Fuel Tank Issue?
Discussion in '1st Gen Tundras (2000-2006)' started by GonePlaid, May 15, 2024.
  1. May 15, 2024 at 4:14 PM
    GonePlaid
    GonePlaid [OP] New Member
    Noticed a pretty significant fuel leak. After trying to get pictures of the top of the tank I noticed this perfectly round hole. Hard to tell if its threaded. Is there a drain hole/plug or any other type of plug supposed to be here/there? Thanks!
  2. May 15, 2024 at 4:16 PM
    Dunno what year or cab type you got but I don't have a hole there.
    Plug it and see if your EVAP code/leak disappears. And if you give us more truck info, we can tell you if your truck is potentially ripe for the filler neck leak.
    Just looking at it, that hole looks way cleaner and newer than the rest of everything in the pic, so I'm thinking there was something plugging it, or someone drilled it to help drain the tank.
  3. May 15, 2024 at 4:17 PM
    I also notice your fuel tank strap bolts look way newer than other bolts, suggesting someone replaced the straps, and/or their hardware since other bolts have been removed.
    Looks almost like the frame has the OEM Toyota rust coating on it too, which may not be a good sign.
  4. May 15, 2024 at 4:19 PM
    GonePlaid
    Thanks for the quick reply. 2006 Gen 1, double cab. It was sitting at a lot at the airport for a bit, it's a clean hole. No codes and still had half a tank of gas. Can't remember what I parked with, definitely not full.
  5. May 15, 2024 at 4:21 PM
    GonePlaid
    I've had the truck for around four years with little issue. Bought at auction so no known history. Live in a snowy then warm climate too.
  6. May 15, 2024 at 4:21 PM
    I'd plug it. It looks far too in-and-clean to be a bullet entry. But leaving it at the airport ... could've been drilled. Hole looks nicely deburred though.
    I've got an '06 Access Cab, and I'm gonna go look again, but I didn't see a hole in that spot on my tank.
  7. May 15, 2024 at 4:22 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Trying to replicate your angles there, no hole in mine either or plug
  8. May 15, 2024 at 4:23 PM
    GonePlaid
    It was initially covered by the plastic guarded wire that can be seen in the pics.
  9. May 15, 2024 at 4:24 PM
  10. May 15, 2024 at 4:24 PM
    GonePlaid
    Thank you! Yours looks much cleaner. I'll try to plug it and see. Is there a good putty or resin for a gas tank?
  11. May 15, 2024 at 4:30 PM
    I'd rubber plug it, honestly. I'm surprised you're not tossing an EVAP code for (at least) 'minor leak' or 'small leak'.
    I tried to include that horizontal line in mine that points at the hole on yours. But DC and AC (double cab/access cab) may not share the exact same tank. Not sure. Definitely no hole. The tank needs to be sealed, the gas cap is responsible to release pressure.
    If I had to guess, someone probably drilled the tank halfway up to see if it leaked out. If it did, they'd know it's at least half-full, and I suspect they were going to drill another hole in the bottom and drain it. It's what crackheads do...
    They may have drilled the hole and used that to quietly siphon off a few gallons too.
  12. May 15, 2024 at 4:30 PM
    image.jpg Double(best)cab 06
    No hole
    noahrexion and shifty` like this.
  13. May 15, 2024 at 4:32 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  14. May 15, 2024 at 4:33 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Paging @KNABORES
  15. May 15, 2024 at 5:00 PM
    GonePlaid
    You have to be right. Hole looks fresh, no reason to be there. Crack isn't for everyone. Thanks again!
  16. May 15, 2024 at 5:02 PM
  17. May 15, 2024 at 8:33 PM
  18. May 15, 2024 at 8:47 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Brutal, but coulda been worse.
    I’d find a SS bolt that just fits/cuts some threads in and put it in with a bit of Seal-All.
    Can anyone think of a reason not to do that? I guess some of the thread cutting could go in the tank, but I would think there’s already plenty in there from the drilling.
  19. May 15, 2024 at 8:52 PM
    GonePlaid
    Found a close-ish bolt with a rubber washer and siliconed it. Should hopefully get me to town to get some fuel tank JB weld.
    shifty` likes this.
  20. May 16, 2024 at 2:11 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Looks like that hole is in the tank itself. Your tank is made of plastic, so maybe find a rubber or plastic plug that fits snugly
    shifty` likes this.
  21. May 16, 2024 at 7:36 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Looks like someone may have drilled it to help drain your tank, and then got interrupted and stopped before drilling a 2nd hole.
  22. May 16, 2024 at 7:53 AM
    Honestly, this is probably a perfectly-fine permanent repair if the depth of the fastener is not much more than the tank. I would've used FIPG myself, but ... Sealed is sealed, and a fastener shouldn't back out. I'd trust it more than JBweld for a plastic tank!
  23. May 16, 2024 at 8:14 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    I'm surprised nobody has mentioned this. I would be worried about potential foreign matter in the bottom of the tank. Like water, dirt, plastic from drilling, etc. Sure doesn't seem like just plugging it up and walking away is the answer.
  24. May 16, 2024 at 8:30 AM
    Natural tendency is for the swirls of plastic to come up in the bit.
    If you look closely in the picture, and this is why I originally thought it was drilled, and this supports your theory "they didn't finish", you can actually see the lip where the drill bit breached the tank, but didn't make it all the way into the tank. This would suggest there's little of no plastic in the tank. But the fuel pump has a screen on it, so it'd catch the tiniest bits. This is what I'm talking about, notice how the lighter plastic ring seems angled inward here, like the face of a drill bit. I don't think they made it all the way into the tank.
  25. May 16, 2024 at 8:42 AM
    ATBAV8
    Tempe, AZ
    I don't know. This picture would indicate otherwise. Seems it did make it all the way into the tank. And the staining around the hole would indicate the sloshing and evaporation of gas on the outside of the tank, which would support a full breach. I agree that the swirls of plastic on the initial part of drilling would go up, but once the inside is penetrated, there is going to be stuff that drops off the end of the bit. I guess, all this to say, if it were mine, I'd be draining and dropping the tank to inspect and repair properly. Maybe this is my aircraft brain thinking that (clean) fuel is life.
  26. May 16, 2024 at 10:15 AM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    I wouldn't be worried about that. Anything coming from the bit when drilling plastic is gonna be way larger than the filter sock mesh in the tank.
    shifty` likes this.
  27. May 16, 2024 at 10:39 PM
    GonePlaid
    They definitely made it through. That's how I discovered it, while filling at the gas station. Found some rubber plugs and a few coats of Seal-all seems to be holding so far. First time using Sealall, much more liquidy than I expected. Wanted to find a sealant that's ok around gas. Didn't find a JB that fit that description with a poly tank. Brutal since I don't have a locking gas cap. Youtube how to syphon for Fs sake. Thanks again for all your replies and advice.
