  1. May 3, 2024 at 6:50 AM
    I would pay $150/shipped for my fronts if I knew they'd last. I think a 3-5yr warranty would do it for me. I'm really curious to see how the '97 Hilux rear bumps work out for others. I'm less concerned about my rear than I am the fronts, though.
    oscardog86[QUOTED] likes this.
  2. May 3, 2024 at 6:53 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Interesting, I havent heard of people using '97 Hilux rear bumps. Are those considered better than our stock rear bumps?
  3. May 3, 2024 at 7:03 AM
    Someone was talking about it in another thread this week. They look to be an inch taller?
  4. May 3, 2024 at 7:27 AM
    87warrior
    87warrior Whiskey Tango Foxtrot
    Kansas
    2004 DC 2uz 4x4
    It is mounted to the metal dash frame under the cluster to the left of the steering column. I didn't get a picture of the mounting. Once you pull the lower plastic piece under the steering column you will see the metal frame for the dash. I used 3 of the 4 mounting points on the 'unit' and secured it with a heavy duty zip tie, VHB tape and a nut and bolt. It's important the 'unit' is secured, but it doesn't matter how the 'unit' sits so that opens up a few options. I was surprised that the Tundra had fewer places to mount this under the dash than the Land Cruiser.
    metalpete[QUOTED] likes this.
  5. May 3, 2024 at 6:04 PM
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    Bed stiffeners
    bmf4069, oscardog86, BroHon and 3 others like this.
  6. May 3, 2024 at 6:10 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Did you build those?
  7. May 3, 2024 at 6:32 PM
    Lundy
    Lundy New Member
    San Diego
    nope, my friend made them for me.....1/4 plate, Tig
    oscardog86 and 455h0le_dachshund like this.
  8. May 3, 2024 at 9:15 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Been having condensation in my front driver side blinker. Popped it out and cleaned out these little rubber u turn breather guys - no clue what they’re actually called. They were plugged up with dust. They had some ancient foam in them that dissolved when I cleaned it with water. Put ‘em back on and we’ll see if it works. Can’t remember who gave me this tip - maybe @VR6T or @FishNinja.
    I used a shoestring threaded behind the housing to pop it out. Worked really well.IMG_1354.jpg
    bmf4069, oscardog86, Voss and 5 others like this.
  9. May 3, 2024 at 9:26 PM
    VR6T
    Texan.... Big suprise
    00 Tundra Limited 2WD AC
    Not I said the cat
  10. May 3, 2024 at 9:27 PM
    VR6T
    Same here
  11. May 4, 2024 at 3:49 AM
    Arringtonpalmer
    Arringtonpalmer New Member
    Sam
    New Hampshire
    2004 Limited Double Cab
    ARB Bumper, Warn Evo, UTE H66 tray, OME 2884 and Nitrochargers.
    Finished up the steering rack job and put the truck back in action. Ordered the steering coupler from Ourisman, took a ski trip, and put everything back together this week.
    That old stuff was CRUSTY!!! So much anti seize and grease on the re-install.
    I have a wiring project coming up too. There is a non working remote start, brake controller, and two unknown switches in that rats nest…..
    Tlar25, bmf4069, oscardog86 and 9 others like this.
  12. May 4, 2024 at 4:18 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    I didn't even know those were a thing lol
    TXTundraGuy23[QUOTED] likes this.
  13. May 4, 2024 at 3:04 PM
    Bed Tundy
    Bed Tundy Like changing a tire, the 1st time you're careful
    Neature Gary
    Moscow, ID
    (W) 2005 AC 4.7 4x4 with VSC, (G)2005 AC 4.7 TRD Sport RWD
    See Signature or my Photo Album
    Me either! I’ve got plenty of condensation in my turn signal housing. The dealership probably sold me subpar blinker fluid.
    today I replaced my pcv valve on my 05. The old one still worked fine I found out. But, With crust like this on the valve, what can I expect the inside to look like??? Or, has anyone pulled one of these out that looked good? I don’t know how to gauge this. IMG_2363.jpg
    Voss likes this.
  14. May 4, 2024 at 5:53 PM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    I think over time they all end up looking like that, at least from my experience. It does remind me that I need to stop putting off a seafoam treatment lol
  15. May 4, 2024 at 6:00 PM
    Natalie fix
    Natalie fix New Member
    2023 Ice Cap Tundra SR5 Crew
    if you're wondering what Nitto ridge grapplers looks like on the 2006 tundra stock rim . lol. see pic
  16. May 4, 2024 at 8:17 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    I backed into a tree last week with my tailgate down and banged it up, still works, but now I have one more thing to replace. Took the white topper off of my gold 2wd and swapped it onto my white 4wd. IMG_2366.jpg IMG_2264.jpg
  17. May 4, 2024 at 8:29 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    You tried hammering that tailgate out yet?
  18. May 4, 2024 at 8:46 PM
    I did something similar by backing into a loading dock with my tailgate town. Thankfully it only scraped the paint.
    I hate when that shit happens.
    Bed Tundy[QUOTED] likes this.
  19. May 4, 2024 at 8:50 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    those concrete filled bright yellow steel pipes have been jumping out behind my mom my whole life, i dont know why they pick on her.
  20. May 5, 2024 at 5:13 AM
    Seems like it would be hard to hammer it upwards. Almost need a way to pull that dent.
  21. May 5, 2024 at 5:28 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    True
    Bed Tundy likes this.
  22. May 5, 2024 at 5:29 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Those weld on pins & a slide hammer.
  23. May 5, 2024 at 6:41 AM
    JakeJake
    JakeJake Slippery Snake
    2000 Tundra AC 4X4
    I have from harbor freight that works well for dents that don't have good access.
    A tailgate at the local yard is only $83 though. You would be time and money ahead to just find a replacement.
  24. May 5, 2024 at 7:18 AM
    VR6T
    A slide hammer and some tack welds are gonna be needed there
    455h0le_dachshund likes this.
  25. May 5, 2024 at 7:36 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Good point. Might be fun to hammer on and use the old one for target practice in that case!
  26. May 5, 2024 at 11:07 AM
    I mean, if you really want to know what it looks like in the VC, snake camera in thru the fill tube. If you can't manage via the tube, I think the fill tube only has two bolts holding it in?
  27. May 5, 2024 at 11:36 AM
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
  28. May 5, 2024 at 2:06 PM
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    Trans dwain n phil
    UBJ grease/Cambolt grease/Check bolts on new OEM LBJ, no movement
    Cowl surgery. Definitely the first one in here besides the glass man (Who left all the screws finger loose). All the factory black sealant tape stuff was gone, except small remnants on a couple grommets.
    Some high grade silicon
    You can't be gentle enough with those grommets
    A full scrub and clean of the cover and weather strip
    Side bar - Rear wheel speed sensor on the 13 Edge.
    bmf4069, oscardog86, Mr.bee and 11 others like this.
  29. May 5, 2024 at 3:19 PM
    Bed Tundy
    Neature Gary
    Moscow, ID
    That's what I was looking at, I put a straight bar behind the face and pulled upwards to get the right distance for the latch to release the gate, so at least my handle works fine now. But the top is so smushed that the paint all popped off. The bottom hinge point was on its way out anyway so I am going to replace it. Found a matching white one without a handle for $100, and it has good plastic on the hinge.
    whodatschrome, oscardog86 and NUDRAT like this.
  30. May 5, 2024 at 3:30 PM
    Yeah, you can't be gentle enough with those little normally-white-but-now-beige fuckers. Half mine broke on exit, on one side. Same with the black posts that snap into the tophats holding the cowl down. Yeesh.
    Hopefully that was ammonia-free silicone (for corrosion reasons)
    303 action --> :thumbsup:
    oscardog86 and Voss like this.
