Hood Issues on 2021
Discussion in '2.5 Gen Tundras (2014-2021)' started by nmjameswilson, May 10, 2024.
  1. May 10, 2024 at 7:52 AM
    nmjameswilson
    nmjameswilson [OP] New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
    Has anyone had their front hood piece pop out when semi trucks pass? I had this happen immediately after I bought it and had it replaced. Now it is doing it again and the service department will not cover it with the extended Toyota warranty. The clips that hold it popped out and only one is still attached. I am guessing I am not the only one with this issue. I might just add bolts myself.
    I have the 2021 Nightshade model BTW
  2. May 10, 2024 at 7:53 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I've seen it happen on trucks with modified bulges to fit light bars, but personally haven't seen it on a normal truck. That said... I know you're not alone as I have seen a handful of Tundras in the world without hood bulges at all.
    nmjameswilson[OP] likes this.
  3. May 10, 2024 at 7:59 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It happens on normal trucks as well.
    I see it on the highway as I drive for a living.
    My 2014 did it.
    I tried replacing the clips but it kept popping out on the highway.
    It happened so much it broke one of the speednut mounts on the end of the bulge.
    I tried several glues and expoxies for that plastic mount but nothing held.
    I ended up ordering another hood bulge and it stopped popping up, for about 2 years.
    It still does it occasionally, mostly in automatic car washes, but not like it did..
  4. May 10, 2024 at 8:17 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    You can try replacing the clips and see how it goes.
    Hood & Components for 2014 Toyota Tundra | Sparks Parts
    75867-AA010 - Rocker Molding Clip - 2002-2023 Toyota | Sparks Parts
    I bought these, they worked for a few months.
    You may have better luck.
    Amazon.com: 15 Rocker Panel & Scuff Plate Clips Compatible with Lexus & Toyota : Automotive
    Be careful tightening the 3 bolts to reinstall it.
    Too tight and it will snap the speed nut mount.
    That is probably how I broke mine..
  5. May 10, 2024 at 8:22 AM
    nmjameswilson
    James
    Kansas City
    Thanks for the links ... I will stock up as these will be replaced a lot. LOL
    1lowlife[QUOTED] likes this.
  6. May 10, 2024 at 8:23 AM
    The earlier years of the 2.5 gens had the issue before Toyota went to an improved clip.
  7. May 10, 2024 at 8:25 AM
    nmjameswilson
    James
    Kansas City
    When did they go to the improved clip? My 2021 has the issue so maybe I can ask for one from a newer model?
  8. May 10, 2024 at 8:31 AM
    It was a couple of years ago. I would look at all of your mounting points on the back of the bulge...they can break very easily. When you look at it, you will see what I am talking about.
  9. May 10, 2024 at 2:31 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    2021 Sr5 here never seen that.
  10. May 10, 2024 at 2:51 PM
    HaveFun
    HaveFun Happy to be here
    Fair Oaks Ranch, Texas
    2019 Black Tundra CM SR5
    I have a 2019. Started to have to travel more. Surprised the heck out of me one day when I noticed it after coming out of the store. I thought someone had tried to steal it LOL. Then saw it happen when driving. Just as you said, when I passed a semi…
    1lowlife likes this.
  11. May 10, 2024 at 5:43 PM
    Bergy24
    Bergy24 New Member
    What was their excuse not to fix it under the extended warranty?
    BoyHowdy likes this.
  12. May 10, 2024 at 8:39 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    When mine first did it, I guess 2018, I thought the same thing..:eek2::cool:
    HaveFun[QUOTED] likes this.
  13. May 11, 2024 at 4:22 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    2015 Limited Crewmax
    Bilstein 6112/5160 Method 702 0 offet Toyo open country 285/75 17 Form led headlights OEM Toyota led fog lights Morimoto 3rd brake light Morimoto tail lights Amp Research power steps
    I’ve had problems with mine warping in one corner. If you take it off be gentle, the clips are brittle.
  14. May 11, 2024 at 4:31 AM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    I had a 2015 that I beat the hell out of and never had a single issue with that truck.
    Just bought a 2021 last year that I planned on babying, but got in a wreck and the whole front end had to be rebuilt.
    Now the bulge comes a little loose if you slam the hood too hard. But the bulge and grille are aftermarket. I assumed it was that.
    Never experienced or heard of this before on a stock truck.
    My guess would've been that it's an aftermarket piece, but I'm reading here that others have this issue?
  15. May 11, 2024 at 4:34 AM
    Oolypoolay
    Oolypoolay Meh
    Virginia
    I think it has something to do with the color matched stuff. The chrome one was way thicker. I was disappointed given the cost of OEM parts.
  16. May 11, 2024 at 5:13 AM
    Adamace1
    Adamace1 New Member
    None....
    I always read the fine print. I have never seen a extended warranty cover...
    Squeaks, rattles, light bulbs, brakes "All trim, molding, seals" any part considered a wear item, fit and finish. Plastic trim, rubber trim. Any other kind of trim. Seats, fabric, leather and any other type of seats, seat foam. Glasses, mirrors.wheel covers. Tires unless you buy an extra tire coverage... then most likely they still won't cover it. Body panes, paint. Taillights, headlight housing. Wiring. Rust damage. Rattles....water leaks...
    Also the covered parts are only covered if our employees want to let it be covered. We will inspect your vehicle to find any reason to not cover it. Then it will go through several of our employees who get paid a bonus if they find or make up a reason to not cover it.
    Giskk likes this.
  17. May 11, 2024 at 4:58 PM
    Bergy24
    Bergy24 New Member
    Sounds like you’re a Toyota Employee.
  18. May 11, 2024 at 5:56 PM
    Adamace1
    Adamace1 New Member
    None....
    I sound more like an extended warranty company.
  19. May 11, 2024 at 6:23 PM
    Bergy24
    Bergy24 New Member
    True, is this your line of work and do they really get bonuses for denying claims?
  20. May 11, 2024 at 6:24 PM
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    IF it was fixed previously while under warrranty i would contact toyota corporate, and the dealership, explain that it should be covered because it is a previously repaired item.
  21. May 11, 2024 at 6:40 PM
    Adamace1
    Adamace1 New Member
    None....
    No, and if they paid all the claims they would get fired. I'm sure their are bonuses paid to keep warranty claim costs down. I know they pay people to go around and deny claims. Co worker had a construction strobe light on his truck. So they denied his warranty claim of a covered part. Because in the ten pages of fine print it said no business use is allowed. This was a $4,000 official Chevy warranty. He had to pay the 2,000 repair out of his own pocket. The claim adjuster took pictures of his truck. Most likely got a pat on the back and a nice bonus at the end of year.
