  1. May 4, 2024 at 4:21 PM
    ZHUNTER
    ZHUNTER New Member
    North Georgia
    2020 Quicksand Tundra DC TRD
    Westin Winch mount tray w/ custom light bar, avs hood deflector, 3” lift, badlands winch w/ wireless remote, bed stiffeners, Toyota Predator steps, Husky Floor liners
    Installed aluminum roll up tonneau cover with off-road rack.
  2. May 4, 2024 at 4:35 PM
    thebuildist
    thebuildist New Member
    Bob
    2017 SR5 Crewmax 4x4
    Rear seat storage
    I made a couple little mods to my 17 CrewMax today. First, I fabbed and installed a section divider to wall off the rearmost 20 or so inches. It's a couple shelves out of a steel office cabinet that I scrapped a while back, I just kept the shelves themselves as raw materials. I nested them end to end to the correct length and riveted them into a single unit. Fairly strong, fairly lightweight.
    I have unistrut bed rails, and the each of the tops of the divider attaches into the unistrut using shop-made 1/2" thumbscrews screwed into unistrut locking nuts.
    But with those top points locked in, the panel can still swing like a flap. So to secure the bottom, I installed a couple of M10 rivet nuts
    And then screwed stainless steel eyebolts into them.
    From there I attached a couple of wire guide clamps near the bottom of the divider, using them to clamp a very taut bungee cord in place. It's plenty strong enough to keep general cargo from shifting forward, and pretty simple to install and remove: 2 thumbscrews, and two bungee hooks.
    Bob
  3. May 4, 2024 at 4:41 PM
    thebuildist
    Bob
    Rear seat storage
    And while I had the rivet nut tool out, I made another small, but important mod: A stainless grab handle for climbing up into the bed.
    Amazon sells these big stainless eyebolts in the M16 size, 2 for $10. I don't have any M16 rivet nuts, so I took an M16 bolt, drilled out its center, and tapped that hole to M10. Then screw an M10 threaded rod into there, and you now have a nice big stainless eyebolt that screws into an M10 rivet nut.
    I only installed the one, on the drivers side, where the bed step is.
    When you use the bed step, you need something to grip with your left hand to keep your balance as you climb up. Otherwise you have to bend over/kneel somewhat as you climb. So with this nice grab handle, I can grip it with my left hand, put my left foot on the bed step, and walk right up.
    Bob
  4. May 4, 2024 at 5:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    That was easy!! Thanks for the treats!! My boys are SO fast now!! :D
    Vendeta2k[QUOTED] likes this.
  5. May 4, 2024 at 8:10 PM
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Awesome idea for the bins. Any links?
    Bergy24[QUOTED] likes this.
  6. May 4, 2024 at 10:49 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    So the painted taillights got some sun damage. They just cooked inside the lens since the truck is in the sun all day. I went back to the old modified OEM tails, and they’re already growing on me.
    Finished off with Turtle Wax Ceramic Spray, she shines like crazy.
  7. May 5, 2024 at 3:45 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Which roll up did you go with?
  8. May 5, 2024 at 11:41 AM
    Randydw
    Randydw New Member
    Randy
    Ozark,mo
    2021 platinum crew cab
    Me and son-in-law did some vinyl, more him than me. Wouldn’t recommend doing wheels.looks good but pain in the ass.
  9. May 5, 2024 at 11:47 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Got the hardware yesterday and installed the RCI trans skis and cat guards today
    They really need to do some updates on their install guides
    i.e. trans skis crossmember bracket needs to be attached to skid first not truck.
    Only 4 holes to put big bolts into for sliders not 5 per instructions
    bulldog93 and Tripleconpanna like this.
  10. May 5, 2024 at 12:20 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Ordered an Hp tuneres MPVi so @snivilous stops yelling at me lol
  11. May 5, 2024 at 12:24 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    At least show a picture of SOMETHING, that's the whole point of this thread :D
  12. May 5, 2024 at 12:27 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Lmao. Something
  13. May 5, 2024 at 12:33 PM
    reneaux
    reneaux I've been around
    2017 SR5 CM 4x4
    Much needed upgrade and face-lift thanks to @iHacker
  14. May 5, 2024 at 1:00 PM
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Swapped the overhead console from a 2nd gen. I'll tell ya cutting the headliner isn't for the faint of heart.
    20240505_111708.jpg 20240505_111815.jpg 20240505_113216.jpg 20240505_140500.jpg
    Gonna have to go back and tweak a few things but this lil mod is awesome! I was hoping the insulation would compress enough that I could leave it, but it prevents the console from seating towards the rear. Having the additional storage will be nice.
  15. May 5, 2024 at 1:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    How many sunglasses you need bruh…:rofl:
    Neo258, TreeCat, bulldog93 and 2 others like this.
  16. May 5, 2024 at 3:09 PM
    Pillslinger
    Rollin
    SWMO
    Still looking for that magic number :cool:
  17. May 5, 2024 at 5:04 PM
    Bergy24
    Bergy24 New Member
  18. May 5, 2024 at 6:15 PM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    Not today but last week. Today I installed a Radium catch can.
    FISHN43, bulldog93, Silver17 and 8 others like this.
  19. May 5, 2024 at 7:31 PM
    Mirg
    Mirg New Member
    2021 Tundra Limited TRD OR
    Blacked out the steering wheel trim with SEM trim paint. We'll see how it holds up before I paint anything else. I was super careful putting it back together and got a couple small nicks where the silver showed through. Covered them with a sharpie for now but we'll see how it holds up. I only let it dry for a couple of hours before reinstalling and no adhesion promoter or prep other than just cleaning the trim pieces with rubbing alcohol. Hopefully it's less prone to nicks once it fully cures.
  20. May 5, 2024 at 8:01 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Let us know how much your can collects. Mine catches a lot and others hardly get any. And I’m talking about all supercharged engines.
    pursuit2550[QUOTED] and reywcms like this.
  21. May 5, 2024 at 8:11 PM
    ZPhilip
    Philip
    West Chester, PA
    How have you been flashing? I’ve been borrowing one from my cousin for over a year back and forth. Should have just bought my own from the start.
    reywcms[QUOTED] likes this.
  22. May 5, 2024 at 8:18 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I’ve got a buddy with a hp tuners setup
    ZPhilip[QUOTED] likes this.
  23. May 5, 2024 at 10:05 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Your color combo is stunning. That Blue with the rim color is amazing!
  24. May 5, 2024 at 10:10 PM
    Sleeper16plat
    Near Vancouver
    it's 3. One in the truck ,one in the boat and one in the golf bag!
  25. May 6, 2024 at 5:37 AM
    pursuit2550
    I had a J&C catch can before the SC and it collected when I would check it at 5k oil changes. They work, period. As for how much, I would probably say 3-5 oz. When I did the SC install my intake runners on the engine had oil residue and the intake itself had oil residue on it. So it seems even with the catch can some oil still gets through. It could also be that my previous catch can isn't as good and let some through. I did the Radium because it just looks better and after examining it and comparing it to my old CC, it at least looks way better designed. I know that on the crack case side, people never get any thing in the catch can from Radium's duel setup. That's why I choose to just do the pcv side. I could for shit and giggle put my old CC on the crack case side. It will actually bolt up to the Radium bracket.
    bulldog93 and ZPhilip[QUOTED] like this.
  26. May 6, 2024 at 5:56 AM
    BlueRibbon4x4
    Geno
    Thank you so much!!
    RobertD likes this.
  27. May 6, 2024 at 9:59 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    Got the new OVS awning mounted, and put the RTT back on. the Kuat Ibex is solid.
  28. May 6, 2024 at 10:08 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    built a new bed rack, and made a tent-lifter out of an engine hoist
  29. May 6, 2024 at 11:20 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    having something to lift the tent is nice
    I also made my own using an electric hoist from Amazon, pulleys, synthetic winch rope for ATV, bearings, uni-strut and some brackets and shaft I made. I have a low garage ceiling so I needed it to lift at each corner and tuck up as far as possible. Just barely lifts high enough, then I use some ratchet straps for added safety while it just hangs there.
    bulldog93 and helidave[QUOTED] like this.
  30. May 6, 2024 at 10:47 PM
    Tundra-XP
    Will
