How to wire pod lights into factor fog lights
Discussion in 'Lighting' started by TexMedic, May 16, 2024.
  1. May 16, 2024 at 1:40 PM
    TexMedic
    TexMedic [OP] I ask a lot of questions…
    2017 Dark Gray DC Tundra 4x4
    I’ve seen some similar posts, but haven’t see my exact case, hence me making a new post. I got a new bumper, as well of 2 sets of pod lights. What would be the best way to connect the pod lights (2 on each side of bumper) to the factory dog light wire? I’d like to wire both pod lights into an extra harness so I don’t have to cut off the old fog light harness/clip, but at the same time I don’t know shit about electrical. Carli has some adapters, which are exactly what I need, except for the fact that it’s meant for only one pod light. I need to be able to connect both pod lights to each clip/wire.
    Factory Fog light clip:
  2. May 16, 2024 at 1:42 PM
    TexMedic
    Here are the Carli adapters. Not sure if I’d be able to modify them at all.
    AstroDude likes this.
  3. May 16, 2024 at 1:42 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. May 16, 2024 at 1:44 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Those will plug into Deutsch connectors.
    That is what I used to make, some Rigids come with these connectors.
    What connectors, if any, do your new lights have on them?
    234016AF-1142-44F3-BE2C-CBD1E7894B24_zps_de9c41dec89e339ef93568c3208a2709d750c744.jpg
    5B002C7A-1EE4-4CAC-ABC1-1A9AE7E2E5D8_zps_2821993df731cd41a2aef5d242b0198e4bde8332.jpg93BE8C07-DD4A-4DF9-8CAE-66F318E4480C_zps_35876d5d93581a24bea2253c714c7851f300b905.jpg
  5. May 16, 2024 at 1:48 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  6. May 16, 2024 at 1:51 PM
    TexMedic
    When it comes to electrical, I don’t know shit about shit…
    So here are all the pictures of everything.
    OEM fog light:
    Adapter that came with pod light (plugs into fog light):
    End of pod light:
  7. May 16, 2024 at 2:32 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  8. May 16, 2024 at 4:21 PM
    TexMedic
    The OEM fog light plug is the little green thing in this picture:
    The pic you reposted was the end of my new pod light.
    But I think you’re right. If I get both of the pieces you sent me, it should essentially just plug all in. If by chance it doesn’t, then my neighbors will get to enjoy watching me throw a little rage fit.
  9. May 16, 2024 at 4:56 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    The OEM plug is an H11 female plug.
    That adapter has an H11 male plug that should plug right into it..
    I have had 3 different Rigid fog lights and now have Rigid LED pods..
    rjz07cg4_zpsh5yoyzge_54ccb1cddfdae34f1038c2105abcdd7da2e0f47c.png vye6ix6v_zps1xm0ffid_dff50e2fc975337da564912e210d094cb4768f9f.png
  10. May 16, 2024 at 7:13 PM
    I have the plug and play splitters from Ijdmtoy on Amazon. I have been using them for 4 years now with out any issues. I run 4 Rigid SAE pods as fogs on my 2020.
    1lowlife likes this.
  11. May 16, 2024 at 7:58 PM
    TexMedic
    Just ordered everything. Will be here Monday. Let’s see how this goes.
  12. May 19, 2024 at 8:16 PM
    TexMedic
    That wire combo worked perfectly. Thanks for chiming in guys.
    - Tex
    Tundra234 likes this.
  13. Nov 16, 2024 at 8:55 PM
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    Does anyone know what adapter can make a bd sae plug and play to an 06 tundra fog plug? Having a hard time finding something that looks like it'll work for some reason.
  14. Nov 18, 2024 at 4:51 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Looks like an H11 too. Baja Designs are delphi connectors so you need an H11 to Delphi.
