Suspension help
Discussion in 'Suspension' started by BeachTundra757, May 16, 2024.
  1. May 16, 2024 at 5:38 PM
    BeachTundra757
    BeachTundra757 [OP] New Member
    Jon
    2010 Tundra SR5
    6” front, 3” rear fabtech lift
    Can someone help me identify what type of strut extension this is? What it’s called and if I can buy them somewhere? This lift was on the truck when I bought it. I believe the front struts are stock and they just put these extensions on to lift. I bought new suspension and they are 2.5” diameter. They will not fit into the top of the mount. So I’m looking for these with a larger diameter. Thanks for any help you can offer!!
  2. May 16, 2024 at 5:46 PM
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
    If you have to run a spacer lift for your setup, I would personally rather run a standard top hat spacer.
    I have attached a photo of the type I’m taking about, circled in red.
    What brand and model of 2.5’s did you purchase? Maybe you can run smaller spacers or forgo the spacers altogether to achieve the same lift.
    To answer your original question, I’m not sure where to find your current style of spacer.
  3. May 16, 2024 at 5:59 PM
    BeachTundra757
    Jon
    2010 Tundra SR5
    So I got the Bilsteon 6112 which are adjustable. So figured that would be all I needed. But after a lot of video research… when the C clips are in the top notch, the ride is absolutely garbage. So I don’t want to go that route. I can do the spacers. Just wasn’t sure about it
  4. May 16, 2024 at 6:23 PM
    BeachTundra757
    Jon
    2010 Tundra SR5
    Thank you for your response BTW!
    Slag_Dynamics likes this.
  5. May 16, 2024 at 8:11 PM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    That's part of some huge lift kit. Like 6" or more as a guess. You probably have a full subframe drop on there as well
  6. May 16, 2024 at 8:38 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Take those parts off and send to Hawaii. That’s gotta be over 10” of lift if your shocks are extended close to 6” like that.
    crikeymike likes this.
