2024 Oil
Discussion in '3rd Gen Tundras (2022+)' started by ridre52, May 16, 2024.
  1. May 16, 2024 at 2:34 PM
    ridre52
    ridre52 [OP] New Member
    Robert
    Hey everyone, I understand that Toyota recommends 0W-20 engine oil. Could I use a thicker oil in this engine or will that cause problems? My concern is all of the engine failures I am seeing on 22-24's with the main crank shaft bearing. Perhaps it's the thinner oil that can lead to this? Just a thought and would love to hear your thoughts as well.
  2. May 16, 2024 at 2:35 PM
  3. May 16, 2024 at 2:48 PM
    DFS
    DFS New Member
    2022 Capstone Tundra
  4. May 16, 2024 at 3:13 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Strictly for perspective as you wrestle with your decision. I run 5W30 (O.K. Before you ask. Costco Kirkland brand) and have for a long time.
    And now a word from our sponsor: LOOOOOOOK >>>>> a squirrel.
  5. May 16, 2024 at 3:27 PM
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    OIL ALONE IS NOT ENOUGH
    They make a synthetic one but I used this photo because I love the catch phrase…and it doesn’t say it on the synthetic one.
    Probably makes Lake Speed Jr. have a conniption
    Alice123 likes this.
  6. May 16, 2024 at 3:31 PM
    mass-hole
    mass-hole New Member
    The overseas trucks with this motor in it are ok to run up to 10W-30. If it were me I would run 5W-30 or 10W-30 but thats up to you and if you want Toyota questioning you about oil changes when you engine blows up anyways.
    Or you could just buy 0W-20, return it, and keep the original receipt so when they do ask, you have a bunch of 0W-20 receipts to show them.
    SC4333 likes this.
  7. May 16, 2024 at 5:16 PM
    lapoolboy
    lapoolboy New Member
    Why do people insist on going against what the manufacturer specs for the engine that they designed and developed? They say to use 0W-20....it's readily available....why use anything else? Just for shits and giggles? Or to see who can grenade an engine the fastest? I truly don't get it.
  8. May 16, 2024 at 5:26 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Because Toyota only requests 0-20 to appease the CAFE requirements, we as the consumer want our engines to last longer. Meanwhile overseas they can run thicker oils….
    To each their own. I’d love to run thicker oil. I was not aware running thicker oil would grenade an engine; that overseas is specd for thicker oil…
    GAMark, aj350925 and BlueCrushSC16 like this.
  9. May 16, 2024 at 5:29 PM
    lapoolboy
    Are you 100% certain the overseas 3.4TT engines are exactly the same as the US ones?
    Thicker oil does not have the same flow characteristics and I myself take some comfort in knowing the thinner oil is getting to the already failure-prone bearings better/easier/faster/whatever.
  10. May 16, 2024 at 5:31 PM
    ridre52
    Robert
    That's not the reason I asked the question. They recommend a very thin oil. Seeing all of the crankshaft bearings issues I was starting to think it could be related to the thin oil and was wondering if using a thicker oil would 1. Prevent this and 2. Hurt the engine in any way.
  11. May 16, 2024 at 5:33 PM
    lapoolboy
    Thicker oil can starve the bearings.
  12. May 16, 2024 at 5:33 PM
    ridre52
    Robert
    Do you have documentation that shows that they use a thicker oil for the V6 overseas? I have no doubt they recommend the thin oil here in the US to appease the regulators and for MPGs
  13. May 16, 2024 at 5:42 PM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    use whatever you please
  14. May 16, 2024 at 5:57 PM
    ridre52
    Robert
    Thank you for your feedback
    dJunior and ryanwgregg[QUOTED] like this.
  15. May 16, 2024 at 6:13 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    FWIW… Main bearing oil clearance on the V35A is actually larger than the UR Series V8 engines.
  16. May 16, 2024 at 6:35 PM
    Black widow TRD
    Manuel
    But I think the big question is will Toyota void your warranty for using thicker oil here in the U.S., even though the overseas variant can run thicker oil.
    I don’t think the overseas variant received different internals due to the evap. system….
    I’d be happy to run and have ran 0w-30 Pennzoil Ultra Platinum.
    91 octane only… I’d do 93 if available. Don’t wanna beat the dead horse, poor ol’ horse been beat constantly.
    The info is out there. You do you. Everyone is a big boy.
  17. May 16, 2024 at 6:59 PM
    Jb357
    Jb357 New Member
    They do that themselves
    Hbjeff likes this.
  18. May 16, 2024 at 8:04 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    So it does make me wonder when my work truck is a 3.5 ecoboost. Spec is 5w-30 for oil and were told 5k intervals maybe 6k but never more.
    Sooooo how does toyotas similiar engine go to 10k intervals on a thinner oil? Hell if I know but I know our work trucks get a lot of idle time and some quite spirited driving.
    No engine failures but we have smoked a transmission or 2.
    Fuel used is 87 or 88 octane.
  19. May 16, 2024 at 9:07 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I think we are seeing a bit of many issues:
    1) Thinner oil.
    2) stop/start of the engine.
    3) fuel dilution.
    So if we look at the typical engine failure at ~29k miles. And following the manufacturer’s OCI. Then most of the failures would be approaching the 3rd oil change. So the fuel would have broken down the oil.
    Then add the 2 x 2 quarts from the previous 2 oil changes of watered down oil that doesn’t get changed because it stays in the engine.
    So my take is to adjust my OCI to 5,000 kms (3,000 miles) Using 0w20.
    Turn off the engine stop/start off.
    And like @ryanwgregg says, use higher octane gas and drive it!
    Humpiedog, mve, in_the_mud and 2 others like this.
  20. May 16, 2024 at 9:11 PM
    SpilledTheSalt
    SpilledTheSalt Fish Lips
    Oregon
    2024 Tundra 4x4 HV Limited TRD
    2" RC Leveling Struts
    I dropped the initial oil at 500 and just plan on doing it every 4-5k going forward using 0w-20 (Amsoil signature) I also only run 92 octane.
    Humpiedog and Hadelson like this.
  21. May 16, 2024 at 9:27 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    The most important thing is to use only Genuine Toyota oil. It’s made with love and care like Wagyu cattle.
    Humpiedog and Paul499 like this.
  22. May 16, 2024 at 9:56 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    What if some owners are vegetarians?
    Wagyu tofu! :) is that a thing? ;)
    Dalandshark likes this.
  23. May 17, 2024 at 5:09 AM
    ridre52
    Robert
    I completely agree
    ryanwgregg[QUOTED] likes this.
  24. May 17, 2024 at 7:30 AM
    ridre52
    Robert
    Why? I shut it off Everytime. But why do you suggest we use it esp. +100000?
  25. May 17, 2024 at 7:36 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
  26. May 17, 2024 at 8:01 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    I agree! I don't think this is something you can point a finger at and all we can go by is what is happening in front of us.
    If we combine a system that repeatedly shuts off the oil pump and, oil that is already very thin and then break it down with fuel! What do we get?
    Just saying, add a bunch of things together and the bearings are in the firing line.
    If there is something systemic or problematic within Toyota, we will never know about that. Or perhaps the EPA or other governing body has clamped down so hard on emissions that Manufacturers are struggling to get life out of their engines?
    I really don't think that our engines are poorly designed and they should give us many years of trouble free service, we just need to wade through the crap to figure this out.
    dJunior likes this.
  27. May 17, 2024 at 8:06 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    False.
    Hadelson likes this.
  28. May 17, 2024 at 8:09 AM
    rogzballz likes this.
  29. May 17, 2024 at 8:13 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
  30. May 17, 2024 at 8:18 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I used to use vegetable oil, but I only use extra virgin olive oil these days. It's better for you.
    sudobash, Humpiedog, pwpblue and 3 others like this.
