Second Gen grilled
Discussion in '2nd Gen Tundras (2007-2013)' started by That07Tundra2005, May 7, 2024.
  1. May 7, 2024 at 9:33 AM
    That07Tundra2005
    That07Tundra2005 [OP] Shadow_Tundra
    Ashton
    Saskatchewan, Canada
    2008 SR5 “shadow”
    VLAND LED headlights Tinted Taillights & Third breaklight Tow mirrors with tinted markers Amazon Mesh Grill Westin running boards Full stereo with CarPlay/android auto & Subwoofer More to come!
    Can I see your aftermarket/custom grilles? I need some inspiration. Thanks!
  2. May 7, 2024 at 7:35 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    Mine is made by Enve Grilles, but they are no longer in business. I’m thinking about trying out the Sequoia TRD grill.
    Tridom likes this.
  3. May 7, 2024 at 8:39 PM
    That07Tundra2005
    Ashton
    2008 SR5 “shadow”
    Did you paint it yourself?
  4. May 9, 2024 at 7:50 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Got this insert from customcargrilles.com
    Must cut out the original insert and bond this one in place. They provide the emblem as well if you like.
    Figured the design was going to have issues with snow accumulation, but there has been only storm the last three year with wet enough snow to cause the following, tho there was no effect on cooling.
    After this one is done, I will probably look at a new surround with the faux TRD Pro insert.
  5. May 11, 2024 at 5:09 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
