Spotify on Factory USB/Aux
Discussion in 'Audio & Video' started by rphass17, May 13, 2024.
  1. May 13, 2024 at 1:56 PM
    rphass17
    rphass17 [OP] New Member
    I can only listen to spotify as long as my truck is not plugged in to the usb port. When connected to the usb port it says "music not found".
    I don't have the apple music app on my phone at all. Is there a way to play spotify while it is connected to the USB?
  2. May 14, 2024 at 9:04 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    Just a WAG here, but it sounds like the USB is trying to read but not finding "Data", and by having it plugged in the USB is superseding the bluetooth.
    Do you have it plugged into the USB just to charge your phone or for other reasons?
    I play spotify via BT but I charge my phone with the port in my center console.
    If only to charge, you could get a "Charge Only" cable.
