Brake bleeder tube size?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tsm503, May 6, 2024.
  1. May 6, 2024 at 9:12 PM
    Tsm503
    Tsm503 [OP] Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Gonna bleed the brakes, looking for ID of tubing needed. Thanks
  2. May 6, 2024 at 9:56 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I dont know the size but I used what ever came with my mityvac and it fit. Also there is a program within techstream you can run that will activate the abs and guide you through the process which helped me get a nice firm pedal after replacing all the fluid. The bleed order per Toyota is, FR, FL, RR, RL.
    Tsm503[QUOTED][OP] likes this.
  3. May 6, 2024 at 11:38 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    What happened to the old school way, longest line first???
    Most brake use ¼” ID hose
    Tsm503[OP] likes this.
