Need help with stuck brake piston
Discussion in '3rd Gen Tundras (2022+)' started by Newtonfb, May 4, 2024.
  1. May 4, 2024 at 3:33 PM
    Newtonfb
    Newtonfb [OP] New Member
    Need some help with parking brake malfunction while changing brake pads. I got the caliper off and new pads installed but the caliper wouldnt compress so I tried the parking brake procedure again and now it said malfunction and the piston is all the way out and I can't figure how to get it back in? Any help?
    Tundrastruck91 likes this.
  2. May 4, 2024 at 3:56 PM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    It twists in. Run to the nearest auto parts store and rent a caliper toolIMG_3951.jpg
  3. May 4, 2024 at 4:01 PM
    Newtonfb
    I have fluid coming out of the seal, is that still okay?
  4. May 4, 2024 at 4:16 PM
    TundraTT
    TundraTT Full Send
    Crap. Hopefully someone else can chime in but you shouldn’t see any fluid. You may have over extended it looking at the picture. You may have done that activating the brake off the rotor
    Black widow TRD likes this.
  5. May 4, 2024 at 4:19 PM
    TundraTT
    TundraTT Full Send
    Screw the piston back in and hit it with brake clean. See if it still leaks after all the fluids cleaned up
  6. May 4, 2024 at 5:18 PM
    Newtonfb
    Thanks for the help! Went down and grabbed the tool from the store and it was a life saver. Thanks again!
    TundraTT and NewImprovedRon like this.
  7. May 4, 2024 at 5:39 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Don’t forget to top off your brake fluid !
    raylo, ChesterTundra and TundraTT like this.
  8. May 4, 2024 at 6:21 PM
    Newtonfb
    Okay so I did top it off and my brake pedal still goes to the floor. Does that mean air got in and I need to bleed the line?
  9. May 4, 2024 at 6:29 PM
    Jettster
    Jettster New Member
    2023 Tundra 1794 TRD Off Road
    TRD Pro Wheels and Tires
    Yes
    raylo, Tom976 and Newtonfb[OP] like this.
  10. May 4, 2024 at 6:37 PM
    Newtonfb
    Thanks. Do I only need to do that wheel or both rears?
  11. May 4, 2024 at 6:39 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Did you check to see if the boot was leaking after you pressed on the brake?
  12. May 4, 2024 at 7:04 PM
    Newtonfb
    Yeah I wiped it down and didn't see anything. There's also nothing dripping
    Tom976 and TILLY[QUOTED] like this.
  13. May 4, 2024 at 7:12 PM
    TILLY
    Massachusetts
    That's good.
  14. May 4, 2024 at 9:54 PM
    Black widow TRD
    Manuel
    maybe you can get away with doing just the one that got air in it. But that air could have gotten in the whole system.
    if you do the whole system start with the furthest from the master cylinder then work your way in order.
  15. May 5, 2024 at 8:48 AM
    Newtonfb
    So I just bled the line and it all seems normal now. The only issue now is the parking brake malfunction code is popping up, parking brake is also not engaging when I pull the level but not sure if i screwed it up or if I just need to clear the code first. Is there a way to clear the code without tech stream? I've disconnected the battery and nothing happened
  16. May 5, 2024 at 4:12 PM
    Black widow TRD
    Manuel
    Maybe someone else can chime in I. This one. You’ll need to clear the code at the dealership/ tech stream. Maybe an OBD2 device can do it… hopefully that should suffice. As long as both e-brakes ( left and right) are synchronized. Meaning both are retracted/ detracted.
    Dealer may do it for free, if hes a nice guy. Them electric gremlins be crazy sometimes….
  17. May 5, 2024 at 6:43 PM
    Newtonfb
    I purchased one of those techstream cables off Amazon that comes tomorrow. Hopefully that will clear it
  18. May 6, 2024 at 11:11 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Did you try setting the ebrake with the calipers removed?
  19. Oct 10, 2024 at 7:28 PM
    mountain_heart_homestead
    mountain_heart_homestead New Member
    Patrick
    2022 Tundra 4x4 SR5 Crewmax
    I did the exact same thing. Got it back in, compressed, and back on. Same error message too. Parking brake works though; tested on an incline, with the truck in neutral. Did you get the code cleared?
