Loud bang
Discussion in '1st Gen Tundras (2000-2006)' started by oldgoldy, May 2, 2024.
  1. May 2, 2024 at 10:29 PM
    oldgoldy
    oldgoldy [OP] Why did I have to choose trucks
    2006 tundra v8 gold
    2.5in bilstien 5100 level kit, Black Rihno chamber 17x8.5 wrapped in 275/70/r17 ko2s. Interior led lights.
    Hey guys, I’ve got a weird question but when I turn my truck off and sit in it for a few minutes there’s this loud bang the comes from the engine bay, does it very 5–10 minutes. Walked out to my truck this afternoon (it was sitting for probably 2 hours) and I heard the bang again. And ideas for the problem would be awesome thanks!
  2. May 2, 2024 at 10:42 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    A loud bang, huh? Sounds like your engine is shot. :rimshot:
    Seriously though, that sounds freaking weird. How loud of a bang are we talking here? 12ga? (I doubt it). A clunk like the starter is trying to engage?
  3. May 2, 2024 at 10:43 PM
    oldgoldy
    2006 tundra v8 gold
    it starts off loud then gets quieter, I’ve heard that it could be my cats but not sure.
  4. May 2, 2024 at 11:01 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    My papaw's old 2000 cheby 1500 would pop as the exhaust would cool down over time
    I have NEVER seen the stock exhaust on a V8 tundra so I don't know what it's supposed to do.
    Post up some pics so we can see what you see!
  5. May 3, 2024 at 6:13 AM
    Ok, I'll ask the obvious first:
    Any codes at all?
    Have you modified the engine in any way, intake/exhaust, or anything else on the engine to adjust functionality like a SAIP bypass or programming?
  6. May 3, 2024 at 6:27 AM
    2mchfun
    Have you tried to open the hood and observe?
  7. May 3, 2024 at 6:36 AM
    "A watched pot never boils" :rofl:
  8. May 3, 2024 at 6:41 AM
    oldgoldy
    2006 tundra v8 gold
    No codes and everything with the engine/exhaust is bike stock.
  9. May 3, 2024 at 6:44 AM
    How many miles?
    Have you ever done timing belt?
    Have you replaced any worn parts intake/exhaust parts like cats, had the intake manifold off, exhaust manifolds off, replaced the plugs, replaced coil packs, replaced anything?
    How do the plugs look?
  10. May 3, 2024 at 6:49 AM
    2mchfun
    Does it bang while driving?
  11. May 3, 2024 at 6:58 AM
  12. May 3, 2024 at 7:20 AM
    oldgoldy
    2006 tundra v8 gold
    It’s got 182,000, timing belt was done about 15,000 miles ago, don’t think anything else have been done.
  13. May 3, 2024 at 7:21 AM
    oldgoldy
    2006 tundra v8 gold
    Nope, only after I turn it off, that’s why I was more leaning towards cats because it’s when the truck is cooling down.
    2mchfun[QUOTED] likes this.
  14. May 3, 2024 at 7:24 AM
    Describe the sound for us. Is it a loud explosion, like a backfire or firework? Or is it more of a pop, like a cork from a champagne bottle? Maybe more of a clang, like heavy metal on metal, like a monkeywrench tapping a framerail? Or more of a ping, like a marble hitting a body panel? You tell us.
    If I've been running my truck hard, it's not uncommon to hear pings as the engine cools down.
  15. May 3, 2024 at 7:25 AM
    2mchfun
    Maybe put an exhaust pressure guage on it to test for clogged cats. Pretty cheap DIY or muffler shop.
    oldgoldy[QUOTED][OP] likes this.
  16. May 3, 2024 at 7:53 AM
    oldgoldy
    2006 tundra v8 gold
    It’s like a monkey wrench hitting the frame rail, sometimes I can feel the larger ones in my feet.
  17. May 3, 2024 at 7:57 AM
    You got me. Throw a camera on it with the hood open so we can all hear what it sounds like. Something like what this guy did would suffice. Note the thud after turning it off, right between the 5s-6s mark.
  18. May 3, 2024 at 7:58 AM
    SD Surfer
    SD Surfer Globe Trotting Bon Vivant
    Bruce
    So Cal
    2019 SSM CM SR5 TRD OR 4X4 5.7
    That's weird...
    BroHon and shifty` like this.
  19. May 3, 2024 at 7:59 AM
    2mchfun
    Take the wrench away from your monkey or turn down your hearing aids!
    landphil likes this.
  20. May 3, 2024 at 8:00 AM
    Have you considered this may be happening because your truck is gold? Pucks' old lady is possibly living under your truck and smacking the framerail with a hammer periodically because she thinks gold looks terrible.
    Pnwtundy likes this.
  21. May 3, 2024 at 8:39 AM
    oldgoldy
    2006 tundra v8 gold
    Will do, I’ll take a video as the truck is cooling off from my drive home from work today.
    shifty`[QUOTED] and 2mchfun like this.
  22. May 3, 2024 at 8:59 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Could your exhaust shields be making noise as he are cooling down? Do they seem loose?
    Pnwtundy and shifty` like this.
  23. May 3, 2024 at 9:41 AM
    oldgoldy
    2006 tundra v8 gold
    Yeah the cat heat shields are loose but they rattle, they don’t bang
  24. May 3, 2024 at 10:10 AM
    Mine would make a loud bang when I started moving for the first time after it sat a while. It went away when I removed the sway bar.
  25. May 12, 2024 at 2:25 PM
    oldgoldy
    2006 tundra v8 gold
    Hey guys sorry for the late reply got caught up in school and work and forgot about it. I ended up figuring jt out, it was my cats. I took them gf did a usual drive and it didn’t make the noise so I’m all set. Thanks!
  26. Jun 1, 2024 at 5:39 AM
    kentuckyMarksman
    I can't stop thinking about this thread now... I've noticed my exhaust shield make a bang noise about 10 or 15 minutes after I turn my truck off. Hadn't noticed it on this truck till after I read this thread.
    Cars I've had in the past did it too. Perfectly normal
  27. Jun 1, 2024 at 8:22 AM
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    HOLY CRAP hes gotta TRUNK MONKEY
    2mchfun likes this.
