  1. May 1, 2024 at 9:34 AM
    Damie Street
    Damie Street New Member
    Edsel
    2016 MGM CrewMax SR5 TRD OffRoad
    That DOES sound like a HUGE PITA. Yikes
    Azblue[QUOTED] likes this.
  2. May 1, 2024 at 2:26 PM
    Old springs were FUBAR on one of our doors. Shit scAmazon quality, the other door still has 21yo originals intact and healthy, I replaced these when a pulley went out 8-9 years ago, and look at 'em already. Same tension as the other door, but the coil thickness was subpar. I went with DURA-LIFT brand this time, Home Depot carries their stuff. Calipers out closer to the originals.
    I'd say they were pretty done.
    WAtundra4x4, BroHon and Kimosabe like this.
  3. May 1, 2024 at 9:19 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Water chemistry can have an impact on copper too. I still trust it over most alternatives though. There are bad batches of PEX - I have a coworker that has had four separate blowouts in the PEX in his house. Not fitting failures or localized damage/scratches. Literally pipes split and leaked, traced back to a bad run of material. At this point his whole house has been gutted and repiped ($1.5mm home).
    WAtundra4x4 and BroHon[QUOTED] like this.
  4. May 1, 2024 at 9:21 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yes
    And good quality solder
    BroHon[QUOTED] likes this.
  5. May 1, 2024 at 9:26 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Emery cloth or a good rotary brush. Then good flux. Then good solder, and MAPP gas in your torch.
    shifty`[QUOTED] and BroHon like this.
  6. May 1, 2024 at 9:28 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I want to get rid of those style springs and switch to torsion springs one of these days
  7. May 2, 2024 at 4:43 AM
    Jckdanls07
    Jckdanls07 We May Not Know Them All, BUT, We Owe Them All !!
    Keith
    Tampa Area
    2015 White Tundra SR5
    Then when soldering concentrate the heat more on the fitting than on the pipe... With the fitting hotter than the pipe... and then when solder melts on the pipe the heat of the fitting sucks the solder right in ... The whole fitting (all inlets/outlets) has to be done at the same time... Can not do one connection and then try to come back (after the first has hardened) and do another...
    Justa a thought...
    ATV25 and BroHon like this.
  8. May 2, 2024 at 6:08 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yep.
  9. May 2, 2024 at 6:49 AM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    Copper is the way if you want your water to stay in place, but if you have a well water it usually has a high mineral content (pending on location)it will break down the Copper unless you do the tedious chore of filter replacement.
    Just food for thought.
  10. May 2, 2024 at 8:03 AM
    Azblue
    The Dirty T ( ^_^)_且
    Inspection today, then can get started replacing all the drywall. The city is worse than the damn cable co, at least the "window" for cable is usually a few hours, the city- 7am-4pm. :frusty:
    NWPirate likes this.
  11. May 2, 2024 at 8:18 AM
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Talk about a low stress job,just do what you can at a snails pace.
    Azblue likes this.
  12. May 2, 2024 at 9:58 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Getting some concrete poured this weekend for the side yard. Gonna put a few sheds and the box we keep all the pool toys in.
  13. May 2, 2024 at 5:55 PM
    Honestly, I'm debating whether to keep the damn doors or not. The doors are 7'x9' (HxW), that's four 21" x 9' wood panels. Heavy as hell, and with all the rain we get, I'm replacing the lowest panel that touches the ground every 7-8 years or so. (I've got proper seals on the bottom, water still eventually wicks up). If I hadn't just replaced both openers with new chain drives and installed MyQ bridge on them, I'd trash it all and go with a different system. I really hate that the doors roll up and obscure 1/2 my garage ceiling, it's preventing me from installing more lighting, the door would just block it.
    Ideally, I'd like to have a steel roll-up door that rolls up into a box in the ceiling, just in front of the garage opening. Or trash everything and go to a multi-panel all-metal door that's insulated on the back side for our mild winters and sound control with a rotary or screw style opener - anything quieter than a chain drive, I don't know what type would be. Garage is in the basement, I can hear the garages opening two floors up in my bedroom. Which is a blessing (security/awareness) in the days before I installed the MyQ bridge, and a curse (noisy as hell).
  14. May 2, 2024 at 6:48 PM
    Azblue
    Look at belt drive openers, very quiet.
  15. May 3, 2024 at 7:26 AM
    Tundar the Barbarian
    Tundar the Barbarian New Member
    2020 MGM TRD OffRoad
    Speakers, amp, subs, floorboard lights...and the little step thing under the bumper
    Second on belt drive. When we needed to replace the door a couple years ago, went ahead and got a new opener. Belt drive, super quiet...I won't be going back.
  16. May 3, 2024 at 9:54 AM
    Florida AF
    Logan
    North Florida
    edited because I forgot how to read this morning....
    Skil brand is my go to for table saws.
    Damie Street[QUOTED] likes this.
  17. May 3, 2024 at 12:25 PM
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Grabbed a load of mulch for the wife and kids to spread, as I sit and watch while drinking beer (can’t help due to rotator surgery)
  18. May 3, 2024 at 7:46 PM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    Is that a yard? Or ?? In the past I usually get It delivered at 5 or 7 yards as a minimum. But I need just a little and and thinking I’d get a Tundra load. Less of a schedule hassle then.
    note: Tundra load.
  19. May 4, 2024 at 1:21 AM
    MARanger
    Andy
    yes, 1 yard
    WAtundra4x4[QUOTED] likes this.
  20. May 4, 2024 at 6:14 AM
    Once you add concrete, where does the water run off? Just curious how it will drain with your neighbors house so close.
  21. May 4, 2024 at 8:07 AM
    Damie Street
    Edsel
    I have a couple projects in the works after cleaning/organizing the garage this coming week.
    First is a cart for the miter saw and job site table saw. I'm thinking something like this:
  22. May 4, 2024 at 8:24 AM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    A cart like that with a good set of locking casters would be sweet. I use the DeWalt miter saw stand, it’s far less mobile but really stable. The extendable wings on either side really help with long pieces as well
    Blufin and Damie Street[QUOTED] like this.
  23. May 4, 2024 at 8:26 AM
    Looking for some opinions here. This retaining wall was replaced by the previous owners when we bought our house 3 years ago. They paid some DIY rednecks who only installed drains at the very bottom. I'm trying to keep it from getting worse. The contractor who did our bathroom recommended I dig down above the worst section and then drill a hole and install drains. Curious if anyone has different suggestions. I would think I could drill and install a drain without digging down.
    I do not know if the entire wall is brick, or just brick covering block.
  24. May 4, 2024 at 8:29 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Got the keys to our new home a week ago. Can’t wait to start doing some home improvements.
    The list: extend concrete patio, add a 20x30 shop in the back, and remove grass on the left side and add concrete to the gate.
  25. May 4, 2024 at 8:31 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    Congrats!
  26. May 4, 2024 at 8:40 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Congrats! Can’t wait to see the improvements
    CaptRussia253[QUOTED] likes this.
  27. May 4, 2024 at 9:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    What is a trudeau load?
    I’ll get compost/gravel/bark/wood chips all the time when I just need a little.
    1/2cy gravel is about max (with the RAS helper springs) I’ll carry
    Compost or bark dust mulch, a full yard will haul just fine.
    Cedar chips you can fit 1-1/2 cy and it will still be below the top of the bed (I can close my cover over it. I’ve hauled 2cy of them but I probably lost 1/4cy blowing off the top of the pile in the 15 miles home.
  28. May 4, 2024 at 9:29 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Drilling in drains won’t help much if you don’t have good/proper drainage behind it.
    BlueCrushSC16 likes this.
  29. May 4, 2024 at 10:01 AM
    French drain? The issue is that the end is not open. It's not the best design and certainly not good for drainage. I'll snap more pictures so you can see what the top looks like.
  30. May 4, 2024 at 10:38 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah - sorry, was on my phone.
    You need good drainage behind the wall first and foremost. Drain holes through the wall are fine to drain water out, but if you don't have a good porous fill behind it to collect that water then you'll end up with mud blocking up those drain holes. Something like this (ignoring the concrete/rebar detail part).
    If you can dig back behind the wall about two feet, get some drainage rock and perf pipe in there down closer to street level, run some weep holes through from the front, and then backfill the remainder with good soil you'll be in much better shape for making sure it drains at least. Of course, if the wall isn't structurally sound, then you're kind of just prolonging it at that point.
    ColoradoTJ, BroHon, NWPirate and 4 others like this.
