Jumper cables hooked up backwards... got issues
Discussion in '2nd Gen Tundras (2007-2013)' started by Tvexcavating, May 13, 2024.
  1. May 13, 2024 at 8:24 PM
    Tvexcavating
    Tvexcavating [OP] New Member
    Talon
    2007 toyota tundra 5.7
    370,000 km .Truck had a dead battery after sitting about 3 weeks. When the horn started blaring u realized my error. After charging properly, truck would turn on, and starter turns, but motor wouldn't fire. I went through the fuses and replaced several blown related to fuel systems. Now the truck will start while hooked up to jumpers, but will die in a few minutes after running. Battery voltage shows 12v or less while running. Also, while running I have no radio, no headlights, no climate ctrl, obd scanner does not activate when plugged in, check engine light on. I swapped a healthy battery from my other truck and it did not fix the issues. So yeah I've got issues, I suspect alternator might be busted. I'm just hoping for some help and ideas posting on here. I've had this truck a long time, I hope it's not the violent electrical shock that breaks the camels back...
    OldGuy03 and FrenchToasty like this.
  2. May 13, 2024 at 8:33 PM
    Oof. Could be the ecu
    texasrho83, OldGuy03 and ColoradoTJ like this.
  3. May 13, 2024 at 8:34 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    There are main fuses under the underhood fuse box that supply power to other fuses..
    The first thing I would do is to check them, I'd bet you blew at least one of them..
    There are a few YouTube on it..
    Good luck...
    OldGuy03, T-Rex266, SR5BART and 3 others like this.
  4. May 14, 2024 at 4:17 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    THIS ^^^^.
  5. May 14, 2024 at 4:35 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Good luck!
  6. May 14, 2024 at 6:36 AM
    Florida AF
    Logan
    North Florida
    Welcome from North Florida! Good information above, let us know what you find and good luck!
  7. May 14, 2024 at 7:42 PM
    Tvexcavating
    Talon
    I pulled out the main fuse and found one of the links was broken. I have ordered a new one and will update again when it is in... fingers crossed the issues stop here. Thanks for the help!
  8. May 14, 2024 at 8:34 PM
    Becmat
    Becmat New Member
    2024 Silver Tundra
    I had a similar issue with my wife's 2005 Sienna. As a temporary fix I was able to swap it out with another fuse, I think it was the horn, but not 100% sure
  9. May 14, 2024 at 8:35 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    He blew a main fuse, not a small blade fuse.
    Cruiserpilot likes this.
  10. May 15, 2024 at 6:25 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Probably that main fuse will help a lot but will need to figure out if he blew that ground OBD2 wire. He may need to look up info on that part.
  11. May 15, 2024 at 12:28 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    2007 RCSB 2014+ TRD Pro Conversion 5.7 4x4
    Full 2014+ Conversion Regular Cab Short Bed 4X4 2019 TRD Pro Grill, 2014+ Front End Swap 2014+ Interior/Dash Swap with TRD Pro Leather Seats, 2014+ Bed Swap with TRD Pro Stamping SOS 2/4 Drop Kit
    Defiantly a main fuse, seen it several times. Hooking the battery up backwards is almost a guaranteed time to take the fuse box apart and replace the main fuse scenario.
    I suspect with a good main fuse all your interior systems will be properly powered which means the "Key On" signal to enable the voltage regulator in the alternator will start working again and it actually be charging the battery. Hoping this fixes all of your issues.
  12. May 15, 2024 at 12:35 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Hope it's the main fuse but it very well could be a fried ECU
