Engine swap...which wire harness?
Discussion in '1st Gen Tundras (2000-2006)' started by Vegas 22, Oct 19, 2020.
  1. Oct 19, 2020 at 1:16 PM
    Vegas 22
    Vegas 22 [OP] New Member
    gary
    06 tundra double cab
    Swapping engines 05 sequoia into my 06 tundra. same engine same trans. question is do i keep the wire harness attached to the new engine or keep the harness attached to the tundra?
    YardBird likes this.
  2. Oct 19, 2020 at 2:05 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    leave the harnesses alone while you pull your engine with its harness, and install the new engine with its harness... it'll be easier to just plug the new engine with its harness to the ECU than resetting your harness on the new engine... If it doesn't work, then you can always pull the old harness out and swap it over.
    N84434 and evilrb like this.
  3. Oct 19, 2020 at 3:09 PM
    Vegas 22
    gary
    Plugged harness in that was in engine went to start and no response. plugs are all the same its just different amount of wires to each plug are differnet. so i should use wire harness from tundra right?
  4. Oct 19, 2020 at 3:12 PM
    blackdemon_tt
    Have you verified if the wires are correctly plugged in? Battery is good with good engine grounds?
  5. Oct 19, 2020 at 3:24 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Oct 19, 2020 at 3:35 PM
    blackdemon_tt
    You may need a couple tries, as long as there are not apparent mechanical issues with the engine, just to get it back up and running again...
  7. Oct 19, 2020 at 3:57 PM
    Vegas 22
    gary
    all plugs and ground are good battery good i own both engines sequoia was totalled strong motor and half the miles of my truck. after everything was swaped the only noise heard when turning key was a click at the oil pressure sensor. the starter wont engage no fuel pump pumping relays are all good
  8. Oct 19, 2020 at 4:02 PM
    blackdemon_tt
    try swapping the ECU over... I'm sure the ECU is separate from the body harness as they have different functions... Ensure the ECU is properly grounded...
  9. Oct 19, 2020 at 5:08 PM
    Vegas 22
    gary
    still nothing
  10. Oct 19, 2020 at 5:20 PM
    blackdemon_tt
    At this point, you may as well swap your old harness over, if you haven't already... Take pictures of how the loom wired through, if you have to remove the intake manifold, you might as well bring your old starter with it...
  11. Oct 19, 2020 at 5:21 PM
    blackdemon_tt
    how long has the sequoia engine been sitting??
  12. Oct 19, 2020 at 5:42 PM
    Vegas 22
    gary
    A year but put marvel oil down all cylinders and turned the crank after changing water pump and timing belt.
  13. Oct 20, 2020 at 1:54 PM
    blackdemon_tt
    Were you able to get to run??
    I got locked out of my computer last night due to an update, which took the better part of 4 hours, lol....
  14. Oct 20, 2020 at 10:08 PM
    Vegas 22
    gary
    What a pain in the rear! would have been so much easier while it was out. getting ready to put the wire harness and intake back in now. fingers crossed
  15. May 4, 2024 at 1:39 PM
    Stock_ej8
    Stock_ej8 New Member
    Did it work??
