  1. May 9, 2024 at 9:18 PM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    Installed my warranty replacement morimoto tail lights, got my ditch lights working, and installed an Amazon billet battery holder thing I had laying around. While I’m happy morimoto sent me replacements and in the red color I had originally wanted, I’m kinda bummed they sent me old stock. The ones I removed had a date of 2/22 whereas the replacements had a date of 5/22. Others have told me that their replacements came with beefed up tabs but the ones I got are exactly the same.
    IMG_3435.jpg IMG_3432.jpg IMG_3437.jpg IMG_3434.jpg IMG_3440.jpg IMG_3438.jpg
  2. May 9, 2024 at 9:23 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I rarely check this thread, but tonight I did, I LOLed..o_O:thumbsup:
  3. May 9, 2024 at 9:27 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  4. May 9, 2024 at 9:42 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    7’s on the way home from work.
    3-1/2 years
  5. May 9, 2024 at 9:43 PM
    RoniusMaximus
    J
  6. May 9, 2024 at 9:43 PM
    RoniusMaximus
    J
    Go buy a scratch it or lottery ticket!
  7. May 10, 2024 at 3:20 AM
    Bergy24
    Bergy24 New Member
    Maybe wheel bearing? I had a similar sound with a S10 years ago and I replaced a bunch of front end parts only to finally figure out it was a loose door hinge that was the culprit all along.
  8. May 10, 2024 at 4:01 AM
    It feesl sort of like a spring pop. I though I saw something in their forum about someone having a strut mount that was loose but I would have to look at the post again. That forum is not very active at all.
    Bergy24[QUOTED] likes this.
  9. May 10, 2024 at 4:31 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Not to belabor it...but that's exactly what mine sounded like.
  10. May 10, 2024 at 9:38 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I'm curious to know how those shocks perform for you!
  11. May 10, 2024 at 9:44 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    Got these Bush Company awning brackets last night and put them on the Kuat Ibex rack. Very beefy!
  12. May 10, 2024 at 10:29 AM
    Retired Blue
    Retired Blue New Member
    Steven
    Round Rock, TX
    2020 Super White Platinum
    Well, I got all four installed. (Also got my new-to-me Fuel Blitz 20x9 +20 on, and they currently have almost bald 285/55s.) A lot of changes all at once: new wheels, shocks, and Road Active Suspension. After about 10 miles, surface streets, ride is nice, not harsh, but less cushy than stock; a different level of "touch" with the road. My big worry now is those worn out, front 285/55s rub in reverse. Both fronts are hitting either the bumper plastic, or the mud flap, depending on my direction of turn. And, I've already paid for new 285/60s that I planned to have installed in the next day or two. So, priority now is finding solutions: bumper shims (I've bumper light brackets currently installed on the mounts that likely won't go back on with 1/2" shims)?, remove/replace mud flaps?, adjust the CO lift?
    Florida AF likes this.
  13. May 10, 2024 at 10:37 AM
    MJustice
    MJustice New Member
    Mitch
    Sacramento CA
    2021 Platinum Tundra MGM
    6 window Ceramic tint, TRD Exhaust, TRD front and rear sway bars, TRD BBS wheels, temporary 2" front leveling spacer.
    That much suspension change will need an alignment. I personally wouldnt trim and adjust things without the tires on it that you plan to use, and i wouldnt align it with worn out tires. Id install the new tires and have someone align it who is compitent to adjust the caster forward for clearance
    Florida AF and Tripleconpanna like this.
  14. May 10, 2024 at 10:54 AM
    Retired Blue
    Steven
    Round Rock, TX
    Basically agreed. But, I'm already rubbing, front and back, with tires that are 1.2" smaller diameter than what are going on. Plan is to get the new tires on, and then the same shop does the alignment. Perhaps I'm anticipating too much, but I'm thinking at least shim the bumper out using stacked washers, or 5/8" nuts, to give the alignment tech some room for caster forward? Trimming/cutting is the last thing on my mind.
    MJustice[QUOTED] likes this.
  15. May 10, 2024 at 11:15 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Which is why I never have over half a tank full of gas :rofl:
    Tony_h, Tripleconpanna and BoyHowdy like this.
  16. May 10, 2024 at 11:25 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I never wanted a rack until this. I want the rack and the awning. Would be perfect for the beach so I wouldn't have to drag out the canopy and sand bags.
  17. May 10, 2024 at 11:48 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Finally home from the work trip and had time to tinker. New fuel pressure regulator is in. Just waiting on the new tuning device to arrive then we can dial in this LS103mm throttle body and 5” intake etc. Also got a 3D printed sensor guard which looks good. We’ll see how long it stays on since it’s just a ton of 3M adhesive.
  18. May 10, 2024 at 11:49 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Had a rack; took it off. If you’re going to get a rack you might as well get a topper. Serves the same purpose plus more
  19. May 10, 2024 at 11:50 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Change my oil and cut up the factory skid plate.
    I want to remove the diff drop spacers that the previous owner installed, anyone know the part number for the factory bolts?
    bulldog93 and mgm16trdpro like this.
  20. May 10, 2024 at 11:51 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'll never get a camper/topper.
  21. May 10, 2024 at 11:52 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Why do you want to remove your diff drop?
  22. May 10, 2024 at 12:03 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I did this, let me do some digging for the part number.
  23. May 10, 2024 at 12:05 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
  24. May 10, 2024 at 12:10 PM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Theyre largely unnecessary
    CaptRussia253 likes this.
  25. May 10, 2024 at 12:15 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    I suppose so, yeah. I also don't see the harm in running them though
    coTony likes this.
  26. May 10, 2024 at 12:26 PM
    coTony
    Tony
    Montrose, CO
    I am curious to know how many people that drop the diff actually go out and wheel it hard or if it is just to handle a little more room to raise the front end without binding. I do not recall reading anything from anyone that has had failure that was linked to the diff drop but then again the usage of the diff after the drop is what I am curious about.
  27. May 10, 2024 at 12:33 PM
    b6graham
    b6graham New Member
    I should watch Kai's video on it again
  28. May 10, 2024 at 12:35 PM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    My truck definitely sees full droop when I wheel it, albeit with my current 5100 setup it's not crazy droop. Once I switch to extended travel coilovers then see full droop, that's when I think the diff drop will be worth it.
    bulldog93 and coTony[QUOTED] like this.
  29. May 10, 2024 at 12:49 PM
    CaptRussia253
    Ruslan
    It’s not needed and I can regain 1” of clearance. There’s a YouTube video explaining that diff drop kits are useless.
    BreyTundy[QUOTED] likes this.
  30. May 10, 2024 at 12:51 PM
    CaptRussia253
    Ruslan
