Part number for 2021 TRD Offroad shocks?
Discussion in 'Suspension' started by Resnov1913, May 8, 2024.
  1. May 8, 2024 at 5:52 AM
    Resnov1913
    Resnov1913 [OP] New Member
    Southern Maryland
    2021 4x4 Tundra (mine) , 2023 TRD Offroad 4Runner, 2018 TRD Offroad (spouse)
    I was going to replace my stock black shocks with the TRD Offroad, I looked online at the official Toyota parts shop and all I can find is the sport shocks.
    Any help be appreciated.
    Thanks
  2. May 8, 2024 at 5:55 AM
    Black
    2014 Tundra Limited CrewMax
  3. May 8, 2024 at 6:05 AM
    Resnov1913
    Southern Maryland
    Thanks, that however if for the TRD Pro options. If going to spend that type of money might as well upgrade to Dobinson's
    1lowlife likes this.
  4. May 8, 2024 at 6:28 AM
    Aren't the OffRoad shocks just Billy 4600s? They are on my 2019.
    Terndrerrr likes this.
  5. May 8, 2024 at 6:49 AM
    Black
    Sorry. Misread the original post.
  6. May 8, 2024 at 6:52 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    the trd version is slightly softer valving
  7. May 8, 2024 at 7:26 AM
    I know the old Tacoma blue and yellow Billie’s were smaller than the aftermarket ones. Wonder if the same is true for the Tundra.
  8. May 8, 2024 at 7:33 AM
    Resnov1913
    Southern Maryland
    Just trying to upgrade to the off road from the black shocks.
  9. May 8, 2024 at 7:34 AM
    blenton
    blenton New Member
    I am fairly certain the factory tundra blue and yellows are 46mm like the 4600’s. I haven’t seen a confirmation about the valving though - whether it is the same or different than the off the shelf 4600’s although most say it is a little softer as @Hbjeff noted.
  10. May 8, 2024 at 10:38 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    @Oey12 looked into it a while ago i believe. Even if they are a little stiffer off the shelf i myself wouldnt spend more for the oem ones
    2mchfun, blenton, Oey12 and 1 other person like this.
  11. May 8, 2024 at 10:56 AM
    PermaFrostTRD
    Northern NY
    Have you tried locally for takeoffs? As we get further away from 2021, it will be harder to find "like new" take-offs just laying around taking up space. Also, have you tried our forum marketplace?
    If the availability isn't there, "upgrading" to 5100's probably won't cost too much more than the TRD OffRoad branded shocks.
  12. May 8, 2024 at 11:01 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ryanwgregg likes this.
  13. May 8, 2024 at 11:08 AM
    1lowlife
    DADA
    2014 MGM DC SR5
  14. May 8, 2024 at 11:54 AM
    roughfisher
    roughfisher Aggressive hockey is back in town!
    JP
    Northern Minnesota
    2021 MBM CM SR5 TRD OR 4x4
    I've got takeoffs that have about 30000 miles on them, but I'm guessing the shipping cost is a nightmare so I haven't put much effort listing them on marketplace. I don't sense much demand for them locally (MN)
  15. May 8, 2024 at 12:07 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Yes, as per Bilstein the 4600’s are valved differently than the OEM Bilstein branded version. Additionally the shaft, on the 4600’s, that attaches the shock body to the bushing mount is thicker on every iteration of Tacoma and Tundra model years.
    When I was towing more and carrying weight more frequently, I preferred the 4600’s. Unloaded I prefer the OEM by far…especially on the Tacoma.
    blenton and Hbjeff[QUOTED] like this.
  16. May 8, 2024 at 12:59 PM
    boatsnbikes
    boatsnbikes New Member
    I have the red sport shocks from my 21 with 31000 miles on them I took off about a month ago when I installed a lift. If you’re up for a drive to southern va you can have them for $100. Nothing wrong with them and they have the coils still installed on the fronts. I realize this doesn’t help with your original post but it’s an option for you
  17. May 8, 2024 at 1:21 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Which is thicker? The off the shelf or the oem?
    Oey12[QUOTED] and ryanwgregg like this.
  18. May 8, 2024 at 1:42 PM
    blenton
    blenton New Member
    I’m guessing the off the shelf 4600’s; I believe that would give them higher rod force and a slightly firmer ride. But now I want to check my OE TRD shocks vs 5100’s later today.
  19. May 8, 2024 at 2:02 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    The off the shelf.
  20. May 8, 2024 at 3:19 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    There's a comparison 4 posts above yours..:rolleyes::thumbsup:
  21. May 8, 2024 at 5:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Lol i thought he meant the shock shaft not the outer tube
    Oey12 likes this.
  22. May 8, 2024 at 5:55 PM
    Oey12
    Oey12 New Member
    Joey
    New York
    IMG_0340.jpgThis to be specific…
  23. May 8, 2024 at 7:39 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    That picture from tacoma world is interesting, the oe shock is not even close to the size of a 4600
    im sure the valving is different, but i know 4600 and 5100 are the same basic shock just one is made to extend further
    Oey12 likes this.
  24. May 9, 2024 at 4:41 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    And honestly that picture doesn’t do them justice either. I was shocked when I had my Tacoma shocks side by side…. I always assumed they were the same product and that is what prompted me to call Bilstein.
