aFe BladeRunner 2.5" Aluminum Hot Charge Pipe Kit Black
Discussion in '3rd Gen Tundras (2022+)' started by jeosbor1, Jul 27, 2022.
  1. Mar 29, 2023 at 7:15 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Again, 1yr running e30-e40 on map 5. Fuel trims are spot on at idle, part and wide open throttle. No timing pulled. About 12k miles on this setup. I think I have a lot more experience with this platform than you do
  2. Mar 29, 2023 at 7:23 PM
    YOTA_IL
    YOTA_IL New Member
    You do you bud. I’m just helping the ones who aren’t wanting to living on the edge of a blown motor.
    GeoNeo likes this.
  3. Mar 29, 2023 at 7:29 PM
    eddiefromcali
    Eddie
    100% Stock
    For anyone reading, this guy has ZERO first hand experience and is pulling info out of thin air. Would be more than happy to provide data logs to those willing to accept real world data
  4. Mar 29, 2023 at 7:35 PM
    YOTA_IL
    YOTA_IL New Member
    Provide us a current jb4 log 30mph-80mph wide open throttle, I will read your log that you say is perfect.
  5. Apr 1, 2023 at 6:20 PM
    eddiefromcali
    Eddie
    100% Stock
    Fuel trims at 25 is perfect, wot afr is 10:1, timing is on point
  6. Jan 27, 2024 at 1:01 PM
    Sap136
    Sap136 New Member
    2022 Tundra limited grey
    4mm and bigblue14 like this.
  7. May 18, 2024 at 4:23 PM
    NobleTundra
    NobleTundra New Member
    Kolby
    2024 wind chill pearl white 1794 limited edition
    Fox performance elite 2.5 front And rear coil overs Old man emu springs Ultimate 9 throttle controller Ted pro front grille Baja designs amber ditch and front grille light bar and fog lights
    Where are you buying cat less downpipes from? Been looking around and cant seen to find any.
  8. May 20, 2024 at 10:16 AM
    eddiefromcali
    Eddie
    100% Stock
    I didnt want to post it in public like that because CARB/EPA and all
    ryanwgregg likes this.
  9. May 20, 2024 at 10:48 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    The parts are for offroad/ exhibition purposes…
