  1. May 19, 2024 at 12:57 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Brakes are good. Should have taken it for a proper test drive before posting, probably. They didn't feel quite right sitting in park, but out & about today they're back to normal. The reason I wasn't convinced it was air getting sucked in the vacuum pump was that for the other three tires, I got clear fluid. I went through every tire three times total, and it was always only the driver front with all the bubbles. And when I removed the tube from all the valves, including the driver front, I'd get a huge vacuum release. But clearly for some reason I was sucking some air on that one bleeder valve.
    Anyway now everything's back to normal (except for somehow inflaming my forearm working that vacuum pump), and shifty` can't call my brake fluid 'gnarly' anymore :)
    BroHon, oscardog86, Weagle and 3 others like this.
  2. May 19, 2024 at 12:59 PM
    Looks good from my house!!!
    I’ve never done brakes before, but I found the positive pressure setup for bleeding to be pretty awesome! I’m usually a one man band so it made it super easy!
    Tundra2, BroHon, oscardog86 and 3 others like this.
  3. May 19, 2024 at 1:05 PM
    MT-Tundra
    Montana
    I bought this years ago and for how often I use it, it serves me well. But it's all I've ever used so I have nothing to compare it to.
  4. May 19, 2024 at 2:28 PM
    MT-Tundra
    Montana
    Turns out getting the Tacoma ready for selling will be some work. And this is before it goes to a mechanic for a complete check-over.
    Was under it yesterday (did a brake flush on both the Tundra and the Tacoma), and noticed the drive side blinker wires had sheared off. Again. So a new plug & wires are on their way. Can't sell a truck without a front blinker. Decided to lube the driveshaft, and when I hooked up to the slip yoke zerk & started pumping, grease just came falling out the bottom. Apparently the slip yoke 'grease plug' came off at some point. Might explain the subtle thump I feel when I shift...which is why I decided to lube it specifically in the first place. So for now my project list is all on the Tacoma again for a while. Plan to test my new drill bits and extractors on its broken skid plates bolts to see if I have more luck broken bolt extracting than I have in the past. All those little minor annoyances likely add up when someone's looking at it.
    oscardog86 and Voss like this.
  5. May 19, 2024 at 2:50 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Good news, everyone! I believe I have found the culprit to my 12v clusterfuck.
    After more terminal cleaning and re-grounding (to my entire truck, I think), the reason my taillights are not responding is...the metal coupler, on the OEM 4 way... does NOT exist!
    I think it came off during God-knows-when, but we should be G2G once I replace the connector entirely.
    NUDRAT, BroHon, oscardog86 and 4 others like this.
  6. May 19, 2024 at 5:32 PM
    Did you try turning it off and on?
    bmf4069 and metalpete[QUOTED] like this.
  7. May 19, 2024 at 5:37 PM
    metalpete
    ID
    Unfortunately, I used that special ability on the ambient temp sensor.
    shifty`[QUOTED] likes this.
  8. May 19, 2024 at 6:04 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
  9. May 19, 2024 at 6:13 PM
    metalpete
    ID
    bmf4069 and 455h0le_dachshund like this.
  10. May 19, 2024 at 6:48 PM
    VR6T
    Brake lines hooked up, parking brake IP, bleed down next
  11. May 19, 2024 at 6:56 PM
    VR6T
    Parking brake done, bleed down is IP
  12. May 19, 2024 at 7:54 PM
    VR6T
  13. May 19, 2024 at 8:42 PM
    VR6T
  14. May 19, 2024 at 9:19 PM
    kson
    kson New Member
    K. Son
    2001 White Tundra SR5
    ham radio and aux power bus
    Tore apart the dash and ran aux wires for a ham radio.
  15. May 19, 2024 at 9:52 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Speakin of batteries. I moved a ceiling fan that has a remote and no pullchain for the light or fan to another room in my crib a while back. Dam thing decided to only work on high speed with the light on and nothing else. I finally last night took the cover off and removed the remote receiver since the remote showed a good link, blinking and everything but just not working. I figured I was going to have to replace either the receiver unit, the capacitor, or just scrap the entire fan altogether. I had already tried multiple times to re-pair the remote to it with its little learn button. Popped the cover with the capacitor and receiver back on the fan and still no go. Dammit. I just so happen to have another remote that I use for several bulb sockets to remotely turn them on and off and that uses the same battery so I decided to swap them out. I pressed the learn button again and in about 2 seconds I had a fully working ceiling fan again. Nice! Lesson learned. Even though the remote light is bliking, the battery may be too low to actually work the device its intended for.
  16. May 19, 2024 at 10:00 PM
    artsr2002
    'Yonder
    Welcome to the forum.
    Voss and VR6T like this.
  17. May 19, 2024 at 11:16 PM
    VR6T
    And now I'm done.
    Toilet replacement finished up, truck done. Hardest of core thank yous to @FishNinja @455h0le_dachshund and @Mr.bee for the assists today.id honestly still be doing the axle right now without y'all.
  18. May 19, 2024 at 11:46 PM
    VR6T
    Good luck
  19. May 20, 2024 at 4:18 AM
    We couldn't get mine seated, and both sides leak. Still. I'll pull em eventually but with summer starting that may be an October problem.
  20. May 20, 2024 at 4:22 AM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    I got similar numbers on my truck when i Dynoed her, with just AFE intake and URD MAF tune. Now I have an R0K tune, JBA long tubes and DD Race exhaust and 12 hole injectors. I really need a VF tuner, but thier website showed zero tunes available for the VVTi 2UZ
    455h0le_dachshund likes this.
  21. May 20, 2024 at 5:24 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    I know I'm late to this conversation, but did you have a baseline before the DD 12 holes?
  22. May 20, 2024 at 5:31 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Yes and it was very low. I think the truck was in limp mode or something because it read like 202 WHP and 240TQ. I posted here like 2 years ago. plus my 2nd run on a different Dyno which reads higher. Final numbers were 268 WHP.
  23. May 20, 2024 at 5:34 AM
    Weagle
    Prattville, AL
    Ok thanks.
    Just curious because thus far I've only read opinions on how it felt before and after as to whether the 12 hole's helped
    Some said they could feel it, others said not so sure.
  24. May 20, 2024 at 5:37 AM
    That quoted Dyno chart makes no sense to me. Why is it in MPH and not RPM?
    Weagle likes this.
  25. May 20, 2024 at 5:45 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I think you meant to reply to the other guy, not me.
  26. May 20, 2024 at 5:49 AM
    Indeed, couldn’t find his post maybe @Riverdale21 can comment
  27. May 20, 2024 at 5:50 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I've gotten my 06 VF tuned thru my buddy who does em
  28. May 20, 2024 at 5:51 AM
    Love to see real world Dyno with bolt ons and tune that show 40+hp gain at the wheels.
  29. May 20, 2024 at 5:54 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I felt them for sure, but thats just butt Dyno. they are very responsive but Keith himself told me that there wont be much gains or any at all on Dyno.
    Weagle[QUOTED] likes this.
  30. May 20, 2024 at 5:55 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Look at my Dyno sheet I posted here a few years back.
