Tailgate assist lowering shock
Discussion in '2nd Gen Tundras (2007-2013)' started by Cruiserpilot, May 6, 2024.
  1. May 6, 2024 at 9:07 AM
    Cruiserpilot
    Cruiserpilot [OP] New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    2010 tundra tailgate assist lowering shock 66140-0C010
    No longer available from Toyota. My new to me 2010 has almost worn out and I like the
    feature so I'd like to replace.
    Can anyone help me with finding replacement??
  2. May 6, 2024 at 9:09 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
  3. May 6, 2024 at 9:20 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    It would appear my search ability on RockAuto was flawed. I found it under a different name. On it's way.
    It's called a Lift Support - nothing to do with tailgate anything.......
    Leo's first likes this.
  4. May 6, 2024 at 12:18 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
  5. May 8, 2024 at 7:24 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Nothing to add here, but wouldn't this little gas charged strut be the same for ANY Tundra from 2007 to 2020?
    Is Toyota really not able to provide replacement parts for a vehicle only 4 years old??
  6. May 8, 2024 at 7:49 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Things like this are usually provided by toyota venders anyways, But as @b6graham provided a clearly well priced
    replacement from Amazon. I found on RockAuto as well, but for me in Canada the shipping/duties makes it 45% more
    expensive so I just paid more on Amazon.ca and saved the hassle as well as getting it tomorrow, not next week.
  7. May 8, 2024 at 8:01 AM
    b6graham
    b6graham New Member
    Stabilus is probably the top worldwide provider of these type of struts. they've been doing it a long long time
    CMikeB likes this.
  8. May 8, 2024 at 8:02 AM
    COTundie
    Trey
    Pretty things
    I understand Toyota does not manufacture all of the parts for their vehicles. My beef is with the fact that one can apparently not get a replacement part from the dealer for a vehicle which is only 4 years old.
    What if someone has a warranty claim? Toyota says they have to install some aftermarket part instead of OE replacement?
    Just seems weird. Not that it matters much on a part like this, but what else isn't available?
  9. May 8, 2024 at 8:08 AM
    blenton
    blenton New Member
    Lots of things from lots of MFG’s. A buddy mine has a newer Ram with a transmission that just took a dump. Covered under warranty but there are only a couple of those transmissions available anywhere, so they are going to install a junkyard transmission instead. Under warranty… junkyard parts.. cuz OEM’s barely have enough parts to keep up with new production. It’s gonna take a while to get that production chain ball rolling again.
  10. May 8, 2024 at 8:18 AM
    COTundie
    Trey
    Pretty things
    Uh yeah. My wife bought a jeep, so I am well aware for how "Stellantis" runs things. They just can't keep replacement parts in stock because of the huge number of specific failures their vehicles suffer. They (or their suppliers) still produce the parts, you just can't get them because everyone else needs them as well.
    The info above suggests this OE gas strut is NLA, which is completely different form a national backorder.
  11. May 8, 2024 at 8:26 AM
    blenton
    blenton New Member
    I’m not disagreeing with you that it’s kinda ridiculous. But it’s not just car parts for Stellantis motors; I have unexpected and intermittent delays and shortages on all sorts of parts and hardware that have generally been available without issue for the last decade. Now it’s a guessing game whenever I order something from any of my suppliers.
    Producers, suppliers, manufacturers have all had to make adjustments that last couple of years just to get products out the door. That usually involves a little bit of triage, and old model low volume replacement parts are typically the first on the chopping block to prioritize new production parts. In the case of Toyota et al they are car manufacturers not car parts manufacturers. If they can’t produce new cars, they can’t survive. Servicing older cars is second priority, unfortunately but understandably.
  12. May 8, 2024 at 8:49 AM
    COTundie
    Trey
    Pretty things
    Unfortunately Stellantis was still having these same supply issues well before covid was an excuse. Though I'm sure they are even worse currently.
    And the gas strut we are discussing here doesn't appear to be a supply issue either. Kinda sounds like Toyota just doesn't want to bother with making room in their warehouses anymore.
  13. May 17, 2024 at 5:58 AM
    Tim98TA
    Tim98TA New Member
    Question about the shock and how the tailgate lowers.
    I bought my 2011 in Dec 2023.
    If I open the tailgate and let it drop, it doesn't fall hard, but it doesn't ease all the way down.
    How are they supposed to fall?
  14. May 17, 2024 at 6:57 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    That’s how mine is now, it doesn’t bang down but I’m replacing it now but my impression
    compared to the relatively good one on my ‘07 is that it’s time to replace before I need it.
    Less than $40 so for the price of restaurant dinner I’m replacing mine.
  15. May 17, 2024 at 7:51 AM
    COTundie
    Trey
    Pretty things
    My 2012 started out pretty buttery. Somehow one of my favorite little features on the truck.
    Over the past year, the strut is showing signs of deterioration. Instead of opening smoothly and consistently thru the entire range, the tailgate falls open about 2/3 of the way, bounces up slightly before dropping the remaining 1/3.
    I also plan to replace the strut in the near future.
  16. May 18, 2024 at 3:06 PM
    Tim98TA
    Tim98TA New Member
    Replaced mine today. It literally took me 5 minutes from taking out the taillight to putting it back in. Very simple. Now the tailgate lets itself down easily.
    Cruiserpilot[OP] likes this.
  17. Oct 14, 2024 at 3:38 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    I replaced mine today with this part: Premium Quality Brand Stabilus... https://www.amazon.com/dp/B09MDH8SWL?ref=ppx_pop_mob_ap_share
    It comes with the boot installed.
    It seems to work well for the first few test raises/drops. It starts to fall, and the lift catches it about 1/2 way down, and lowers it gently. It makes raising the tailgate easier. Time will tell as far as longevity.
    It took all of 5 minutes to swap out.
  18. Oct 15, 2024 at 7:34 AM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
  19. Oct 18, 2024 at 7:51 AM
    COTundie
    Trey
    Pretty things
    Looks like the direct replacement, which I've been meaning to order for some time.
    Thank you for the link/reminder.
    Thumper_6119[QUOTED] likes this.
