Mounting Lights to Aftermarket Bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by jmladdy, May 20, 2024.
  1. May 20, 2024 at 4:17 PM
    jmladdy
    jmladdy [OP] New Member
    Oklahoma
    2020 Tundra TRD Pro
    I am trying to mount my Baja Designs Squadron-R fog lights to my CBI Baja Hybrid Bumper for my Tundra. Full transparency: this is the first time I am mounting lights to an aftermarket bumper and I have 0 experience with any of this.
    The brackets BD provide are too short and these XL 4x4TruckLED brackets I found are also too short (or too long if you flip them).
    I've been searching online for solutions, but I'm so novice that I don't think I'm searching for the right things.
    Suggestions, tutorials, resources, etc. would be great help!
    Y0TA PR0 likes this.
  2. May 20, 2024 at 4:21 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    What if you flip the light so the bracket doesn’t go all the way across the light body? Hopefully that makes sense. The light can be oriented in the other direction you can flip the lens also if the logo not being up right bothers you etc.
    FrenchToasty and GODZILLA like this.
  3. May 20, 2024 at 4:22 PM
    18" TRD Off Road Wheels
    @Baja Designs do you have taller brackets that could help?
    @memario1214 how about you, Sir? Anything in the warehouse that could solve this?
  4. May 20, 2024 at 4:23 PM
    I thought that flipping the bracket would work, but didn't know the lens could flip too or I would have suggested it.
  5. May 20, 2024 at 4:24 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yea lens can be flipped also.
  6. May 20, 2024 at 4:24 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Could just get a longer through-bolt, and then pick up a steel or aluminum spacer to close the gap :notsure:
    Mater, jmladdy[OP] and FrenchToasty like this.
  7. May 20, 2024 at 4:25 PM
    Just eyeballing it I think there would still need to be a bracket in between these two. The little silver ones would be in the same position demonstrated with the long one, and if you flip the long one then the light will be too low and hit the lower bar. I think, anyway.
    jmladdy[OP] likes this.
  8. May 20, 2024 at 4:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Looking at the pics hard to tell. But spacers might be need to clear that front tube
  9. May 20, 2024 at 4:28 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Also just to mention this isn’t uncommon on aftermarket products with so many combinations available some tweaking is always needed.
  10. May 20, 2024 at 4:31 PM
    You are advocating for tweaking?! :eek::eek2::eek::eek2: Hurry, everyone! Hide the copper and catalytic converters! :p
    jmladdy[OP] and reywcms[QUOTED] like this.
  11. May 20, 2024 at 4:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Alot of tweaking have you seen my stock tundra on 35s?
  12. May 20, 2024 at 4:33 PM
    I have seen your build. LOL
    reywcms[QUOTED] likes this.
  13. May 20, 2024 at 4:34 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    lol I’m aware.
  14. May 20, 2024 at 4:41 PM
    I just didn't know tweaking was how you got there. LOL
  15. May 20, 2024 at 4:49 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    All the tweaking
    jmladdy[OP] and GODZILLA[QUOTED] like this.
  16. May 21, 2024 at 5:44 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Exactly the issue with the long one; once flipped, it's too long and hits the lower bar.
  17. May 21, 2024 at 5:48 AM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Clearing the front tube is the issue! I'll go for spaces
    I'll try spacers and see how it fits! I was worried spacers might not be strong/stable enough, but it seems like that shouldn't be a concern?
  18. May 21, 2024 at 7:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    No concern there
    jmladdy[QUOTED][OP] likes this.
  19. May 22, 2024 at 4:12 PM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Found the sweet spot. Is this the right idea? Secure enough?
  20. May 22, 2024 at 4:27 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    I agree the brackets are a little to short, but I still mounted my BD like that and I find it works good at night. I do like that spacer though. I might try that when I take my bumper off to re-powder coat or line-x (haven’t decided yet) this summer.
  21. May 22, 2024 at 4:27 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Since you have the longer brackets, personally I would bolt those up to the bumper flip the light, and determine where you would need the screw hole to be for your ideal light placement, then drill a new hole in the long brackets. The spacer method that you have also should work just fine. Like Rey said you gotta tweak till you like the result. I can also grab a picture of my truck since I did something very similar to make a fog light fit.
    reywcms, jmladdy[OP] and Y0TA PR0 like this.
  22. May 22, 2024 at 5:37 PM
    APalmTree
    Brandon
    SW Washington
    Here is the modification I made. I was hitting the bottom tube with the SAE fog light which was not allowing me to angle it far enough down. So I cut the bracket and moved the bolt up. It is damn near impossible to tell from the front unless you are sitting exactly level with the front bumper.
  23. May 22, 2024 at 6:23 PM
    smokint
    smokint New Member
    2017 1794 2002 Tacoma
  24. May 22, 2024 at 7:05 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Nice! How long is that spacer ?
  25. May 22, 2024 at 7:08 PM
    smokint
    smokint New Member
    3/4”
  26. May 22, 2024 at 7:14 PM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Brilliant idea. Makes me kick myself that I didn't think to do it!
  27. May 22, 2024 at 7:19 PM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Exactly what I ended up doing, but with washers between bolt/bracket and spacer/bumper. What size bolt is that?
  28. May 22, 2024 at 7:21 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Thank you sir! :hattip:
  29. May 23, 2024 at 8:33 PM
    jmladdy
    Oklahoma
    2020 Tundra TRD Pro
    Great success! (Borat voice)
    Y0TA PR0 and smokint like this.
  30. May 23, 2024 at 8:39 PM
    smokint
    smokint New Member
    IMG_2203.jpg Good start but you’ve got a lot of room for more lights!
