Lift Suggestions / Wheels
Discussion in 'Suspension' started by edbmon1, May 12, 2024.
  1. May 12, 2024 at 4:38 AM
    edbmon1
    edbmon1 [OP] New Member
    2023 Tundra 1974 3.4
    2023 1974 3.4 (non-Hybrid)
    New to Tundra. Had a Tacoma a long time ago. Recovering F-150 owner. So glad that is out of my life.
    My objective is to have the Tundra 2-3 inches higher.
    I want to keep the TRD Stock 20" rims.
    Currently has 265/60R tires. I'd prefer to keep them since they're brand new, and trying to save a few bucks, if possible.
    1) Do you think it'll look "bad" if I just keep the Rims / Tires and lift by 2-3 inches?
    2) Do you think I should just get wider tires to 'raise it up 2 inches'
    3) Do I need to just get a 2 inch lift and new, wider tires?
    Thanks for your suggestions.
  2. May 12, 2024 at 4:50 AM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    Welcome.
    2-3” with stock tires looks like you skipped leg day at the gym. Too small.
    If you want to run stock tires I’d go 1” level up front. Simple and cheap and when you are ready for bigger tires step up the lift.
    jhtram and edbmon1[OP] like this.
  3. May 13, 2024 at 9:33 AM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    33's will fit stock susp. and wheels (trd susp) no rubbing/ 35's stock susp and wheels will rub minimally/ 35's trd lift will have no issues/ as mentioned earlier it'll look like you skipped leg day if you run stock tire size with a 2-3" lift/
    personally I like bronze wheels if your truck is black, blacked out is the fad for the past 5 years (I like to be unique but complement colors accordingly) so polished alum or chrome wheels (hate coated chrome) with any body color will always go well.. pick your poison, be unique or blend in
  4. May 13, 2024 at 9:35 AM
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    My setup is a 3.5" lift w/ 33's but -24 offset so it has some stance and didn't skip leg day but should work more on leg day
