Where to find deck rail bolts?
Discussion in '2.5 Gen Tundras (2014-2021)' started by goffredo, Mar 23, 2020.
  1. Mar 23, 2020 at 7:15 PM
    goffredo
    goffredo [OP] Grease Nipple
    Lake Tahoe, California
    2018 Tundra Limited Double Cab Magnetic Gray
    Looks like the LineX guy took my 3 deck rails off, and managed to lose one of the mounting bolts without telling me.
    Dude at Toyota dealership said I needed part number 90148-A0006. There isn't much info on this part (no picture, no length, no description) on the online Toyota parts catalogs, so I took a gamble and ordered the one the dealership dude said (on ebay). The bolt I received is too long, and does not have a step-down taper on the end.
    So back to the drawing board. Does someone have better part-foo than I do, and can help me with the part number?
    Here's the screw I'm talking about:
    The screw I need is on the left. The alleged "90148-A00006" from random ebay dude is on the right (anybody want it for free?)
    Thanks guys!
    Paulsn likes this.
  2. Mar 23, 2020 at 7:32 PM
    biebs96
    PA
    Message me..
  3. Mar 23, 2020 at 9:19 PM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    Exactly the same thing happened to me. The Toyota dealer is NOT capable in offering any help.
  4. Mar 23, 2020 at 9:32 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I just used hex head bolts for mine I got them second hand no hardware
    TXTundra2722 likes this.
  5. Mar 23, 2020 at 10:03 PM
    TXTundra2722
    2015 Black Tundra
    True... this is a super easy fix.... take one with you to lowes and you can easily get a replacement/another
    831Tun likes this.
  6. Mar 24, 2020 at 6:51 AM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    Should be a 90148-A0012.. The 90148-A0006 shows to be for a Tacoma
    goffredo[OP], 831Tun and Bob_Wiley like this.
  7. Mar 24, 2020 at 8:29 AM
    meackerman
    meackerman New Member
    Mark
    2020 SR5 DCLB
    when the port sprayed in my bedliner, they didn't remove the rails. Installing my bakflip last night, have to move the rails down, and I now have a white ring around the top of my bed....
  8. Mar 24, 2020 at 9:08 AM
    multimile
    multimile New Member
    2020 Crewmax Cement
    That's annoying, wonder if that's standard for port sprayed liners. I guess I'll check mine sometime since we're on lockdown.
  9. Mar 24, 2020 at 10:32 AM
    goffredo
    The frustrating part was that I had to stand there for like 10 minutes while he poked around on his computer trying to find the part diagram. And then he found the wrong one! Especially because I have a obsessive attention to detail, It's astonishing how incompetent people can be. This dude has been behind the parts counter there for years.
    That would certainly work, but I wanted the OEM bolt, because I have a 500 pound camper shell that clamps to the deck rails. Turns out the OEM bolt is pretty trick, what with its fancy end taper, not sure why but didn't want to risk anything failing prematurely. Plus I hate having to switch bits halfway through removing something because of a mismatched replacement bolt (I doubt I could easily find a matching bolt in Torx 30 at a box store).
  10. Mar 24, 2020 at 10:33 AM
    goffredo
    Gosh I guess I'd prefer them losing a bolt to not bothering to take the rails off ... like, what other shortcuts did you take dude?
  11. Mar 24, 2020 at 10:33 AM
    goffredo
    You da man!
  12. Mar 24, 2020 at 1:16 PM
    meackerman
    Mark
    2020 SR5 DCLB
    dunno if its normal (seems strange to me), but they sprayed two of the bed tie down loops and didn't spray the other two. So I have two black and two white...
  13. Sep 8, 2021 at 4:09 PM
    Motobed
    Motobed New Member
    cody
    2008 tundra grey sr5 trd offroad
    Any one know the size and thread of the tappered part? Looking to use these for mounting points .
  14. Sep 8, 2021 at 4:57 PM
    biebs96
    PA
    how do you need? I have some.
    1lowlife likes this.
  15. Jun 6, 2022 at 1:48 PM
    Paulsn
    Paulsn New Member
    Paul
    2015 CrewCab 4x4 Tundy TRD-OffRoad
    Decked 2 drawer bed system, custom bed load track system (mcmaster.com, Rail pn:39695T32, Rings pn:39695T36, BedRail bolts pn:92703A167). added switches to override "motion" and activate rear camera on-demand. added 100A breaker protected line from battery to tow pkg, for jumpers/inverter/etc. more to come..
    same bolts in my 2015, look here.. https://www.mcmaster.com/94500A237/
    I think the taper is just to help you start the thread.
    m6x16mm buttonhead cap screw. I did stainless replacements so they don't rust.
    tdwesbo and Drainbung like this.
  16. May 14, 2024 at 9:49 AM
    2010SR5NIC
    2010SR5NIC New Member
    2010 Salsa red pearl DC
    Dobinson lift front and rear, SPC UCA’S, icon add a leaf, coach builder shackles, 18x8 method wheels with 295/75 falken wildpeaks.
    how many do you have? I need 18
  17. May 15, 2024 at 9:22 AM
    General Snafu
    General Snafu New Member
    Real simple solution: Try your local Boneyard. Or, go to a Toyota dealer's lot and find a truck like yours sitting on the lot and uh, . . . . . you know what to do. You certainly don't need me to tell you.
    Drainbung likes this.
