  1. May 11, 2024 at 1:41 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Swapped out the last housing I got from Evil. Turns out they sent me one for a friggin Tacoma so yeah wanted a fuller sized version - they sent me one for a Raptor. Definitely wider than the Tacoma version. If anyone has a Taco, I'll sell you this almost new one. Also selling the original one I bought that has 2 cutouts (instead of the 3 for a camera) - fits 2nd & 2.5 gen Tundras. No Baja lights, just the housing that also includes the cargo and brake lights.
    Comparison
    Tacoma housing minus S2 lights
    Raptor housing installed
  2. May 11, 2024 at 2:39 PM
    redrum448
    redrum448 New Member
    Before, After (what a huge difference) and me doing some climbing (lol) but notice the handles look fine as black.......
    Tundra-XP, Gainer, Florida AF and 9 others like this.
  3. May 11, 2024 at 2:58 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Dang! Is that 2 cameras on there? That’s awesome
  4. May 11, 2024 at 3:12 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes, one is for recording rear traffic and the other is another parking cam.
    bulldog93 and BoyHowdy[QUOTED] like this.
  5. May 11, 2024 at 4:13 PM
    AZTundra
    Paul
    Phoenix, AZ
    Installed Falken Wildpeak AT4W's in 35x11.50r18. These replaced a set of Cooper Discoverer AT3 XLT's in 295/70/18. The Falkens are roughly 3/4" taller and about the same width as the 295's. I was very curious to see how these Falkens would feel given that they are a load range C tire and 6 ply compared to the E load Coopers. These do not have the 3 ply Duraspec sidewall according to the spec sheet on Falkens website.
    First impressions are that these tires feel fantastic. They weigh the same as the Coopers that they replaced at about 63 lbs. The steering and overall feeling while driving is that it feels tighter. Steering feels heavier, but in a more solid precise way. I've only put on about 30 miles so far, but overall bumps and whatnot in the roads feel more confident and not jarring like the Coopers. The tires are stiffer than a standard load tire and you do feel the LT part of them, but in a good way. Overall I'm very pleased with them so far. They are barely audible which is welcoming since the Coopers were worn and getting pretty loud. The Falkens fit without any rubbing at all in any direction. For anyone curious I'm running TRD Pro bilstein coilovers with Westcott collar and 2 coachbuilder shims per side for about 3.5" lift in the front. Camburg upper control arms and a cab mount chop. Front mud flaps were previously removed. Rear is just the TRD Pro shocks and coachbuilder +3 shackles. I removed the fender flares and wish I never installed them. I did use ppf underneath them which worked great, but the locknuts on the backside of the flares did rub the paint and I wasn't able to get the marks out. I'll try again with some compound and see if that helps any.
  6. May 11, 2024 at 5:06 PM
    Timberline
    Timberline New Member
    Colorado / South Dakota
    2016 Tundra DC TRD Limited ~ 2007 4Runner Sport ~ 2003 Tunda (sold)
    '19 TRD LED headlights, iHacker harness, RCI sliders, Tuffy Security console safe
    which flares and why didn't you like them?
    AZTundra[QUOTED] likes this.
  7. May 11, 2024 at 5:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    Not sure what brand they were. I picked them up from another member in March of 2022. He had them painted and didn't like the look after they were installed so he removed them. Here is what they looked like after I installed them. I mainly wanted them after adding larger tires for some additional coverage, but prefer the look without the flares.
  8. May 11, 2024 at 5:47 PM
    What the!?
    What the!? New Member
    2017 Pro
    Installed new center console charger and Alpine Halo knob.
  9. May 11, 2024 at 5:53 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
  10. May 11, 2024 at 6:29 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Do your front parking sensors work ok with that bumper?
  11. May 11, 2024 at 6:34 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Yep, incorporated them in front and rear
  12. May 11, 2024 at 7:26 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Update. 90% Completed. Still need to do the following this week.
    • Perform Zero Point Calibration (ABS light On, Trailer brake error, and Pre-collision system malfunction errors due to Zero point Calibration of Deceleration Sensor Undone) (Called to a local PepBoys and they make this calibration for $29.xx)
    • Install Carrier Bearing Drop Kit (Minor vibration at 1k to 1.2k RPM but this kit should fix it)
    • Install front skid plate (Kept uninstalled for easy access and monitoring purposes at least the next few weeks)
    • Sway bar link bolt issue on driver side: The bolt that holds the sway bar link to the lower control arm it is not tie at all. Looks like the thread-locker sealed it at an extreme level and the bolt doesn't go to any direction now. Planning to remove the shock to access the nut located inside the lower control arm and apply heat to see if that helps to tie the bolt completely. No issue in the passenger side.
    I want to complete these items this week so that I can proceed with the Turbo kit install that was delivered this week to my door!!!
    Next mod.!
  13. May 11, 2024 at 10:16 PM
    BoyHowdy
    BoyHowdy New Member
    2021 Tundra
    Beast mode activated
    bulldog93 and Jego[QUOTED] like this.
  14. May 12, 2024 at 3:40 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Pulled lots bushes for neighbors and had a good time with my family. He's 2 and yes those chains are heavy lol.
    Happy Mother's Day to all those mamma's out there.
  15. May 12, 2024 at 8:03 AM
    Dawoofles
    Dawoofles New Member
    Santa’s Village
    2021 Cement Tundra SR5
    TRD rear sway bar, SS3 Max Amber Fog Lights, Carthartt Seat Covers, Morimoto LED interior lights, Ihacker LED Headlights swap, Driver Side Grab Handle, Husky Floor Liners, Weathertech full SunShade, Cat Back Stainless Works Dual Exhaust, OEM metal Oil Canister, Bed Mat, Deck Rail System, OCD Center Console, Full RCI skid Plates(Engine,Transmission, Cat Guard, and fuel tank), 12” Fi Car Audio Neo 3.5 Subwoofer, Gately Box, Rear seat delete, Sundown Audio Salt 2 Amp, Stereo Integrity front stage, Pioneer DVD/CD/wireless Apple CarPlay Receiver
    I had the same experience with RCI. They did the install, and forgot two bolts. Called to say I need two new bolts and they shipped it to the wrong address. Used the address on file, which was their warehouse, since it was an install order. Had to wait another 2 days.
    Terndrerrr and bulldog93 like this.
  16. May 12, 2024 at 8:42 AM
    What wheels are those?
  17. May 12, 2024 at 8:43 AM
    RobertD
    Robert
    DFW, Texas
    The black TSS wheels
    bulldog93 likes this.
  18. May 12, 2024 at 8:58 AM
    Gotcha. Thanks.
  19. May 12, 2024 at 9:21 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Report back with what tire pressures you end up with.
  20. May 12, 2024 at 9:29 AM
    AZTundra
    Paul
    Phoenix, AZ
    I asked at Discout Tire and the store manager said he'd recommend 37-38psi for that tire on the Tundra. He told the installer to set them at 37psi. They feel great where they are. I'm going to check them in a bit to confirm that's where they actually set them at. What psi have you been running in them?
  21. May 12, 2024 at 10:53 AM
    GLaDOS
    GLaDOS Engineer
    Central Oregon
    2014 Tundra SR5 Double Cab
    Installed the tow hooks! I noticed the coating is still very soft and already started to chip and ripple. Perhaps I needed to wait longer than 48 hours before installing.:(
  22. May 12, 2024 at 12:39 PM
    ZPhilip
    Philip
    West Chester, PA
    Started out at 40 and currently at 35. I’m going to chalk them and see what it says.
  23. May 12, 2024 at 6:40 PM
    Florida AF
    Logan
    North Florida
    That is exactly why I got the one I did. I like the Kuat he is showing a lot though! I also added a water port to rinse off before getting back in the truck.
    Unfortunately I took it off because my primary beach blocked off auto traffic.
    texasrho83[QUOTED] and bulldog93 like this.
  24. May 12, 2024 at 6:50 PM
    Florida AF
    Logan
    North Florida
    Happy Mother's day out there! Took the wife and MIL out to a spot to go take pictures of birds. Since birds are not real, I walked my dog and sat in the AC lol. But they had a great time so it was a huge win.
  25. May 12, 2024 at 7:07 PM
    Stanky10
    Stanky10 New Member
    Stanky
    W Columbia SC
    2019 MGM Tundra TRD Sport
    3/1 leveling kit with 295/60/20 Nitto Ridge Grapplers, Go Rhino Dominator D6 step rails, Husky X-Act floor liners (front and back).
    Rays10, Nitto 35x12.50x18 - ARE Cap added this weekend
  26. May 12, 2024 at 7:54 PM
    What the!?
    2017 Pro
    Finally swapped in overhead console from a 2nd gen. Also swapped out the Meso LEDs.
  27. May 12, 2024 at 8:00 PM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Any plans for the old console? I just need the sunglass holder door
  28. May 13, 2024 at 10:59 AM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    Good call, fender flares should be smooth and free of gaudy bolts
  29. May 13, 2024 at 11:05 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    reywcms[QUOTED] likes this.
  30. May 13, 2024 at 11:46 AM
    coTony
    Tony
    Montrose, CO
    I never have liked the bolts in the fender flares, I like the clean look…
    Velocity72, Cthulhu, rdiddy5 and 18 others like this.
