Which Brake Pads?
Discussion in 'Performance and Tuning' started by pvn.beluga, Nov 1, 2023.
  1. Nov 1, 2023 at 5:12 AM
    pvn.beluga
    pvn.beluga [OP] New Member
    Phuc (Phooc)
    Connecticut
    Alright, so got my brakes due soon. Brakes have been feeling soft and rotors have shuddered while braking. I’ve narrow it down to running OE rotors, but still need help deciding what pads to run.
    Thinking about EBC Yellow Stuff, but I know they’re dusty and can wear quickly. What other “decent” options are there?
  2. Nov 1, 2023 at 11:15 PM
    blenton
    blenton New Member
    I still run stock pads again but I liked the feel and extra bite of the Toyota TRD pad when I had them. Still OE design, quality, and reliability with better initial bite and stronger stopping performance. Reasonably priced as well (maybe $10 or $20 more than standard Toyota pads). Factory rotors have worked wel for me.
    I have not tried anything else on the tundra. If the pedal is soft, plan on flushing the brake lines. I will be installing stainless steel hoses soon as well; many have recommended them for a more positive pedal feel.
    Mdl, pvn.beluga[OP] and 02TundraIdaho like this.
  3. Nov 5, 2023 at 7:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've had warpping with the oem rotors. Tried powerstop they too warped within a month. Tried OEM again with no luck. Been running Raybestos r300 rotors with the element3 pads for the past 2 years. Even with high speed stops no warpping!
  4. Dec 16, 2023 at 4:09 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    Akebono
    nobodyintexas and FrenchToasty like this.
  5. Dec 16, 2023 at 7:50 PM
    Fspmdt
    Fspmdt New Member
    2016 tundra 1794
    Bam 8 exhaust 285/70 18 ridges 4:88 gears, auburn lsd 6112s SPC UCA
    Element 3 a good pads i have them on two other vehicles and plan to run them on my tundra when its time along with the r300s
  6. Dec 16, 2023 at 8:11 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The r300's do a good job.
    Ponderosa_Pine likes this.
  7. Dec 16, 2023 at 8:36 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Powerstop z23's. No regrets. I dont tow often, and i dont panic stop. No warping for 10k miles.
  8. Dec 17, 2023 at 5:58 AM
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    Just put Napa premium rotors and Powerstop Z36 pads on. Been great so far, no noise and great bite
  9. Dec 17, 2023 at 6:01 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this
    folks don’t like the name
    but the product is unmatched
    iykyk
  10. Dec 17, 2023 at 7:03 AM
    blenton
    blenton New Member
    If memory serves, Akebono is/was an OE parts supplier for brake pads. We harms an Avalon that akebono=OE.
  11. Dec 17, 2023 at 7:19 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Looks like RA is calling it quits on their inventory too
  12. May 11, 2024 at 5:30 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    What akebono pads should I run for 19 tundra? Anyone have part numbers? Thanks.
