Official Banks Power 3rd Gen Tundra Discussion
Discussion in '3rd Gen Tundras (2022+)' started by ToyFan, Sep 20, 2023.
  1. Apr 15, 2024 at 10:16 AM
    #151
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I was under the impression that the harness wasnt to power the unit, rather to control the activation of the spoiler/access canbus. I was a beta tester for that as well. I believe power comes from the MAP sensors
    ryanwgregg[QUOTED] likes this.
  2. Apr 15, 2024 at 10:57 AM
    #152
    eddiefromcali
    Eddie
    100% Stock
    I believe so. I actually left the obd connection instead of the FAS harness. Makes for easier install/removal for me just reaching under the dash vs reaching the spoiler harness.
  3. Apr 15, 2024 at 7:55 PM
    #153
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Does this include a pedal monster with different firmware?
  4. Apr 16, 2024 at 9:36 AM
    #154
    ToyFan
    ToyFan [OP] New Member
    Jay
    2018 Tundra
    Black Rhino Wheels
    Yes, Test Pilots will wirelessly receive beta firmware.
    Tacotundra, bulldog93 and ryanwgregg like this.
  5. Apr 16, 2024 at 6:01 PM
    #155
    matth66
    matth66 New Member
    matt
    Nor cal
    So you need to already have a pedal monster?
  6. May 1, 2024 at 7:08 PM
    #156
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    Well we just got done with the testing and I’m hooked on the banks pedal monster. It’s pretty dam good. I’m running city mode with level 4, just went up to level 5 today. It feels great compared to stock. The reverse safety feature is great. It detects when you go into reverse and switches back to stock so you have that really soft pedal feel for backing up. I also tried the track mode and it was insane lol you press the pedal a little and it’s pretty much floored. No reason for me to use the track mode but it’s there if I needed it. I’ll probably be adding the idash to it as well. Not that my opinion is special but I would recommend the pedal monster to anyone. With the wide variety of options it can suit any way you want the pedal to feel. Thanks again @ToyFan for giving me the opportunity to help you guys test it out.
  7. May 1, 2024 at 7:17 PM
    #157
    matth66
    matth66 New Member
    matt
    Nor cal
    My only wish is that it had a dedicated switch. I don’t really need the I dash (with all the extra info)and I don’t like using my phone to make adjustments. It would be great if perhaps they had a switch with say 4 favorites that you set using your phone, but after you set it you don’t need your phone.
  8. May 1, 2024 at 7:17 PM
    #158
    eddiefromcali
    Eddie
    100% Stock
    Yeah, can definitely tell when it goes in/out of reverse safety mode. I have about a 5 second delay and can tell/see when it switches over and it's an instant noticeable difference in pedal input.
    ryanwgregg and Taikowaza like this.
  9. May 1, 2024 at 7:55 PM
    #159
    Taikowaza
    Taikowaza New Member
    Also running city mode on the pedal monster and absolutely love it. I also like using tow mode with pedal monster, and dial it down when I do that. Amazingly satisfying and responsive power on tap. Using it with an idash where I’ve corrected the speed gauge with my revised tire size. Just a superb product that since the most recent Toyota neutral roll recall and transmission flash has basically eliminated my turbo lag.
  10. May 1, 2024 at 9:15 PM
    #160
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    So I was one of the testers also. The reverse safety is a cool feature. I am running mine on city and at level 2. When I tried the higher power settings I didn’t like how it was shifting. The lower settings work perfectly for me. Cleans up the dead pedal feel doesn’t eliminate it but it is way better. Super easy to install. Over all it’s a nice product and it works great! Thanks @ToyFan for letting me be part of this you guys rock!
    tfry02, ryanwgregg and bulldog93 like this.
  11. May 7, 2024 at 8:53 AM
    #161
    tfry02
    tfry02 New Member
    2023 Limited TRD OR Toyota Tundra
    I was lucky enough to be selected to test the PedalMonster. Being able to change the throttle response curve is an absolute game changer. To anyone that is on the fence about the PedalMonster, do your self a favor and purchase it. In my opinion, you wont regret it. As @Tacotundra mentioned, it really cleans up that dead pedal feel. Makes Sport mode just that much more fun. I went as far as purchasing the iDash as well after the testing period. Being able to control the Pedal monster from the iDash is quite nice. I have used Banks products before and appreciate the time and effort that Banks puts in to each product they support.
    @ToyFan Thank you again for allowing me to be apart of the pilot testing. I tried to take a look back through the thread to determine if the engineering team was able to find a solution regarding current gear information for the iDash. However, I didn't find anything. Have there been any updates on current gear PID for iDash?
  12. May 7, 2024 at 9:19 AM
    #162
    MaxPayne3
    MaxPayne3 New Member
    2024 Lunar Rock SR5 Crew Cab
    Just starting out but never will be done
    I recently purchased an iDash and pedal monster and also would like to be able to see the actual gear instead of just PRND as well. I recently took a trip and noticed the truck was hunting for gears, would have been nice to see what gears it was cycling through so if it continues to be an issue it will help narrow down my issue.
    tfry02[QUOTED] and bulldog93 like this.
  13. May 18, 2024 at 3:53 PM
    #163
    MIK12
    MIK12 New Member
    Warning - sort of pic heavy.
    I really like the Banks equipment I have installed in my '23 Platinum non-hybrid. This is the first time I've owned Banks equipment and I was hesitant to go "all in" up front. Initially, I bought a Pedal Monster, an iDash and a single gauge pod mount. I got one of the early pods that didn't fit so well. The first 2 pics show the single pod and the fit problem. Pod issue aside, I really liked the Pedal Monster and the iDash, but I wanted more info. @ToyFan worked with me to go from the single pod to the double and now I have a second iDash - pics attached. Much better fit.
    For me, the setup removes the pedal sluggishness, but I think it may have affected the leather surface of the passenger seat because I've gotten a little side eye from my wife that I can only assume is caused by some rearward shift that she didn't expect. I don't know. I'll continue to monitor that.
    The iDash gauges give me instant on the fly changes to the Monster settings and all the real time feedback I want regarding what the truck is doing. I especially like being able to know what the transmission temp is when towing. I usually run the Pedal Monster in City mode Level 7, with occasional trips into Sport and Track mode levels. I have to say, Track mode at 10 is flipping crazy (see side eye comment above). This thing doesn't need to go to 11.
    @ToyFan thanks for your help with this - I really appreciate it.
    IMG_0469.jpg IMG_0470.jpg IMG_0475.jpg IMG_0476.jpg IMG_0479.jpg IMG_0482.jpg
  14. May 28, 2024 at 6:16 PM
    #164
    tom_w2287
    tom_w2287 New Member
    Tom
    2024 Tundra SR5
    Weatherguard toolbox, Ranchhand grille guard
    Any update on the monster exhaust?
  15. Jun 4, 2024 at 10:53 AM
    #165
    ToyFan
    Jay
    2018 Tundra
    Black Rhino Wheels
    Great news! New PedalMonster firmware is now available for 2022-2024 Tundras. This firmware adds Reverse Safety for those using PedalMonster as a stand-alone (controlled via mobile app). This was previously available to those with an iDash or using beta firmware. If you'd like to update, the next time you connect the mobile app to the PedalMonster, you'll see a pop-up alerting you to download the new firmware. If you don't see it or accidentally dismiss the notice, you can access the firmware by clicking on the menu in the top left corner and then scroll down to Module Info. From there, you can command the update.
    As a side note, this update also adds Reverse Safety for 2014-2024 4Runner and 2024 Tacoma stand-alone PedalMonsters.
  16. Jun 6, 2024 at 6:01 PM
    #166
    Odinsravens
    Odinsravens New Member
    Kris
    22 Tundra MGM TRD Limted
    Wescott Lift
    Is there an ETA on possible air intake yet?
  17. Jun 6, 2024 at 7:01 PM
    #167
    ToyoWorld786
    ToyoWorld786 New Member
    2023 Black Limited TRD Off Road
    Anyone using these to monitor speed? Really considering getting one as I’m looking to upgrade to 37s and would like to see accurate speed as I do a lot of interstate driving for road trips and this allows you to update tire sizes in the module itself. Also are there any group discounts or group buys currently on going for this? Saw a post in this thread on some earlier but wasn’t sure if still active. Thanks!
  18. Jun 7, 2024 at 7:40 AM
    #168
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    I use it with 35s. Works very well, verified by GPS and a handful of different radar signs on my way to work
    bulldog93 likes this.
  19. Jun 16, 2024 at 5:43 PM
    #169
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    @ToyFan - Is there a date for the next iDash firmware release? Looking to have oil pressure, current gear and convertor locked added to display for '23 Tundra Hybrid application. Currently on iDash_6288X_05_1_24_0, it does not have the coverage.
  20. Jun 17, 2024 at 8:44 AM
    #170
    mass-hole
    mass-hole New Member
  21. Jun 17, 2024 at 8:45 AM
    #171
    jctmundra
    Northern VT
    see post 99 -
  22. Jun 17, 2024 at 5:41 PM
    #172
    223Wylde
    223Wylde New Member
    Jeff
    Cottage Grove, MN
    2023 Tundra TRD Pro MGM
    Has there been any progress on adding current gear to the iDash? I'd really like that option, I've noticed the only way to get it to display on instrument cluster is to move the stick to manual side.
  23. Jul 10, 2024 at 9:20 AM
    #173
    DaveE
    DaveE New Member
    2023 Platinum Hybrid, Magnetic Gray
    got bored waiting for the wife in the parking lot, so I tinkered with the idash and color matched it to the stock electronic gauge. Love how it turned out.
  24. Jul 13, 2024 at 12:21 PM
    #174
    blenton
    blenton New Member
    For those of you who have installed an iDash, does it require an update to view Toyota specific PID's? I just installed one on my 2nd gen and have nearly zero options for gauge selection. Some of the initial PIDs don't even work on the 8 gauge display and are just blank. I've worked my way through the settings page and selected Toyota, adjusted some colors and brightness, etc, but I'm feeling like a simpleton not getting this gauge to display any useful information. I've been using my head unit via iDatalink to display trans temp and such for towing but wanted a dedicated gauge. I followed the link they provide on the instruction sheet. Firmware is 1.24.0
    @ToyFan I'm kinda feeling a little snookered. Or like my IQ took a nosedive over night (not out of the realm of possibility). I bought a second iDash for my sequoia so I hope I can get it working.
  25. Jul 20, 2024 at 10:01 AM
    #175
    TacCoyote
    TacCoyote New Member
    2024 Tundra Hybrid TRD Limited CrewMax 6.5'
    Couldn’t find a close match from SEM rattle cans, so mixed up a custom color.
    AND and bulldog93 like this.
  26. Jul 20, 2024 at 2:03 PM
    #176
    lapoolboy
    lapoolboy New Member
    Looks close. Can we get the recipe?
  27. Jul 20, 2024 at 2:19 PM
    #177
    TacCoyote
    I don't have a recipe unfortunately, it was done ad hoc.
  28. Jul 20, 2024 at 2:20 PM
    #178
    lapoolboy
    Dammit.
  29. Jul 22, 2024 at 1:51 PM
    #179
    TacCoyote
    Thanks @ToyFan for the awesome products and great help here on the forum.
    Cbrash and bulldog93 like this.
  30. Jul 23, 2024 at 10:00 AM
    #180
    lapoolboy
    Paint match looks pretty good but I see the fitment of the pod is still off? Is that the original release or the 2.0?
