 2024.
  1. May 22, 2024 at 1:02 PM
    DaveInTexas
    DaveInTexas [OP] New Member
    Dave
    West Texas
    2020 Tundra SR5 + 2003 Tundra SR5
    The 2020 has a Ranch Hand front brushguard/bumper
    A year ago the right one was flickering, then went out.
    Recently, the left went out.
    Was at auto supply store, thought I’d pull one out to test the power supply or the lamp.
    Not so easy.
    The lamp is hardwired, can’t access the wire terminus.
  2. May 22, 2024 at 1:14 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I just threw 2 of those in the trash, I didn't think anyone would want them.
    The first thing I'd do is make sure the circuit has power.
    Test the wires with a DDM.
    Although if the cargo light has power it should have power unless there is an inline fuse for the bed lights.
    They should be tapped into the cargo light circuit.
    Pretty sure you'd have to buy an entire OEM kit to replace them and it isn't worth it
    You're best bet would replace them with LED strips.
    Do you have the bed rail system?
    I just swapped my OEM bedlights with a $17 set of lights from Amazon.
    Post 90582 in this thread.
    What have you done to your 2.5 gen Tundra today? | Page 3020 | Toyota Tundra Forum (tundras.com)
    Although it took a little work and soldering of the wires.
    Amazon.com: Ampper White LED Rock Light for Bed Track, 60 LEDs Cargo Pickup Truck Bed Lighting Kit W/Switch Fuse for Truck Bed, Foot Wells, Under Car, Rail Light and More (20 Pcs) : Automotive
    @mattgecko makes some nice ones.
    You could try contacting him and see if he would just sell you the lights without the relay and stuff since you already have a power source.
    Although you will need some extra wire..
    Motorcycle LED Headlights - MATT GECKO LEDS
    If you like the OEM, you could try something like this.
    They say they are brighter than OEM.
    You'd just have to splice them to your existing wiring..
    Direct Fit LED Truck Bed Lighting Kit w/ Wiring Harness For Toyota Tundra Tacoma | eBay
    Mater, bulldog93, 2mchfun and 2 others like this.
  3. May 22, 2024 at 2:18 PM
    2mchfun
    Might be able to find some flush mount 12v clear led about 2.5" long and just mount them over the existing lenses. Maybe drill the wiring hole straight through the existing light and then paint it black with plastic trim paint prior to mounting the new light housing with screws at both ends which will secure it to the current black plastic surround. Then just wire and screw em in. All for like $20 and a few hrs.
    DaveInTexas[OP] likes this.
  4. May 22, 2024 at 2:20 PM
    2mchfun
  5. May 22, 2024 at 2:59 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Before I did the strips I thought about replacing those with these..
    Wow, they are 20% off for Memorial Day.
    UNIVERSAL LED PUDDLE LIGHT (vleds.com)
    Just drill the hole bigger and put plugs where the screws are.
    I plugged my holes when I removed mine.
    I'm using these for mirror puddle lights.
    The only reason it didn't do it was I had one in the front and one in the back.
    With my swing case I couldn't put both in the rear corners.
    I figured the front one would be too blinding.
    8012F3BF-4D59-4E09-A8B0-216A00B629E6_zps_dd9e48b652b3d8010a0d599e2ce4fb3caccc423b.jpg
    Pretty happy with the LED strips I did instead.
    bulldog93 and DaveInTexas[OP] like this.
  6. May 22, 2024 at 3:40 PM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
  7. May 22, 2024 at 3:57 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    I think it’s a southeast Toyota accessory, try a southern online dealer.
  8. May 22, 2024 at 3:58 PM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    Tundra/Tacoma LED OEM Set Cargo Bed Lighting P/N 00016-34089
    Totmacher and DaveInTexas[OP] like this.
  9. May 22, 2024 at 4:01 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  10. May 22, 2024 at 4:04 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  11. May 22, 2024 at 4:37 PM
    DaveInTexas
    Dave
    West Texas
    Where is the fuse for the bed lights?
    2mchfun likes this.
  12. May 22, 2024 at 5:37 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    My bed lights were an OEM kit, I added them years after I bought the truck..
    I would guess it would be the same install as what you have.
    There doesn't seem to be a separate fuse for them, they are just tapped into the cargo light circuit.
    Pretty sure these are dealer or port installed and not done at the factory.
    Here are the instructions so you can see if this is what you have in your truck.
    00016-34089_2018_tundra.pdf (sparkstoyota.com)
    Ironically it seems @Oolypoolay did have a correct part number, they are on the instructions, but the part number I posted seems to be them as well..:confused:
    Maybe they are different parts numbers for Tundra and Tacoma, but they are the same kit for both trucks.
    00016-34187 - LED Cargo Bed Lighting - | Sparks Parts
    That's why I was saying if the cargo lights work, then the bed lights should be getting power.
    Good luck..
    Totmacher, bulldog93 and 2mchfun like this.
  13. May 22, 2024 at 5:42 PM
    2mchfun
    In fuse box under dash above parking brake, cargo light fuse
  14. May 24, 2024 at 12:25 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    Yeah, those are a southeast toyota thing. I remember seeing them for Tacoma years ago in GA. Back then on tacoma kit they got power from tapping a line behind kick panel under fuse panel at driver side. Dont know if that is still how dealer does them.
    bulldog93, 2mchfun and 1lowlife like this.
  15. May 24, 2024 at 12:49 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Also it could be something as simple as a bad connection.
    I've had a couple of issues with my Amp steps not working over the years.
    The OEM wiring is so small, you really have to make sure your taps are making a good connection, and I was using Posi-taps.
    Over the year the Posi-taps lost the connection, I just took them apart and reseated the wiring.
    But the first thing you need to do is to see if there is power at the lights, perhaps the LEDs just petered out.
    Especially if you don't have a cover and they have been exposed to the weather all this time.
    I can't remember if there is an inline fuse on the bed light wiring harness.
    When I can I'll look at my truck and see if it has one..
  16. May 24, 2024 at 12:52 PM
    2mchfun
    100% this, check for power before spending $$$
    DaveInTexas[OP] and bulldog93 like this.
  17. May 26, 2024 at 3:20 PM
    DaveInTexas
    Dave
    West Texas
    The fuse is in the engine compartment; tests and looks fine.
    The cargo lamp above the rear window works fine.
    I unwound the extra 8' of cable under the right rear bumper, followed the rear cargo lamps to the connectors.
    There is power there and they look like good connections.
    I checked the ohms across each lamp's terminal-pair and - infinite. These are LEDs which I have never tried that so not sure how to interpret. Likely they are both bad. They did fail separately, months apart.
    Thanks for ideas on how to resolve. Will report back if anything unusual happens.
    Other bulb problems in separate threads.
  18. May 26, 2024 at 4:48 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Thanks for the update.
    Just replace with the option of your choice, there are many.
    You have to do some splicing, but that's pretty easy.
    Posi-taps with tape or heat shrink, or soldering with heat shrink.
    Tons of youtubes on soldering.
    Either find an OEM equivalent (posted a couple), ort go crazy with after-market strips.
    The OEM equivalent would be easier, you certainly should have some slack in the wiring if you pulled the OEM light out to splice.
    The extra cable is because those OEM bed light kits allow for 8' beds.
    On my first OEM install I bundled them up and did the same thing..:eek2::thumbsup:
    bulldog93 likes this.
  19. May 26, 2024 at 5:05 PM
    2mchfun
    Prior to replacing, I would try to determine what caused the failure to begin with and try to eliminate that this time around.
  20. May 26, 2024 at 5:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I think his OEM bed lights just petered out.
    He stated one was flickering and it went out.
    His bed looks like it's not covered and 4 years in the weather might do it..:eek2:
  21. May 26, 2024 at 5:23 PM
    2mchfun
    He's apparently now asking about problems with front turns/markers or parking (ambers), so I'm starting to think maybe he bought a flood damaged truck for a bargain or maybe even was lied to. His truck just isn't all that old yet.
    1lowlife[QUOTED] likes this.
  22. May 26, 2024 at 5:39 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    You have a good point.
    It's odd the rears work (turn signals), if they do, and the fronts don't.
    I'd think if it was a flooding issue nothing in the headlights would work.
    As well it may also be a rodent wire chewing issue..:(
    2mchfun[QUOTED] likes this.
  23. May 27, 2024 at 4:47 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I put led bulbs in the cargo lamp. No need for anything else. I can skin and quarter a deer with them on. Also good for getting the message across to tailgaters at night. I had regular bed lights in my Tacoma. I used 8" LED weatherproof marine lights. My problem with lights in the bed is cargo blocks them.
  24. Jun 2, 2024 at 10:56 PM
    DaveInTexas
    Dave
    West Texas
    Sj,
    The failed bulbs were factory LEDs (so, ostensibly, I did need something else!)
    Tonight I soldered in new cheapo LEDs much like the one posted by 2mchfun.
    (If they don’t last, well they were $1.50 each.
    After drilling through the old ones for the wires, I used WeldBond 2part epoxy with a 550° temp rating to affix them.
    2mchfun likes this.
  25. Jun 3, 2024 at 6:24 AM
    2mchfun
    Just so you know, the ones I posted are not only in my bed under the rails, they are also under my cab behind the rocker panels as puddle lights. They get exposed to rain splash, mud, gravel, salt, etc. Which means they get hit with frequent really hot water undercarriage rinses too. They have been there for a couple of years and still work like new. That is why I suggested them. Just my .02, good luck!
    Edit: If you zoom in this pic, you can see clear lense amber versions used as side markers just under the doors too. There are 5 on steel tube bolted to the pinch weld. Again, no problem with element exposure, tucked in away from physical damage.
  26. Jun 3, 2024 at 6:27 AM
    RCwyoming
    RCwyoming New Member
    RC
    2019 Tundra 4X4 CM MGM
    Flashlight
  27. Jun 3, 2024 at 6:48 AM
    2mchfun
    When you want to go to the next level, add a door switch to the tailgate. Include a bypass manual switch for when hauling with gate open.
