Sway Bar Rub (35x12.50s on +35 offset)
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra18overland, Mar 14, 2022.
  1. Mar 14, 2022 at 6:20 PM
    Tundra18overland
    Tundra18overland [OP] Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Noticing a rub on on my front sway bat after installing 35x12.50x17s on a +35 wheel. It’s primarily only rubs when driving/turning on un-even surfaces at full lock only. Don’t really want to remove the sway bar bc I don’t want the increased body roll and I’m not installing spacers. My concern is the rub being severe enough to wear the tire’s edge down to the point it has un-even edges.
    anyone else dealt with this issue?
    thanks!
  2. Mar 14, 2022 at 6:32 PM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    I'm dealing with the same (little worse) on the passenger side. Tire place isn't worried about it. I'm not worried about it. Only happens on full lock.
  3. Mar 14, 2022 at 6:40 PM
    Tundra18overland
    Jesse
    GA
    What’s your offset? 35x12.50 tire?
  4. Mar 14, 2022 at 6:44 PM
    Blang805
    Blang805 New Member
    Central Coast California
    2010 CrewMax Platinum 4x4
    Build in Signature
    That is very minimal rub. I would not worry about it. Maybe just refrain from going full lock. Mine rubs the passenger side sway bar at full lock so i stop right before.
    Tundra18overland[OP] likes this.
  5. Mar 14, 2022 at 6:49 PM
    Occidentalis
    North Florida
    305 70 on oem 18" 2015 pro rims (just offroad standard rims with different paint)
  6. May 20, 2024 at 12:26 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Would a sway bar drop bracket help this or make it worse ?
  7. May 20, 2024 at 10:59 PM
    Tundra18overland
    Jesse
    GA
    not sure, seems like it would still rub
  8. May 20, 2024 at 11:39 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Yes, slight rub for me also. 315/70-18 MT's, +25 offset. Doesn't worry me.
  9. May 20, 2024 at 11:49 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    If you have aftermarket (stiffer) front coil overs, just remove the sway bar. Its free to remove and try out and can just put back on. I've been running no sway bar on my Tundras since 2017 haha.
