  1. May 8, 2024 at 10:49 AM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    Think it was one existing and 1 new
    455h0le_dachshund and oscardog86 like this.
  2. May 8, 2024 at 10:53 AM
    txagg
    txagg New Member
    Central Texas
    Stone cold stock
    Haha! I only mangled two actually, so call it a tie. Glad you were thinking about me shiftster
  3. May 8, 2024 at 11:45 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Good on ya! I needed to stop bad. I was not in a good place. Drinking before work, during work, after work. All just because. Sun up to sun down on the weekends. While driving, while in church, you name it. I got real good and crafty with hiding my sipping cup everywhere I went.
    I made a decision to stop on Jan 1 and only slipped up on Jan 17. Been sober since then. I'm down 50 pounds and 3 inches in my waste just from not drinking and the calorie intake of snaking that come with it. I'm also more active and more willing to get shit done. There is a huge difference in my relationship with my wife, kids and coworkers. I'm a much better person now and I'm happier for it.
    The hard part was having to recognize that I needed to change. People could tell me all day long, but in the end, it came down to a decision I had to make for myself. Truth is, I only miss the taste of whiskey now, not the buzz.
    Now that I look back on it, I realize it was a sad thing that the owner of the local liquor store new me on a first name basis :anonymous:
    txagg, bmf4069, daveeasa and 8 others like this.
  4. May 8, 2024 at 11:51 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Right back at ya man! That is really great to hear youre doing better and staying strong. Wish you nothing but the best. Its amazing how much my sleep and energy has improved and the satisfaction of getting more stuff done!
  5. May 8, 2024 at 11:55 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  6. May 8, 2024 at 1:20 PM
    shifty` Oh, I have felt Cobain's sarcoma
    Welp. Got into the drums today to see if I can figure out wtf this squeal is. I got in, cleaned out, greased all the contact points as best I could w/o tearing everything completely down or getting anything on the shoe. I guess I didn't grease where the wheel cylinder meets the shoe, but got just about everything else. Zero improvement. Still have the squeal (vid below) and it literally is only on my first pullout. I had to make a 5-stop trip when testing, dropping off and picking up stuff, and it didn't happen a single time. Only seems to happen if the truck sits for more than 3-4 hours.
    I really hoped having the phone outside the garage to record video/audio would reveal whether it was the fronts or the rears, but no such luck. Even with directional audio, I can't tell whether it's louder from the front or the rear. I'm suspicious it's the rears but IDFK. It's clearly very thin metal vibrating against something.
    txagg, Voss and oscardog86 like this.
  7. May 8, 2024 at 1:42 PM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    That sounds like the goddamn squeeler on the pad. Lol that's wayyyyy gnarlier than I was expecting
    The Black Mamba likes this.
  8. May 8, 2024 at 1:49 PM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    I'd try to bed those pads and shoes in again, making sure you get them nice and warm. That squeal is unreal!
  9. May 8, 2024 at 1:51 PM
    FishNinja
    Lee
    06DC2wd
  10. May 8, 2024 at 2:33 PM
    I agree, but it was there with both the old pads AND the new pads. These are brand new.
    I used the same process I always use, and again - this squeal was here both before and after doing the pads.
    I've seen numerous people complain about this exact same issue on here:
    • Squeal while backing out on 1st ride of the day
    • Only in reverse
    • Only for the first 3-5 seconds or so of backing up
    • Will return if the truck sits for more than a few hours
    • Happens whether wet or dry.
    KTM_AJ421 and FrenchToasty like this.
  11. May 8, 2024 at 3:18 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    @shifty`
    Our e46 does something like that, pretty much the same conditions too (only first drive of the day and backing up).
    I asked the shop we go to sometimes and they suggested it may be the aftermarket pads aren’t a perfect fit and have a bit more movement than they should so it allows a little drag and movement that they shouldn’t have or something like that, it made some sense.
    Here’s a thought; when you park at the end of the day can you pull a bit farther forward then you usually would then back up a bit and leave it like that and see if it does it the next day? This might shift things differently before sitting.
    NUDRAT likes this.
  12. May 8, 2024 at 3:50 PM
    I'll surely try that and try what @FrenchToasty suggested resolces his issue, which is a hard pedal mash.
    The Black Mamba and FrenchToasty like this.
  13. May 8, 2024 at 4:39 PM
    FishNinja
    Lee
    06DC2wd
    So I was thinking about this and I was wondering if the pad composition is causing it? What kind of material are your pads made of???
    the only thing that makes sense to me is on the first brake gets the pads warmed up enough and the material becomes less "grabby" but that first brake causes the squeak.
    I ONLY think this because on my Miata and 240 I had hawks. And those bitches would squeal like crazy until the brakes got hot enough.
    I could also be entirely wrong. Like you have ceramics or something
  14. May 8, 2024 at 5:47 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    this clip you are referring to is on the front or back brakes? Both show a “clip” on the left.
    The clip in the front is what holds the pins in place. Would be very important.
  15. May 8, 2024 at 6:11 PM
    Advics ceramics. What I pulled out appeared ceramic also.
    TX-TRD1stGEN[QUOTED] likes this.
  16. May 8, 2024 at 6:15 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    That clip goes through the holes on the pins to keep them in place. I hope you have this installed.
  17. May 8, 2024 at 6:20 PM
    Nah, I have individual clips for the pins, pics here from 2wk ago: https://www.tundras.com/threads/wha...-gen-tundra-today.2558/page-1960#post-3562765
    I'd just reiterate too, for @FishNinja, this shit was happening with the old pads also. I can't figure out when it started, but I did not have this for the first 3ish years I had the truck. It either started around the time I had to replace a couple of rear driver wheel studs, or I can't figure it out. Pretty sure it was happening before I lifted the truck. I can't explain it.
  18. May 8, 2024 at 6:36 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Ceramics are known to be noisy
    edit
    I am wrong. Ceramics are not usually noisy.
  19. May 8, 2024 at 6:40 PM
    Definitely, I usually avoid. But this is just obnoxious.
  20. May 8, 2024 at 6:46 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I just looked up what pads I installed on my truck. Raybestos ceramics. They are silent (even when backing out of my garage).
    still think you need to figure out what wheel the noise is coming from and then investigate. Have someone next to you when backing out so they can listen.
    shifty` likes this.
  21. May 8, 2024 at 7:01 PM
    It's so shrill, I'm not sure if they'll be able to tell.
    I did get a GoPro-style camera and a magnetic mount today. I'm going to try tossing it in the center of the truck while backing out to see if I can figure out where it's originating. If I can't put it smack in the center of all four wheels and tell, I guess I'll just need to mount it right on top of each wheel over the course of 4 days and see which is louder? Such a pitfa. What if it's two wheels?! Aaargh!
    But yeah, this literally sucks. Now I see why the other 1GT guys with the same problem never resolved it. Trying to figure out the source is a bitch. And it only happens if I'm ever so slightly holding the brakes in, about 20% or so. If I keep the brakes at 75% compression while backing out, nothing. If I back out with no brake pedal, nothing. It's like it hits right at 20-30% pedal activation.
  22. May 8, 2024 at 7:03 PM
    I usually opt for organics. Not horrible on dust, and I like the way they feel. Not as noisy or dirty as met/semi-met.
  23. May 8, 2024 at 7:23 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Just noticed this shifty, prob not anything related but worth throwing in here I guess? That's real tinny @ 1.5 seconds, like thin metal hitting a perfect resonance. Annoying AF!
  24. May 8, 2024 at 7:38 PM
    I'm going to pull the lower tomorrow for sure.
    The ones Advics providers (which are the lower in that pic) are smaller than OEM. Which is weird to me, b/c Advics is the OEM.
  25. May 8, 2024 at 7:41 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    That rant was real epic. As was the lack of mandatory line thru the username time off.
  26. May 8, 2024 at 7:50 PM
    PenderBen
    2003 Tundra AC 4x4
    Sounds like a drag to me ;-)
    txagg, bmf4069 and shifty`[QUOTED] like this.
  27. May 8, 2024 at 9:10 PM
    @shifty` that's a lot louder than mine. I seem to remember PHM talking about shim pow, or the shims in that diagram solving his issue. I don't remember for certain though. I have the shims somewhere here, but never put them in.
  28. May 8, 2024 at 9:53 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    For those who have done the Denso 12 hole upgrade on the 99 to 03 2UZ, which company did you get them from and did you have to install or repin the harness for the connectors?
  29. May 8, 2024 at 10:20 PM
    AmericanKing06
    AmericanKing06 New Member
    New Mexico
    04 Toyota Sequoia aka Dadwagon
    I have not done this upgrade yet, it is on my to do list when I switch to the VVTi intake plenum. Ill most likely buy them from dirty deeds. On other forum and Facebook groups people had problems buying them from eBay. Dirty deeds is a trusted retailer. The injectors themselves are plug and play. No rewiring is necessary.
  30. May 8, 2024 at 11:15 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Parked next to this cool AC today will getting dinner this GFC camper shell was so cool
