Tire rub help
Discussion in 'Wheels & Tires' started by Elfine, Dec 19, 2019.
  1. Dec 19, 2019 at 4:03 PM
    Elfine
    Elfine [OP] Doing my best to break this beast
    Pensacola, FL
    2017 Quicksand Tundra TRD
    Datin Metal Fab 18" Bed Rack, ARB Diff Breather, SDHQ ABS Guards, RCI Engine/Transmission/Fuel Skid, ICON Stage 5, Rago Bed Stiffener/Ditch light brackets, ARB twin air compressor, 295/70R18 Cooper Evolution M/T, Spydertrax 1.25" spacers
    IMG_20191217_084825_422.jpg MVIMG_20191214_221803~2.jpg Good evening you savages, I need some advice. I recently installed an Icon stage 5 suspension and 295/70R18 Cooper Evolution MTs. Once the suspension settled I noticed that I am rubbing on the damn sway bar on the passenger side when fully left hand down. I included a pic of the driver side, and put an X where it is hitting.
    My question is, what is the best fix? This is my daily driver so I am hesitant to remove the sway bar, but will if I need to. Is there an aftermarket option with more clearance or would spacers help? I hit some pretty extreme trails.
    plumber802 and Vizsla like this.
  2. Dec 19, 2019 at 4:04 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Take it off.
  3. Dec 19, 2019 at 4:10 PM
    Elfine
    Pensacola, FL
    Have you done this and if so, how much difference do you notice on road or when towing?
  4. Dec 19, 2019 at 4:14 PM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    Looks like you are on factory trd wheels? I wonder if spacers would do the trick? I have 315/70/17 tires that don't rub, but I have aftermarket wheels with 0 offset and I don't rub my sway bar.
  5. Dec 19, 2019 at 4:20 PM
    Elfine
    Pensacola, FL
    Yeah I am still on the factory wheels (Icons kinda blew the budget). Spacers are definitely on the short list of fixes. Thanks
  6. Dec 19, 2019 at 4:30 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I have 35x12.5s on a +25 offset wheel (OEM wheels are +60) and I barely rubbed the front sway. A 1.25" spacer should get the wheels out far enough to not hit the swaybar (295s are ~.9" narrower than the 12.5"). Only issue to watch out for with lowering the offset of the wheel is that when turning, the backside of the tire could be closer to the cab mount.
    I just removed the front swaybar and so far I like it and have not had any issues. I take corners a little slower and I do feel the outside front corner dip a bit when turning but the 700# springs help to minimize the bodyroll.
  7. Dec 19, 2019 at 4:51 PM
    Elfine
    Pensacola, FL
    Awesome! Sounds like I will try the spacers then pull the sway bar if needed. Thanks for the advice!
    sr5shark[QUOTED] likes this.
  8. Dec 19, 2019 at 4:59 PM
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    One more thing - if you are going to spacers you should get a good quality hub-centric spacer (Spidertrax and Bora are a two options, there may be others).
  9. Dec 19, 2019 at 6:57 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Spacers will put you closer to cab mount and the bumper. You might have to massage some plastic liner too.
    Inquiringone and Elfine[OP] like this.
  10. Dec 19, 2019 at 7:02 PM
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Spacers and then probably bumper shims if you don’t want to mess with the fender liner after spacers.
    Black Wolf and Elfine[OP] like this.
  11. Dec 19, 2019 at 7:12 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Bora Spacers plus bumper shims, the all you need to do is remove the small front flap behind the fog lights. I have the bora’s and shims on my pro with OEM wheels with 295/70/18’s. Everything is good.
    sr5shark, Black Wolf and Elfine[OP] like this.
  12. Dec 19, 2019 at 8:29 PM
    I'm seriously thinking about keeping my TRD rims and going with 1.25" BORA spacers. Did you have to trim the OEM lug bolts or do they clear with the 1.25" BORA's??
  13. Dec 19, 2019 at 8:36 PM
    Shaggie13
    Mitch
    Central CA
    Or spend no more money and just remove the sway bar and die like a man.
  14. Dec 19, 2019 at 9:02 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    This.
    :bananadance::rofl:
  15. Dec 19, 2019 at 11:03 PM
    Aerindel
    Aerindel New Member
    Montana
    Never done this on a tundra, but my on my subaru that I use to off road, a front sway bar delete made a world of difference. (in a good way)
    I am now of the opinion that sway bars where designed by lawyers to make driving suck.
    Black Wolf likes this.
  16. Dec 20, 2019 at 3:52 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Everything fit. No trimming
  17. Dec 20, 2019 at 8:01 AM
    Kuul. Hmmmmmm....
  18. Dec 20, 2019 at 8:04 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Does it rub on both sides?
  19. Mar 11, 2020 at 7:34 PM
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Reviving an old thread, but how much harm does minor sway bar rubbing at full lock do? I am having some rub that has worn paint and a bit of metal down, but I don’t notice the rub day to day. Also don’t notice any issues on the tires thus far.
  20. Mar 11, 2020 at 8:51 PM
    jessenavarro
    jessenavarro New Member
    Jesse
    Oak Glen, CA
    2018 White Tundra TRD Off-Road 4x4
    Front Fox 2.5 Coil-over shock with adjustable reservoir -- DSC Rear Fox 2.5 shock with adjustable reservoir -- DSC Total Chaos Fabrication UCA -- tubular Method Race Wheels MR701 18x9 + 25mm -- Matte Black BFG KO2s - 35x12.5x18 Demello Sliders RetraxPro XR bed cover Yakima Roof Rack setup Baja Designs S8 40" light bars x2 (amber and white LED) Baja Designs Squadron Pro ditch lights Baja Designs Squadron Sport fog lights Switch Pros SP-9100 Midland MXT400 GMRS radio
    Following
  21. Mar 12, 2020 at 6:35 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Subscribed
  22. Sep 15, 2021 at 9:48 AM
    @TUNDRACRUZ
    @TUNDRACRUZ New Member
    2019 Tundra TRD off-road
    3/2 ReadyLIFT
    I have a 3/2 ReadyLIFT on my 2019 Tundra TRD off-road with stock wheels and tires and I’m afraid if I put 275 70 R18mt I’ll run into the same issue…????
  23. Jun 14, 2023 at 11:39 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Resurrecting this old thread.. did anyone get to a final solution?
  24. May 20, 2024 at 12:25 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    Would a sway bar drop bracket help this or make it worse ?
