Mud Flaps
Discussion in '1st Gen Tundras (2000-2006)' started by MT-Tundra, May 9, 2024.
  1. May 9, 2024 at 2:23 PM
    MT-Tundra
    MT-Tundra [OP] Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I just noticed this. Best I can tell, the flap itself is just attached to the base by a very very thin line of plastic, and that has peeled away? This must be a common issue. Aside from some pretty inelegant fixes I can think of, what have people done to fix this?
  2. May 9, 2024 at 2:54 PM
    It's melted away. Best bet? Trim it to look natural.
  3. May 9, 2024 at 3:00 PM
    MT-Tundra
    Montana
    Here's what I'm specifically talking about. I can live with the amount it's melted right now. The problem is that it melted because it appears to be peeling away from the base. The mud flap on other side doesn't have this much play.
  4. May 9, 2024 at 3:02 PM
    Interesting. I don't have my spares anymore or I'd send them to you.
  5. May 9, 2024 at 3:07 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I had the exact same thing happen. I drilled holes and added some zipties to secure it a bit better. Black zipties and you can't tell unless you're looking for it.
  6. May 9, 2024 at 3:15 PM
    MT-Tundra
    Montana
    Ok, cool. I appreciate it!
    Yes, something like what Kimosabe is talking about would be an inelegant, but perfectly acceptable solution.
    The driver side is on its way, but hasn't peeled as far yet.
    If I knew it wasn't true, I'd say I must just drive a lot faster than the rest of you!
    Driver Side
    Passenger (and unfortunately exhaust) Side
  7. May 9, 2024 at 4:21 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    There are four screws that hold the mud flaps on. It seems that you might be missing one or more of them.
  8. May 9, 2024 at 5:02 PM
    MT-Tundra
    Montana
    I wish that was the case. There are no fasteners where this is happening. It is the flap part of the mudflap tearing away from the base of the mudflap.
  9. May 9, 2024 at 5:11 PM
    MT-Tundra
    Montana
    Going to be either a zip tie fix, or an epoxy fix. Will see which.
    JasonC. likes this.
  10. May 9, 2024 at 6:18 PM
    KTM_AJ421
    KTM_AJ421 New Member
    AJ
    2006 SR5 DC 2WD 4.7
    I took mine off jury still out whether that was a good idea with -10mm offset wheels
  11. May 9, 2024 at 6:30 PM
    MT-Tundra
    Montana
    My truck being a Limited model, it'd look pretty bad with the flaps removed. And it's nice to have flaps that stick out enough to actually keep my truck slightly clean!
    I had these laying around. Epoxy said it was for indoor use, but I think only because it will yellow with exposure, not because it'll fail...but anyway rather than break open the epoxy I just laid a thick bead of gorilla glue down. Will do the backside once it cures a little. Hopefully that's enough to keep it in place.
    The Black Mamba likes this.
  12. May 9, 2024 at 8:24 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    What’s the temp rating on the glue? Cold temps and snow/mud might make it weaker. Worth a shot.
  13. May 10, 2024 at 6:39 AM
    MT-Tundra
    Montana
    No idea. We'll see how it holds up.
  14. May 10, 2024 at 7:24 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
  15. May 10, 2024 at 7:55 AM
    MT-Tundra
    Montana
    "Talk about mudflaps..."
    My Tundra's certainly got em.
    Bprose likes this.
  16. May 10, 2024 at 9:52 AM
    Acatlin96
    Acatlin96 amateur breeze shooter
    Austin
    Central Coast, CA
    2003 AC SR5 V8 4WD TRD
    I had the exact same problem with my rear mud flaps. I did as you did, slathering the joint with JB weld and they've held up great so far!
  17. May 10, 2024 at 11:57 AM
    MT-Tundra
    Montana
    Great. I figured this couldn't be a rare problem.
