3rd Gen Accessory Thread
Discussion in '3rd Gen Tundras (2022+)' started by jimfish98, Dec 17, 2021.
  1. May 11, 2024 at 12:31 PM
    #2521
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    Does your phone block the vent? It's so hard to tell...
  2. May 11, 2024 at 1:47 PM
    #2522
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Might. Depends on phone. With my ICS and the claw style holder, if I set the phone low on it, it blocks the vent. I have an S22 ultra though...bigger phone
  3. May 11, 2024 at 3:00 PM
    #2523
    Taikowaza
    Taikowaza New Member
    Installed my passenger side Tundra branded Swingcase this morning. Took my time measuring and drilling, everthing went on smoothly. Very nice unit and makes good use of the space between wheel well and tailgate. I like it, have the driver’s side on back order. 6.5’ bed, works great. Thx to all who helped me during my research
  4. May 11, 2024 at 4:46 PM
    #2524
    Jalzate44
    Jalzate44 New Member
    San Antonio TX
    2024 Tundra SR5 Crewmax 4x4
    Not really, here’s a picture
    BDATundra likes this.
  5. May 12, 2024 at 10:04 AM
    #2525
    McCoy1794TT
    McCoy1794TT New Member
    2023 Tundra 1794
    Where did you get that dash cover?
    It’s a great idea.
  6. May 12, 2024 at 10:18 AM
    #2526
    Torque3725
    Torque3725 New Member
    Thorin
    2024 Tundra TRD Pro
    Decked drawers Oct '23 redesign ARE Cap
    Added ARE cap and new Decked system
    CappyKD, SnowToy, vichmr and 7 others like this.
  7. May 12, 2024 at 12:39 PM
    #2527
    NOEVSh*t
    NOEVSh*t 53 Toyota Buys - 2016 382,000 M - 2011 528,000 M
    The Great State of Texas
    2024 Platinum 4X4 Non-Hybrid Night Shade Crew Max
    Start/Stop Disabled, Ceramic Tint, 305/55/20 BFG KO2's on No Lift or Level, EFF Replace OEM Charger, Wireless Charge Iphone Mount, Exceed Bed Cover, etc.
  8. May 16, 2024 at 5:00 PM
    #2528
    John K.
    John K. New Member
    2024 Tundra 4x4 Limited
    What's the best way to convert the dash cigarette lighter (behind the display) into a USB port? I'd prefer a hard wired fix vs. a plug-in adapter. Any thoughts? Thanks again!
  9. May 16, 2024 at 5:03 PM
    #2529
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  10. May 16, 2024 at 5:06 PM
    #2530
    John K.
    John K. New Member
  11. May 16, 2024 at 10:34 PM
    #2531
    Keeptipsup52
    Keeptipsup52 New Member
    22 SR5 TRD OR
    I found a flush mount 2 usb adaptor that looks like a hard wired usb plug.
    far easier solution than doing a full replacement
    DogRunner2 and John K. like this.
  12. May 17, 2024 at 4:59 AM
    #2532
    John K.
    John K. New Member
    What brand was it? Thx
  13. May 17, 2024 at 2:21 PM
    #2533
    TN Tundra2
    TN Tundra2 New Member
    Keegan
    ‘24 Platinum TRD Off Road
  14. May 17, 2024 at 7:40 PM
    #2534
    Keeptipsup52
    22 SR5 TRD OR
    Scosche
  15. May 18, 2024 at 9:18 AM
    #2535
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
  16. May 18, 2024 at 3:26 PM
    #2536
    pyoung62
    pyoung62 Retired
    Paul
    Raleigh, NC
    2023 Tundra 1794 Edition
    I believe the part you want is PT948-34240-02. It’s for the Limited and includes the “Limited” emblems for the C pillars, but I don’t think you can get the matte finish “sombrero” emblem any other way.
    CappyKD likes this.
  17. May 19, 2024 at 12:46 PM
    #2537
    NOEVSh*t
    I use the lighter plug for power to Dell Laptop, that's why I chose to go all the way to the dash USB Type A socket.
  18. May 21, 2024 at 5:36 AM
    #2538
    Justinfro
    Justinfro New Member
    Justin
  19. May 21, 2024 at 12:36 PM
    #2539
    BigTexasTundra
    BigTexasTundra New Member
    Russell
    San Antonio, TX
    2024 Toyota Tundra Platinum Hybrid Max 4x4 | 2000 Toyota Camry LE, 236k "Mutt"
  20. May 24, 2024 at 3:01 PM
    #2540
    John K.
    John K. New Member
    I went with ICS, a little pricey but seems pretty solid.
    eddiefromcali likes this.
  21. Jun 1, 2024 at 6:07 AM
    #2541
    Taikowaza
    Finished the matching driver’s side Toyota branded Swingcase install. They make quite a nice pair. Recently had to remove the cases to fit an irregular item and that process was easy. Glad to have these, have loaded them with tools and other smaller gear, leaving more space under the seats for other equipment.
  22. Jun 8, 2024 at 3:22 AM
    #2542
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I hadn't seen these and they would work for me instead of a bedcover. I watched the video of the F150 install. How was the Gen3 install? Could you use existing bolt holes or did you have to drill the bed? Thanks
    Taikowaza[QUOTED] likes this.
  23. Jun 8, 2024 at 4:45 AM
    #2543
    Taikowaza
    @BoulderGT3 re your questions, the gen3 Tundra swingcase install is very similar to the F150 install. Here is a link to the install in a Tundra TRD Pro. Watch this video as well as the other ones online and you’ll have a good idea of how to do it. Drilling is required.
    Be sure to print out the template and get the hole locations just right, very impt. I did not remove all the taillight cabling, just placed each light on stands while I worked and then replaced the lights.
    I have the OEM bedliner which is tricky to drill through with pinpoint accuracy, watch your pilot holes (which are hard to see in the bedliner). If you get your holes drilled properly you are good to go.
    I took my time and probably spent about 2 to 2.5 hrs per case just to get everything perfect. I have found these to be excellent cases that are easily holding 30+ lbs of tools each and swinging/locking very well. Do use paint to coat the inside of every hole to avoid rust.
    print this PDF, the last 2 pages are the template
    http://toyotaparts.sparkstoyota.com/install/PT973-34220-RH-LHinst.pdf
  24. Jun 8, 2024 at 5:25 AM
    #2544
    Rockpig
    Rockpig You did what?
    08 Limited
    No need to go through all the trouble to do that, get a flush mount plug like this, I use it and it only protrudes barely a quarter inch.
    Amazon.com: Anker 320 Car Charger (24W II), Mini Aluminum Alloy Dual USB with Blue LED for iPhone15 14 13 12 Series, iPad Pro/Air 2/Mini, Galaxy and More - Not Compatible with Quick Charge : Everything Else
    John K.[QUOTED] likes this.
  25. Jun 8, 2024 at 8:46 AM
    #2545
    ArmygreenTRD
    ArmygreenTRD New Member
    2022 Army Green TRD, SR5 DC
    @NOEVSh*t What type of backplate do you have connected to the ESR Charger? Thnx
  26. Jun 14, 2024 at 10:12 AM
    #2546
    BigTexasTundra
    Russell
    San Antonio, TX
    You have the spray on bedliner like I do. Do you really need the rubber mat too? I see one used one forsale locally for $80 oem too.
  27. Jun 14, 2024 at 10:26 AM
    #2547
    Taikowaza
    @BigTexasTundra thanks for your post! At first I felt the same way, didn’t think a mat was needed as I have the OEM spray on bedliner. I read some posts about how the bedliner, through tough is certainly not immortal (impervious!) and some tasks like using a shovel, or dragging heavy cargo can actually scrape off sections of it. The mat is, for me fantastic as I can beat up on it with all sorts of gear knowing that the bedliner is there to provide additional protection below. Already the mat has taken punctures that while they didn’t hurt the mat, may have damaged the bed liner. All in all if you can pick one up used or new I would go for it. Looks great too.
  28. Jun 14, 2024 at 10:53 AM
    #2548
    BigTexasTundra
    Russell
    San Antonio, TX
    Thanks for letting me know. I'll see if I can get the one from that guy locally then. Not sure if $80 is a good price, I'll look up to see what it is new.
  29. Jun 15, 2024 at 5:53 AM
    #2549
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    Added some hook points to the back.
  30. Jun 16, 2024 at 9:42 AM
    #2550
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Nice! Ordered the same a couple weeks ago.
    Mrconnsmythe[QUOTED] likes this.
