NEED HELP P0420 and P2447
Discussion in '2nd Gen Tundras (2007-2013)' started by Yotababy, May 1, 2024.
  1. May 1, 2024 at 5:12 PM
    Yotababy
    Yotababy [OP] New Member
    Logan
    2012 Toyota tundra 4.6 L four-wheel-drive
    3 inch level 35 inch tires dual cat back exhaust
    Anything will help me at this point i replaced the Downstream oxygen sensors and not too long ago I actually replaced The secondary air injection pump twice As well as valve now I'm looking at Cal converters what do y'all recommend anything will help thank you
  2. May 1, 2024 at 7:02 PM
    Orions Dad
    Orions Dad New Member
    2007 Tundra 4.7L
    P0420 can be gas cap related
    P2447 can be low air pressure to secondary air valve try checking the hose that goes from pump to valve for cracks or holes
  3. May 2, 2024 at 12:10 PM
    Yotababy
    Logan
    Haven't tried a new gas cap but my hoses look good i replaced one of them myself it's there a vacuum test i could do myself
  4. May 2, 2024 at 12:53 PM
    Orions Dad
    2007 Tundra 4.7L
    Don’t rely on a hose looking good, in the past I will either just replace the questionable hose or plug one end of hose and use compressed air at the other end, you can apply soapy water to the outside of the hose to make it easier to spot a leak
    Have you tried switching the hose to the bank 1 air pump and valve?
  5. May 3, 2024 at 4:36 AM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    If you are going to replace the gas cap, only get OEM. The aftermarket ones are junk
