Custom nerf bars for access cab..
Discussion in '1st Gen Tundras (2000-2006)' started by parkss1181, May 18, 2024.
  1. May 18, 2024 at 11:18 AM
    parkss1181
    parkss1181 [OP] New Member
    Shane
    2002 TRD limited Access cab V8 4X4
    None yet, some to come !
    Id like to order these for my 2002 access cab, and cut them to be rewelded by a professional shop, to be shortened so the bed step would line up. I know I’ll have to modify the mounts and even drill holes for the mounts. Anyone done anything like this? Would love pics if anyone has any. Thanks
    abcinv likes this.
  2. May 18, 2024 at 12:27 PM
    @abcinv actually has step bars from a name brand that are very, very similar to that. I forget the name (EDIT: I think it's n-Fab), but can look it up.
    His post on it: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1543#post-3074713
    This is the link I think: https://www.amazon.com/dp/B072KKF7SH
    He also linked up these other ones that should fit AC/RC but they looked a bit sketch on quality (to me): https://www.tundras.com/threads/nerf-running-board-sale-on-amazon.115139/#post-2972682
    Weagle and abcinv like this.
  3. May 18, 2024 at 1:36 PM
    parkss1181
    Shane
    yeah I ended up seeing those too, but since they are pretty expensive might just have to go to a shop and ask them for a custom set, since either way I’ll end up at the shop for them to shorten them for an AC cab, might just be better off having a shop make some for me.. thank you for the reply I’d really like the one to have the truck step.
  4. May 18, 2024 at 1:40 PM
    Sometimes scAmazon kicks deals on those nFAB units, I want to say acbinv got his on sale for $340 or something.
    abcinv likes this.
  5. May 18, 2024 at 2:45 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    This is true, sometimes they will pop on sale. I got mine for $283.55 total...
    Weagle and shifty`[QUOTED] like this.
  6. May 19, 2024 at 6:23 AM
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Man, I'm jealous. I spent weeks researching nerf bars. I guess I just missed the n-fab's due to the price. I could've sworn when I looked at the one for the 06 double cab it did not have that extra step for the truck bed
    side note: I ended up with two extra sets of black Westin Nerf bars for a double cab because the first two arrived with a slight ding and they told me to keep them instead of returning
    abcinv[QUOTED] and shifty` like this.
