Sealing the Cab to the Cap
Discussion in '3rd Gen Tundras (2022+)' started by Amy, May 2, 2024.
  1. May 2, 2024 at 7:36 AM
    Amy
    Amy [OP] New Member
    2023 Black Tundra
    Solar Hood Panel, Wheels & Rims, ARE cap & seal (open window), roof rack with box, DIY curtains, bed platform...
    Hello! I am new here, recently bought a 23 platinum crew max.... I just put a new ARE cap and built out a bed platform, working on executing my plan to drive/camp/live as I venture West.
    ****The goal is to be as stealthy as possible, to go from the drivers seat to the back/cap (where the bed is) without having to go outside.
    - To match the size of the Tundra windows I cut into the cap to match the window size openings
    - Next I installed a rubber boot with contact cement to cap and a boothook to the cab, this is ok but not perfect water can still get in (the boot is not 100%)
    I tried pool noodles (major fail)
    I covered the truck/cap over gap with 8" width vinyl to cover the entire thing - and was told it will fail.
    Looking for options/ideas to get this water tight/no leaks! Thank you !!!!!
  2. May 2, 2024 at 7:43 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I can't help with your issue, but I'd like to welcome you to the forum..:thumbsup:
    I dug around a little and it seems most boots are made for small center slider windows..
    Surely more will comment.
    Good luck..:cool:
    2mchfun and Amy[OP] like this.
  3. May 2, 2024 at 7:59 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  4. May 2, 2024 at 9:14 AM
    Amy
    Amy [OP] New Member
    2023 Black Tundra
    I have the Breezer window boot/boot-hook installed ... it's not designed for the Tundra, it is only bridging the gap - not sealing the gap :(
    1lowlife likes this.
  5. May 2, 2024 at 10:49 AM
    ENOK
    ENOK New Member
    Paul
    Adirondack Mountains, NY
    2000 SR5/AC/TRD BLACK 4X4
    I had the same problem with a 03 Ram and Topper. After trying many different ideas, I came up with the perfect answer. A Bicycle tube for the largest Bike Tire I could find.
    With just a little air in the tube to get a shape, work it down and round the window in the cab and Topper. A little more air and you can work out the wrinkles and get the shape you
    want. Then inflate the tube just enough for a water tight seal. Be careful when inflating the tube that you dont break or bend any thing, you have a lot of force available. It worked slick, never leaked and only cost a few bucks for the cheap tube.
    Paul
    Kap1, kirkb, Tundrastruck91 and 2 others like this.
  6. May 2, 2024 at 11:11 AM
    2mchfun
    Yes, motorcycle tubes work great on small windows, but I think this is a full size crewmax rear window opening.
  7. May 2, 2024 at 11:17 AM
    2mchfun
  8. May 2, 2024 at 11:28 AM
    Wood-Dro
    Wood-Dro New Member
    I thought ARE made one of those? Did you check with them?
    Amy[OP] and 2mchfun like this.
  9. May 2, 2024 at 11:49 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I don't have a product specifically, but you might want to consider looking at how RV's work, specifically with their double seals on slide outs. It might be an option in combination with the pool noodle or inner tube idea. Pop-up campers are probably a closer to what you are looking for, but you don't currently have a good overhang to get the channel attached to on both sides. Good luck.
    Amy[OP] and 1lowlife like this.
  10. May 2, 2024 at 11:55 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Welcome to the forum. Years ago on a 94 Toyota I did the bicycle tube trick. It worked but wasn’t the whole rear window.
    with that boot on the shell, I bet if you could find an inner tube big enough to go around the boot it would work. The boot already provides the shape for the tube. That was the hardest part to seal my old truck/shell. Keeping the shape. You could probably get a custom length one ordered or even make one out of 2 tubes and some rubber cement (and patience).
    Amy[OP] likes this.
  11. May 2, 2024 at 12:03 PM
    2mchfun
  12. May 2, 2024 at 12:06 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Pfffft, forget the tube idea. Do this.
  13. May 2, 2024 at 6:17 PM
    Amy
    Amy [OP] New Member
    2023 Black Tundra
    I wish that there was something big enough to accomplish that... Thank you!
  14. May 2, 2024 at 6:18 PM
    Amy
    Amy [OP] New Member
    2023 Black Tundra
    Yes - I saw that on ARE's site and they don't make them anymore. I will call these guys tomorrow! Thank you so much
    OldGuy03 and 2mchfun[QUOTED] like this.
  15. May 15, 2025 at 1:27 PM
    Kestrel2020
    Kestrel2020 New Member
    Donnie
    Texas Hill Country
    2020 Tundra Double Cab SR5 TSS Calvary Blue
    Sleep Deck with Solar & Galley Drawer under an ARE MX
    Any luck calling on this? Lots of us want to know! Thanks.
  16. May 15, 2025 at 4:39 PM
    Drootz
    Drootz Beer me!
    NorCal
    2021 Tundra MGM Platinum 4x4
    TRDPro Fox Suspension, TRD Black Chrome Exhaust, TRD Pro Wheels, TRD Skid Plate, TRD Rear Sway Bar, TRD Air Filter, TRD Flow accelerator, Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added, TRD Shift knob, Remote Tailgate Lock, TRD Parts Added: Fox Suspension, Black Chrome Exhaust, BBS Pro Wheels, Skid Plate, Rear Sway Bar, Air Filter, Flow accelerator, & Shift Knob Other additions: Color matched rear view mirror caps, Xpel Ultimate Paint Protection Film, Driver's side grab handle added. Wanted list: Color matched exterior handles
    I believe this is what you want it's called an accordion style boot.
    When I used to have a shell on my 94 Toyota pick-up truck, it had the compression boot and it worked great, but if you wanted a better seal and permanent pass through they used to use what they called an accordion style boot.
    The only thing that you may have issues with is.....If I recall correctly you had to remove the back glass and molding to install the accordion boot since the pinch mold to mount it goes where the current window seal is. So you would effectively lose the ability to use your power rear slider.
  17. May 16, 2025 at 8:26 AM
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
    I've tried to do this in the past with the Tacoma, ended up with the stupid blow-up ring around the rear slider, which was ok at best. Then throw in the scuffed paint on the back of the cab, and I figured it was a no-go for the Tundra.
    Well this thread got me looking around again, and I just ran across this https://centurydistributing.com/bts...AaFiJxVhTM0bOgxPTQzZ8lFAArnRfJq4lpWxAIa55Iwov
    I'm not sure how it will actually work, but at only $5.50 per foot. I'll buy some, and some 4"-6" wide ppf to put around the cab window give it a shot. Obviously, the goal is compression type boot.
    What are anyone else's thoughts?
    Tundrastruck91 likes this.
  18. May 16, 2025 at 8:52 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The topper on my '08 came w/a 'boot', which worked as advertised in terms of not letting water in, etc. while providing a pass through between the bed and cab...
    However, just note that it basically removes any functionality of the rear window other than a pass-through. In other words if you opened your rear window w/boot intact, hot air would pass from the bed into the cab of truck (at least in the summer months).
    I ened up eliminating the boot and putting glass in at the front of the cap for more functionality of the Tundra's rear window (not sure if your 3rd gen has the full roll down windows like our 2nd Gens). I found w/the cap in place and no boot that I was able to get more 'function' out of the rear window. I almost always have a dog or 2 or 3 with me, so being able to park w/the rear door windows cracked and the back roll down window all the way down (since the cap would prevenet any intrusion) was a huge win for my set up. Much better airflow in the truck when parked.
    With that being said, if you're just concerned w/having a sealed (water resistant) pass-through by way of a boot, I think your idea w/that product is spot on. Also, PPF over the location where the boot touches the cab is ideal as well because the flex between the bed and cab will definitely cause some paint wear over time.
    2mchfun likes this.
  19. May 16, 2025 at 8:52 AM
    2mchfun
    Looks like it could be better and I might have a solution. I would order a little over double the needed length and double it up face to face or in a mirror image lapped together with a waterproof tape available at roofing supply house. The tape is 1.5" wide and is used to seal rubber roofing material seams. It is a little pricey but it will seal, it's easy to work with, don't dry out, etc. I would also probably triple the PPF due to the abrasives that will become trapped in the gap. The doubled boot material will give you a mounting lip on both the truck and cap.
    Tripleconpanna likes this.
  20. May 16, 2025 at 8:58 AM
    2mchfun
    There are fold up window options for caps, and one can mount a remote switch in the bed for the truck window too. Best option IMO provided the budget allows.
  21. May 18, 2025 at 1:21 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've looked into installing some sort of a boot between the camper shell and truck cabin, but decided against it because when you're driving, the cab and bed will slightly move around on bumps etc, and that would cause the boot to rub against the paint and eventually destroy it. Was not worth it for me
  22. May 26, 2025 at 2:15 PM
    Kestrel2020
    Donnie
    Texas Hill Country
    2mchfun likes this.
  23. May 28, 2025 at 6:32 PM
    KrissyMattAlpha
    KrissyMattAlpha New Member
    2023 SR5
    You would think that all the smart people in Toyota's engineering and marketing division would have taken advantage of the Tundra's unique full roll down window feature 2 decades ago.
    They could have easily collaborated with any of the half dozen camper shell manufacturers to design boot/seal system that would simply replace the outside weather stripping with a rubber accordion style boot on the rear window. This would allow a camper shell designed with a duplicate of the Tundra window template to be joined with a weather tight rubber boot and allow full function of the rear window as a pass thru.
    Such a simple idea that could be executed with ease and be a huge selling point for campers, dog owners, surfers, tradesman, etc.
