  1. May 16, 2024 at 12:07 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Ugh... too much.
    It was $1,295 total.
    The "Wet Look" sealer I use is about $400 for the 6 gallons it takes to do my patio.
    The guy I used before charged me like $350 and I'd buy the sealer, but he was a flake and would sometimes no show/reschedule. He'd just pressure wash with water only and a wand, this guy used a good degreaser and a serious truck mounted pressure washer connected to the surface sleaner/scrubber thing you push around.
    The other guy sprayed it on only, this guy sprayed and then rolled it in, seemed to soak it into the concrete deeper.
    We had let it for too long, so I paid to have this guy do a really good professional job, and now the plan is that I'll keep up on it and do it myself.
    AZTundra[QUOTED] likes this.
  2. May 16, 2024 at 3:30 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    If you end up going (scortched earth) with muriatic be careful to pick a day with at least some light wind and place yourself UP wind. If you get a snoot full of that vapor it will take your breath away.
    Hard to tell from pictures bit is that top beach ball or basketball sized? Looks like a behemoth to move. Very cool fountain! Do you get avian/bird traffic on it?
    coTony[QUOTED] likes this.
  3. May 16, 2024 at 6:13 AM
    Florida AF
    Logan
    North Florida
    Direct quote when I fact checked my answer, "We went with the El lowes variety."
    Aka, not sure. bought them from lowes because the tractor supply options didnt take.
  4. May 16, 2024 at 6:46 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Living where I do, it never ceases to amaze me when people plant blackberries o_O
  5. May 16, 2024 at 7:16 AM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the info. We also need a good professional cleaning and resealing. This will at least give me an idea of what to expect. :thumbsup:
    SD Surfer[QUOTED] likes this.
  6. May 16, 2024 at 7:30 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    Yes... Sink head just enough to cover with caulk but not show a bump from the caulk
    Moon Puppy[QUOTED] likes this.
  7. May 16, 2024 at 7:44 AM
    NWPirate
    Zach
    WA
    I thought the same thing :laugh: The best growing weed there is
  8. May 16, 2024 at 7:52 AM
    SD Surfer
    Bruce
    So Cal
    Given that he was only there a couple hours on Friday to clean, and 2-3 hours Saturday to seal, he made $100+/hr.
    I didn't like paying that much, but I did like not having to do it, and he did a much better job than I would've soooo...
    We bought this house in '08 as a TOTAL fixer-upper (translation = shithole) and with all the blood and sweat I put in over the years sometimes I am just not nearly as motivated to DIY as I used to be.
  9. May 16, 2024 at 8:07 AM
    SD Surfer
    Bruce
    So Cal
    I think with some possible exceptions, most carved stone water water features are made from Marble, Basalt, and occasionally Granite.
    Marble is pretty soft and would likely be the most vulnerable to damage from acids and chemicals.
    That could be GFRC (glass fiber reinforced concrete) That's what these are.
  10. May 16, 2024 at 8:31 AM
    coTony
    Tony
    Montrose, CO
    It is 18” diameter ball on the top. It is not bad, Roll it on my shoulder and kneel down and put it on the ground. But that made it a bitch to lift. I put it on a temp stand I use in the yard now so I do not have to wrestle with it on the ground.
    Every morning when I was running it the hummingbirds would take a bath on the top of the ball. All of the birds use it as a bath and watering hole. Once I get it going again I can show a picture of it in use.
    Thanks for the heads up!
    BroHon[QUOTED] likes this.
  11. May 16, 2024 at 8:36 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    That's awesome, humming birds are such amazing little buzzers.
    OH, vinegar is a less toxic acid to try as well. Good luck.
  12. May 16, 2024 at 8:40 AM
    coTony
    Tony
    Montrose, CO
    The last one at the bottom that is 6’ tall looks EXACTLY like this and same color ball when it is wet. So I will start with CLR first since it is the least aggressive and work my way up I guess. I really do not want to damage it but starting inside the bottom tub is the most inconspicuous approach I would think
    TaquitoBandito and BroHon like this.
  13. May 16, 2024 at 8:51 AM
    coTony
    Tony
    Montrose, CO
    I am going to tackle this hopefully if I can find someone to take it apart for me since I still need help to pee…
    I have an important task to accomplish today. My Zulus NV scope with Range Finder comes in the mail today so I downloaded the user manual. A lot of reading and I need to get familiar with the Ballistic app
    Good times!!
  14. May 16, 2024 at 9:12 AM
    Florida AF
    Logan
    North Florida
    I agree with you. My hope is here before long I clear out some of the thick crap behind it and it eventually takes over that whole area as a weed. Fingers crossed. I will fight with blackberrys all day versus some of the crap down here. Plus I found a place that will buy them off me as they become harvestable.
    Trying to make a self sufficient, cash generating homestead. This was step two, following closely to the purchase of the property.
  15. May 16, 2024 at 9:25 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    Love this idea. The family is on a 5 year plan to move out to the country. The wife's dad has a nice plot of land and since he is getting up there in age has been asking us to move out there to help. We are going to start planting some fruit trees and have a well dug. Things like that to prepare for the house and shop to be built which will probably be the last year year and half before we make the move.
  16. May 16, 2024 at 9:29 AM
    Florida AF
    Logan
    North Florida
    Love everything about that! Best of luck!
    I currently have a full home and water system in place. Next year (if not earlier) will be my shop. We have found where we are purchasing fruit trees from, i just need the cash and time. Time is harder to come by right now. Eventually we will get livestock, but thats probably 3+ years out. I already named the property and am finishing up the logo. Lots to do, but lots to wait on too. I just want the fruit items in ASAP since they take a while to produce.
    BroHon and Damie Street[QUOTED] like this.
  17. May 16, 2024 at 10:15 AM
    Damie Street
    Edsel
    Great minds my friend. We want some live stock also and make the garden her dad has bigger to support everyone. I want a few dogs too. I envision watching the sun rise and set everyday.
    BroHon and Florida AF[QUOTED] like this.
  18. May 16, 2024 at 10:18 AM
    Florida AF
    Logan
    North Florida
    One of my favorite photos so far.... (AKA, get there bud!)
  19. May 16, 2024 at 11:36 AM
    SD Surfer
    Bruce
    So Cal
    I can't be the only one who pictured Atlas when reading that. :rofl:
  20. May 16, 2024 at 11:45 AM
    coTony
    Tony
    Montrose, CO
    Did not think of that but when I seen it LMFAO!!
  21. May 16, 2024 at 1:13 PM
    SD Surfer
    Bruce
    So Cal
    Took me a minute to find a pic of Atlas where he wasn't full Monty! :eek2:
  22. May 16, 2024 at 2:25 PM
    We have brambles all over my neighborhood. I could probably pick a couple quarts of blueberries walking the dog tonight. However, the new varieties like Kiowa are thornless, just as hardy/spreading, and the fruits can be as large as an egg, sweet as pie. They'll definitely grow in FL, when we were stationed at NAS JAX, we had a couple of stands in our neighborhood vacant lots, and my brother and I would pick buckets full, my aunt would make all kinds of stuff for us with them.
    Some really interesting thornless varieties are out there. Kiowa, Navajo, Arapaho, Natchez, etc.
    Bold text - that's a keeper. It's so impossible to find these days, and it's why I refuse to hire out work anymore!!
    Been working on ours a little more than 15 years, at least for the landscape part. If you ever want to compare notes....
    I will say, keg tubs are your friends when it comes to herbs that like to run, mint, oregano, etc. Good way to keep it contained, with easy reseeding.
    Lots of fruits and herbs easy to grow. Most recent I put in was a Bay Laurel, so we'd have an endless supply of bay leaves for cooking.
    Blueberries and blackberries have been the biggest no-brainers IME. Stone fruits are a bitch to keep pest-free, pears are easier. You're lucky you can get away with citrus in your zone! Get a meyer lemon in the ground STAT! And some satsumas!
    I'd probably kill every squirrel on the planet if I could.
    Florida AF[QUOTED] likes this.
  23. May 18, 2024 at 2:41 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Got done painting trim, casing, and walls last weekend. Starting on the floors.
  24. May 18, 2024 at 4:05 PM
    Damie Street
    Edsel
    Tile?
  25. May 18, 2024 at 4:10 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Please don’t say you’re putting down vinyl.
  26. May 18, 2024 at 5:01 PM
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    I was thinking MAYBE CLR, I would obviously test a small area first, but might be worth a shot if the bottle doesn't say not to use it on stone.
  27. May 18, 2024 at 5:04 PM
    FISHN43
    FISHN43 New Member
    Ohio
    Yup. High end vinyl plank. I put down the old Pergo about 20 years ago in our old house. We sold it last year and that stuff still looked almost new. This vinyl should be even more durable than that.
    NewImprovedRon and NWPirate like this.
  28. May 18, 2024 at 5:10 PM
    trucksareforgirls2
    Northeast USA
    Agreed, hummers are the best!! I got a window hummingbird feeder a couple years ago, and honestly the best 15 dollars I ever spent, it's so cool seeing then so close up! They also buzz me when I am on the deck if it needs a refill or freshening up!
    -T
  29. May 18, 2024 at 5:50 PM
    Florida AF
    Logan
    North Florida
    Bought a couch today... WTF, why are they so much more expensive these days. I wont go in to details, but... fuck...
    I am excited about it though. So now we wait 6-8 weeks.
    Blufin, NWPirate and T-Rex266 like this.
  30. May 18, 2024 at 7:17 PM
    Everything is more expensive, because everyone selling/leasing stuff is using algorithms to set pricing rather than relying on market/demand to set the price. The practice started a couple years ago, and I think you're going to see a federal case on it soon with regards to rent fixing in the housing sector, some markets are actually colluding to price-fix using RealPage (link, gist). Make matters worse, AI is being leveraged now to come up with clever ways to eek money out, find loopholes in stuff, it's a mess. It's only going to get worse. People will find whatever scapegoat they want to blame, but this is technology, interconnected, thinking/calculating for us (against us), this is the future.
    I try to buy used where I can. There's no joy in buying anything new anymore. We also had to buy a couch a couple years ago. Managed to get damn near the exact same couch we bought for $2,200 16 years ago for around $3,200. I wasn't pissed.
    Florida AF likes this.
