Rough county sucks
Discussion in 'Suspension' started by Battousai, May 18, 2024.
  1. May 18, 2024 at 12:52 AM
    Battousai
    Battousai [OP] New Member
    OC
    2024 iforcemax tundra limited
    Ordered a borla atak delivery April 2!!
    3.5in lift kit
  2. May 18, 2024 at 3:20 AM
    How much weight is in the bed?
  3. May 18, 2024 at 3:42 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    I'm not being a stick in the mud here, I got the shaft from a so called " good Vendor here" and I didn't......
    Anyway a little more description would be helpful in your defense to help get the troops rallied here.
    Looking at you pic's yeah that sucks the corn hole and I'd be pissed too but what's the load rating for the lift,what type of lift is it (bags,springs shocks) and how many pounds is that flooring?
  4. May 18, 2024 at 4:20 AM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    its called carrying alot of weight, its not setting like its unloaded!
    ATV25 likes this.
  5. May 18, 2024 at 4:28 AM
    Rykr
    Rykr New Member
    2023 SR5 TRD Sport 4x4 MGM
    Guy has 1400 lbs in the bed and complaining it’s squatting. Cmon. RC is stamped out in the same factory as Icon. Same shit different sticker.
  6. May 18, 2024 at 7:02 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    The names bags.....air bags.
    That's so much weight dude, my roadmaster setup would even squat
    NatesNightMare and B.Ross like this.
  7. May 18, 2024 at 9:04 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    should have bought a gen2
    air baaaggggzzz.....
    :boink:
  8. May 18, 2024 at 9:05 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    On the bright side, those Geolandars are taking the weight like a champ!
    Black Wolf, Black widow TRD and ATV25 like this.
  9. May 18, 2024 at 9:28 AM
    Breathing Borla
    Northern Illinois
    gen 2 with less payload? How would that help
    SpilledTheSalt and digitalwiz like this.
  10. May 18, 2024 at 9:37 AM
    TT YOTA
    TT YOTA New Member
    Shane
    Phx az
    2022 tundra sr5
    Trd pro bbs wheels Trd pro fox shocks Wescott level kit
    Nothing in the bed but 2 pallet of pavers in the dump tailer on trd pro fox shocks surprisingly I didn't hit the bump stops truck did great but won't be doing that again
    Battousai[OP] likes this.
  11. May 18, 2024 at 9:46 AM
    Breathing Borla
    Northern Illinois
    Looks like the trailer is a little front loaded as well
    Colotundie likes this.
  12. May 18, 2024 at 9:57 AM
    wxman91
    wxman91 New Engine Enthusiast
    Montana
    2022 TRD Sport 4x4 Army Green / 2021 4Runner Limited
    CBI Baja Bumper / BD S2s Falken Wildpeak AT3W 315/70R17 Method 316s TRD Pro Fox Suspension w/Total Chaos UCAs TRD Dual Tip Exhaust TRD CV Axles TRD Pro Flares + Heritage Grille Alpharex Headlights Dobinson Coils RCI Skid
    I'm betting those rear coils that come with the RC kit are still stock load rated. Time to hit up Dobinson's.
  13. May 18, 2024 at 10:15 AM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    If you need to do real truck stuff rarely enough that it doesn't make sense to buy a 3/4 ton or 1 ton, the 2nd gen is still a fantastic option.
    Remember that ranch that Toyota gave a 2nd gen Tundra to and told them to go ahead and overload it and abuse it? They used that 2nd gen to pull 12 cattle (@ ~1200 lb each) and a massive water tank for 100,000 miles. The ranchers said truck was in better shape than the HD trucks they were using previously. Toyota tore it apart afterward and didn't find any issues.
    PS: Rough Country sucks no matter what gen you're driving. :hattip:
  14. May 19, 2024 at 2:16 AM
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    I bitched about the price of the Toyota airbag system on my tundra when I bought it but it's spot on and great when carrying a load.
  15. May 19, 2024 at 4:23 AM
    You'd be surprised how many different brands are made in the same overseas factories. Rough Country actually stepped up their game a lot after Covid. Some RC stuff is now being made in Dyersburg, TN where their R&D facility is also located and RC switched factories overseas that were manufacturing their larger hi lift kits that had known issues with QC. RC is very affordable for many on a limited budget.
    Rugerla1 and texasrho83 like this.
  16. May 19, 2024 at 4:43 AM
    yakeng
    yakeng 3URFE Apologist
    I’m not sure why the OP is so surprised about this result. This is exactly what lifted trucks look like when you put load on them without any load assist.
    My favorite thing is watch the bros back down their 6” lifted squatting trucks at the boat ramp.
    Battousai[OP] and Black Wolf like this.
  17. May 20, 2024 at 6:56 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Vinyl flooring is very heavy. I wouldn't be surprised if that was closer to 2000+ lbs in the bed. Last time I bought vinyl flooring I was about half that high in my bed and I was a good 1400 lbs (that was in the Chevy though). That was some pretty dense Vinyl though...
    @B.Ross Looks like you got about 100 ea 2x4x8' Kiln Dried DF or Pine studs in there so about 800-1200lbs depending on moisture content maybe could be 1200-1400 lbs if it was still green. We know we know...all the 3ed gen owners should have bought 2nd gens......
    @Battousai Share the brand of Vinyl flooring and how many boxes ya got in the bed, lets get an idea what kind of weight caused that amount of squat.
  18. Jun 4, 2024 at 4:35 PM
    Battousai
    OC
    Sorry was busy, ok hold on let me find out
  19. Jun 4, 2024 at 4:42 PM
    Battousai
    OC
    Total 950sqft
    6.5mm with padding
    20mil wear layer
  20. Jun 4, 2024 at 4:51 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    Don't know the specific product but... here is one example I found with a quick google
    My calculator tells me that works out to 1,456.9 lbs. Squat looks about right for that.
  21. Jun 4, 2024 at 7:20 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    A lift kit does what is supposed to do. It lifts the truck. However fussing and saying it sucks because it squats is simply and expectation issue. A lift doesn’t mean no squat.
    Unless you get stiffer springs you’re just getting a lift. However if you get stiffer springs that don’t squat the ride will get significantly stiffer and then people fuss about how it rides.
    I know it’s a bit different but the best thing I did for my 2019 that squatted was the road active suspension. But it’s designed to help stop squat. I know they don’t make it for this truck but still.
    find something that stiffens up the rear. I will also guarantee it will cost more than the rough country stuff as well. This doesn’t mean rc sucks but it seems to mean you don’t want to pay for the proper suspension that will keep the truck from squatting under a load. The rough country suspension isn’t designed to stop squatting under weight but to give the truck a lift. Very different things. Just a thought.
