Handgun Mount?
Discussion in 'General Tundra Discussion' started by 10forty2, Mar 27, 2017.
  1. Dec 21, 2023 at 7:51 AM
    guyshomenet
    guyshomenet New Member
    2004 Tundra, Access Cab
    I bought a mag mount. Problem was the under dash vinyl [a] provided no good anchor options, unbolting the part of the dash is a big task and [c] the double-sided-sticky pad option failed after one day.
    Any options for mounting under the dash, into the vinyl in a way that lasts? Screws without anchors worked, but only for half a year.
  2. Apr 5, 2024 at 6:41 AM
    Cooldsh5
    Cooldsh5 New Member
    How did you attach it?, what kind of screws did you use? Did you use anchors? Did you have to take the console apart? I have the exact same truck just 2016. And want to add a armotechusa.shop magnet as well but don’t want put a bunch of holes in my console want to do it right the first time.
    coTony likes this.
  3. Apr 6, 2024 at 6:46 AM
    coTony
    Tony
    Montrose, CO
    That is a magnet and the ones I used from two different companies have weak magnets and the rubber cover over the magnet slides off the magnet while you drive. Not my choice, I have one under my desk at home and I hate it
  4. Apr 6, 2024 at 8:25 AM
    HooliKen
    HooliKen New Member
    Ken
    2014 DC
    I have been using this Alien Gear Shape Shifter setup for 5+ years. Hostlers can be swapped on the paddle to fit more than one firearm. My EDC is a S&W Shield or a G19, depending on what I am wearing or where I am going. Perfect placement for a right-hander.
    1lowlife likes this.
  5. May 4, 2024 at 7:42 PM
    Cooldsh5
    Cooldsh5 New Member
    Drilling holes in the side of the console, what is behind there? Does it grab? What kind of screws did you use?
