  1. May 15, 2024 at 7:02 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Thanks to a good ole Texas Aggie on here, I have a second fog light switch :D. I cannibalized the switch that came with the AuxBeams and wired the white bright lights into that second fog light switch. I also tapped into the marker light circuit to power the amber DRL lights on the pods. Supper happy with this :cool:.
    https://youtu.be/q6TCMBke1D4?si=4b9Rn0ZOtFcooTp0
    upload_2024-5-15_9-1-27.jpgupload_2024-5-15_9-1-27.jpgupload_2024-5-15_9-1-27.jpgupload_2024-5-15_9-1-27.jpgupload_2024-5-15_9-1-27.jpg
  2. May 15, 2024 at 7:08 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Ooh, me so jelly...
    The Black Mamba likes this.
  3. May 15, 2024 at 7:37 AM
    What they said ^^
    Only thing I can add is this. If you really want to test/verify before you cut/solder/shrink, get some Posi-taps. They'll let you cleanly tap into the wires you intend to use with a simple pinhole to pierce the sheath of each wire. When you remove the tap, simply paint over the tiny pinhole with GB liquid electric tape, and you'll never have a problem with water/moisture intrusion. It absolutely won't cut/fracture wires like typical scotchlok/t-tap connectors will do.
  4. May 15, 2024 at 7:42 AM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    @03Limited
    Yes! I forgot to add this little nugget of advice as well. I just learned of their existence from @shifty` and have a few packs on order.
    https://www.crutchfield.com/S-VdDxS...MIq7qHrPGPhgMVyh-tBh1phQ98EAQYASABEgLFVvD_BwE
    ToyotaDude and The Black Mamba like this.
  5. May 15, 2024 at 7:46 AM
  6. May 15, 2024 at 10:16 AM
    metalpete
    ID
    Anyone have a source or a general direction to purchase KO blanks for our dash? I used the small square to the left of the steering wheel for my remote, and marked it up quite a bit.
  7. May 15, 2024 at 10:29 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Are you asking about the square circled on the right?
    metalpete[QUOTED] likes this.
  8. May 15, 2024 at 10:29 AM
    metalpete
    ID
    Correct!!
  9. May 15, 2024 at 10:30 AM
    The Black Mamba
    DFW
    Imma keep it stock
    I have a spare one at home I'll send you. Unsure on color. I can take a pic when I get to the house. PM me your addy.
  10. May 15, 2024 at 11:09 AM
    metalpete
    ID
    My brother! I really appreciate that, but (shockingly) the dealership has the oak colored pc for $10. I appreciate the gesture, my friend.
    55539-06010-E0 - the E is for the oak color, but this is how the part # starts.
  11. May 15, 2024 at 11:15 AM
    The Black Mamba
    DFW
    Imma keep it stock
    That's even better because I do know that the one I have is NOT oak.
  12. May 15, 2024 at 11:19 AM
    You have to be careful with plastics at this point. Toyota has been defaulting to oak on everything these days.
  13. May 15, 2024 at 11:22 AM
    The Black Mamba
    DFW
    Imma keep it stock
    So keep some gold spray paint around? :rofl:
    bmf4069, BroHon, oscardog86 and 3 others like this.
  14. May 15, 2024 at 11:39 AM
    metalpete
    ID
    Well it's a damn good thing my interior is oak!
    Hell yeah. I have the duplicolor touch up pen for the exterior, just need to find the interior one. Pretty sure Toyota calls it "Beige".
    KNABORES likes this.
  15. May 15, 2024 at 3:41 PM
    Chrisfrom1986
    Chrisfrom1986 New Member
    Central CA
    06 AC SR5
    Yeah I wanted to get the axle installed before I bought spacers. I think I'm still going to need 1" on all 4 corners.
    No thanks, it's a semi daily driver so can't take the chance of the ass end kicking out on the gf if it ever rains. I'll patiently wait for an lsd to hit the junkyard.
    New gas cap solved some evap codes I had that was preventing the evap monitor to set and a new air filter went in as well. Passed smog and ready for an oil change tomorrow once it hits 165k.
    Needs that lowering kit installed asap.
  16. May 15, 2024 at 3:41 PM
    The Black Mamba
    DFW
    Imma keep it stock
    I inadvertently lied to you. Turns out I don’t have one at all :anonymous:
  17. May 15, 2024 at 3:53 PM
    Rolled over to 271k miles. Slooooowly creeping towards the million. Should hit it around 2315AD.
  18. May 15, 2024 at 4:20 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Got my Rockauto order, now just gotta install- all 4 02sensors, platinum plugs, air filter, got the new steering shaft seal on hand too.
    Too much timing using the truck, not enough time working on it.
    Got a load of slate today for a new patio, I was told it’s approximately 450sqft, I felt like this was a full enough load and have about a beds worth left to pick up this weekend.
    Also gave it a quick wash yesterday:)
    NUDRAT, oscardog86, bmf4069 and 3 others like this.
  19. May 15, 2024 at 4:58 PM
    metalpete
    ID
    Curses! And it was oak after all!
    oscardog86 likes this.
  20. May 15, 2024 at 5:20 PM
    The Black Mamba
    DFW
    Imma keep it stock
    No, I knew the oak didn’t have one. I was certain the charcoal had one
  21. May 15, 2024 at 5:26 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Doesn't really count since it's a first gen Tacoma, but I decided to make it a little easier to sell and replaced the belts today. Will also replace a CV axle. That's about all I'm willing to do. But way too old belts and a torn CV boot aren't good selling points.
    NUDRAT, oscardog86, bmf4069 and 4 others like this.
  22. May 15, 2024 at 5:31 PM
    I want one in this condition that's manual, 2WD, 4cyl, power windows, good frame.
    TXTundraGuy23 likes this.
  23. May 15, 2024 at 5:36 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Where you located?
    I always wanted a cool steel/lavender steel metallic Tacoma.
    Or is that horizon blue metallic?
    Those colors can be hard to identify in pics because they are similar and both change some in different lighting.
  24. May 15, 2024 at 5:38 PM
    MT-Tundra
    Montana
    Just take out the t-case and front diff and there you go! :D
    I'm in Montana. The color in this light was good. In some light, it's weathered into what some like to argue is purple. Or I guess lavender as you wrote.
    oscardog86 and shifty`[QUOTED] like this.
  25. May 15, 2024 at 5:40 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I also have terrible ideas.
  26. May 15, 2024 at 5:49 PM
    MT-Tundra
    Montana
    It's not perfect, but there's no rot. And I'm not sure what happened to the body under the passenger side door. Was like that when I bought it, and at the time was the only body rust. Now it has a couple rock chips etc with little rust spots. Good friend bought it brand new when I knew him in college. Sold to another friend of mine at 120,000 miles. I bought it from that friend at 189,000.
    I know how much we all love frame photos.
    IMG_6244.jpg IMG_6243.jpg IMG_6242.jpg IMG_6241.jpg IMG_6240.jpg IMG_6239.jpg IMG_6238.jpg IMG_6237.jpg IMG_6236.jpg
  27. May 15, 2024 at 6:13 PM
    The Black Mamba
    DFW
    Imma keep it stock
    bmf4069 and AmericanKing06 like this.
  28. May 15, 2024 at 6:18 PM
    MT-Tundra
    Montana
    Aaahhhhh.
    I had an 83. Even found an earlier model to swap grills & headlights so I could get round headlights. Don't have my photos handy unfortunately. Those were the best looking trucks Toyota ever built.
    txagg and oscardog86 like this.
  29. May 15, 2024 at 6:21 PM
    MT-Tundra
    Montana
    Looking at my photos, I realize how much corrosion has happened just in the last few year. They started using more corrosive road treatments a few years back. Too bad.
    Everything about my Tacoma is 'well used, not abused, maintained, but certainly not immaculate'.
  30. May 16, 2024 at 3:04 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Partially joking, but how much for one of those dimmer controls from your parts hoard?:D
    Mine was busted off, most likely from someone's knee... in the accident. I was able to drill a tiny hole in the shaft and screw on a knob, redneck style :rofl:
    455h0le_dachshund likes this.
