General Supercharger Thread
  1. May 7, 2024 at 4:35 AM
    TurboKits
    TurboKits New Member
    Yeah buddy, keep us updated. Shipped yesterday, 2 day air, you should have it tomorrow :cheers:
    We primarily use the Innovate SCG1 since it is basically the PSB-1, but with wastegate control for the turbo set up. However, we are seeing the PSB-1 is the preferred gauge (rightfully so) for the SCs. Anyway, we added the PSB-1 to our Tundra section, we have (12) in stock for anyone that needs one :)
    PSB-1 PowerSafe Boost & Air Fuel Ratio Gauge Kit | TurboKits.com
  2. May 7, 2024 at 7:14 AM
    ViktorG
    ViktorG Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    Mine was a 1.97, hitting ~14 PSI with a 10% overdrive lower pulley and headers at 4000 ft elevation.
  3. May 7, 2024 at 9:21 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I still have ASP overdrive pulley on. Think it was 6.7in?
  4. May 7, 2024 at 12:29 PM
    Fastlane47
    Fastlane47 New Member
    Maryland
    2018 Platinum
    I have the XAT crank pulley 7in, and the @snivilous 2.0 s/c pulley, hitting 18.5 psi, I'm still surprised to see the boost numbers. With long tube headers and ported heads, I thought I would be lucky to see 15psi.
    carn_dogg, nags, reywcms and 10 others like this.
  5. May 7, 2024 at 12:58 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    What are your approx WHP #s? Sorry haven't been following these threads closely.
    Pretty close to expected # plus some deltas if you look at Viktor's # adjusted, assuming you are at seal level. You'll probably see a drop if you haven't switched to the larger blower.
    Mdl and Fastlane47[QUOTED] like this.
  6. May 7, 2024 at 1:06 PM
    Fastlane47
    Maryland
    2018 Platinum
    Once the tune is complete I will hooked it up to the dyno. I'm hopeful to see 650whp plus.
    ARES35, bulldog93, reywcms and 8 others like this.
  7. May 7, 2024 at 1:15 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^^^^^ Holy Moley!:) awesome
    Fastlane47 likes this.
  8. May 7, 2024 at 2:16 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Dude that thing is spinning at nearly 24,000 RPM at redline if your engine redline is 6800. That’s 400 revs in one second! You could roast a marshmallow on the discharge of that blower! Lol.
    It will be interesting to see if you can hit 650whp on that setup. I’d be curious to know what exactly the diminishing returns are as you crank the boost. My guess with the 1.9 you’re probably getting about 20-25 extra hp per psi on the first 10-12psi, but maybe only 15 hp per for the extra 6psi. I guess 630whp but would love to see it make more!
    Fastlane47, Mdl and Saltyhero13 like this.
  9. May 7, 2024 at 2:17 PM
    TurboKits
    Water meth pre-SC and bring the efficiency way up!
    snivilous[OP], e30cabrio, Mdl and 4 others like this.
  10. May 7, 2024 at 3:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm spraying 500cc now at 8psi on up full pressure at on. Will transition to 1000cc soon.
  11. May 7, 2024 at 3:59 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The 1.9 turns into a heat pump pretty quick.
  12. May 7, 2024 at 4:18 PM
    Fastlane47
    Maryland
    2018 Platinum
    I'm shifting at 6800, the engine builder said I could go to 7100, but I want to keep it safe for now, lol. I'm keeping the blower as cool as possible, lots of coolant upgrades to help.
  13. May 7, 2024 at 7:56 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    This happened in the BMW today.
  14. May 7, 2024 at 7:58 PM
    Black@Blue19
    Ken
    SE Texas
    Is it running? 0 oil pressure?
    snivilous[OP] and Wynnded like this.
  15. May 7, 2024 at 8:10 PM
    e30cabrio
    The VDO sender was bad, waiting for a new one.
    Mdl, HulkSmurf14 and Black@Blue19 like this.
  16. May 8, 2024 at 11:43 AM
    ssmokedz
    Shelton CT
    Got any footage of how that thing sounds? I'd love to see that!
    Black@Blue19 and Mdl like this.
  17. May 8, 2024 at 1:20 PM
    e30cabrio
    ssmokedz[QUOTED] and Mdl like this.
  18. May 9, 2024 at 8:18 AM
    ssmokedz
    Shelton CT
    Nice! sounds like fun!
    e30cabrio likes this.
  19. May 9, 2024 at 10:50 AM
    Silver17
    Eastern PA
  20. May 9, 2024 at 10:57 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @snivilous I was perusing the OP for a couple of tidbits, and thought I'd see what is thought of adding an issue to the Magnuson 2650. How's this: "Brass boost port plug on the left rear side of the unit is very tight and is easily stripped. It is recommended that it be removed and reinstalled prior to install of the whole unit to facilitate easier removal at a later time."
  21. May 9, 2024 at 11:00 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    e30cabrio, Silver17[QUOTED] and Mdl like this.
  22. May 9, 2024 at 11:00 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice. And or adding a barbed nipple and cap. I didnt realize at of people don't care about what the blower is doing.
    e30cabrio and Wynnded[QUOTED] like this.
  23. May 9, 2024 at 11:02 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Over 50% concentration will strip that coating. Not sure how long it would take but it does strip it in the long run.
  24. May 9, 2024 at 12:12 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Done, good thinking!
    If I'm missing anything else people think is pertinent let me know.
    Just put a 2-stroke oil fogger and it'll seal the rotors back up, and make the engine happier :D
  25. May 9, 2024 at 3:01 PM
    Saltyhero13
    Stoopid question: Any special tuning considerations for VVT-i when Supercharged?
  26. May 9, 2024 at 3:06 PM
    Whoopsmadeyoulook
    Whoopsmadeyoulook New Member
    Trevor
    2016 MGM Tundra Crewmax 4x4
    Hello everyone I have a quick question, I have a Magnuson TVS1900 installed on my 2016 Tundra , and noticed there’s a small coolant leak coming from the passenger side hose fitting. I’ve readjusted the clamp and even added another clamp onto it but the minor leak still remains. Has anyone ran into this before or have any other recommendations on how to resolve this? Thank you in advanced.
  27. May 9, 2024 at 3:38 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Change the hose. Refill coolant done
    HulkSmurf14, e30cabrio and Mdl like this.
  28. May 9, 2024 at 4:46 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not that I'm aware of. I do know Toyota had something concerning the 4.7 non vvti vs. Vvti supercharged. Cant remember though.
    Saltyhero13[QUOTED] likes this.
  29. May 9, 2024 at 4:49 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Either get a new hose as @reywcms suggested or if room cut 1/2 inch off the end and clean up the fitting as it probably got buggered up somehow.
    HulkSmurf14, e30cabrio and reywcms like this.
  30. May 9, 2024 at 5:42 PM
    Whoopsmadeyoulook
    Trevor
    Definitely gonna end up doing that , thank you guys. @Mdl @reywcms
