GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Apr 27, 2024 at 6:08 PM
    #4801
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I had a set of wheels I ordered in March not going to ship mid to late June at the earliest. I passed once I realized how much poke there was gonna be.
  2. Apr 28, 2024 at 10:20 PM
    #4802
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Good taste. Bronze and black is always a killer match
    az 3rdGen likes this.
  3. Apr 28, 2024 at 10:21 PM
    #4803
    cabiczzz
    cabiczzz New Member
    Clyde
    2024 SR
    Stock
    Nice setup.
    Chad365[QUOTED] likes this.
  4. Apr 30, 2024 at 8:10 PM
    #4804
    tacobronco
    tacobronco New Member
    Scott
    2024 Blueprint Crewmax Limited
    I have the TRD Off Road wheels, which I think are the same offset as yours, and no lift or suspension mods. I am running 275/65-20 BFG's, which is basically a 34 inch tire. No rubbing whatsoever. Nice thing is they also just barely fit in the spare carrier if you're into running a full size spare and a 5-tire rotation, which I am. A lot of people run 295/60-20, which is actually ever so slightly smaller in diameter, but wider, of course, and claim no rub. (It looked to me like 295s would be a little tight on the front of the upper control arms at full lock and in compression, but it's hard to visualize how the arm and the tire move relative to one another.)
  5. Apr 30, 2024 at 9:44 PM
    #4805
    jachal
    jachal jachallen
    andy
    FLX, NY
    2023 Black Platinum Hybrid
    w ~1k payload
    U Sh00k, Yaboy, ytank1 and 2 others like this.
  6. May 1, 2024 at 10:20 AM
    #4806
    ullmsie
    ullmsie New Member
    Limited DC TRDOR
    That thing is sweet.
    jachal[QUOTED] likes this.
  7. May 2, 2024 at 7:41 AM
    #4807
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    2022 TRD sport ( sits 1/2” lower in front.) Factory TRD 20” rims. Going to do the Westcott lift down the road. For now can I fit 295/65-20 on the truck stock? Does the 1/2” lower in the front matter? No mud flaps. Thanks.
  8. May 2, 2024 at 9:04 AM
    #4808
    DTieu1
    DTieu1 New Member
    Andrew
    2022 Toyota Tundra iForceMax
    Falkens Wildpeaks, 35x12.5x18
  9. May 2, 2024 at 10:19 AM
    #4809
    Welderdude80
    Welderdude80 New Member
    JP
    Alberta
    2023 Tundra limited hybrid crew max
    working on it
    I ordered Toyo at3 and the next day I got an email saying they were back order and my other option is nitto recon grappler? Who’s running them ? Are quiet on hwy ? I’m currently on ko2 stock size and wanting go 285/65/20 (34.6). I find them really quiet will I be disappointed as far as road noise goes ?
    Bruski208 likes this.
  10. May 2, 2024 at 10:25 AM
    #4810
    DTieu1
    DTieu1 New Member
    Andrew
    Yeah, I love these tires so far, Ive had Toyos MT before, and those were loud. But its quiet, tread wear is great too
    Welderdude80 likes this.
  11. May 2, 2024 at 1:11 PM
    #4811
    nkawal
    nkawal New Member
    2024 Tundra Limited
    Been debating which tire to go with since I bought my 24 limited 2 months ago. I finally pulled the trigger and went with 285/60/20 Falken Wilpeaks AT4W. They were actually $5.00 cheaper per wheel than the popular AT3's. They should be delivering to the installer by saturday.
  12. May 2, 2024 at 3:29 PM
    #4812
    SilveradoSwap
    I hear the AT3 are quieter than the Recons.
  13. May 2, 2024 at 3:30 PM
    #4813
    SilveradoSwap
    My wheels and tires are being delivered Monday, cant wait!
  14. May 2, 2024 at 3:45 PM
    #4814
    Welderdude80
    JP
    Alberta
    working on it
    I heard the same but can’t get them as they’re b/o everywhere
  15. May 2, 2024 at 4:11 PM
    #4815
    SilveradoSwap
    Recons are still a good tire.
  16. May 3, 2024 at 4:40 AM
    #4816
    nkawal
    nkawal New Member
    2024 Tundra Limited
    They're available on simpletire.
  17. May 3, 2024 at 6:05 AM
    #4817
    Welderdude80
    JP
    Alberta
    working on it
    I’m in Canada
  18. May 3, 2024 at 6:16 AM
    #4818
    benca1
    benca1 New Member
    2023 TRD Offroad SR5 Crewmax 4x4
    295/60/20 Wildpeaks 20” limited wheels TRD running boards TRD exhaust OEM bed mat OEM bedcover OEM all weather Mats 4Knines rear seat cover
    @donog1432 295/60/20 fit perfectly fine with stock 20" wheels from the limited, 1794, platinum and sport wheels as those wheels are 20x8 not 20x8.5 like the black trd offroad 20" wheels which are 8.5" wide like the 18x8.5 TRD Pro wheels but the 295/60/20 still fits fine. Now if you are going to go 35x12.50 is where the issues start with the TRD 20" offroad wheels. 12.50 on the stock 20" TRD wheels which are 8.5 wont clear the UCA. I run 295/60/20 stock with no rubbing on anything including mud flaps (OEM 20's not TRD 20's). I am pretty sure with the stock 20's being 8" wide and offset of +60 I could even run a 35x11.50x20 and more than likely only need very very minor adjustments maybe even just removing the mudflaps or just a very small level. I know the 34x11.50x20 will fit totally fine on the OEM 20's Or TRD OR 20's. But if going to run a larger tire on the TRD offroad wheel and not need a spacer go 35x11.50x20 or 295/60/20. If doing any small lift/level then go 295/65/20 or 35x11.50x20.
    Clean setup of a 1794 with TRD 20's and WD kit.
    New 2024 Toyota Tundra 1794 with Westcott Designs lift (youtube.com)
    Paul499 likes this.
  19. May 3, 2024 at 10:21 AM
    #4819
    nkawal
    nkawal New Member
    2024 Tundra Limited
    285/60/20 Falken Wildpeak AT4W
  20. May 3, 2024 at 3:49 PM
    #4820
    6rian
    6rian New Member
    These have quite a brilliant finish. Won’t stay this way for long.
    Jlopez1978sd, Rustifer, DWM and 2 others like this.
  21. May 4, 2024 at 10:46 AM
    #4821
    Bruski208
    Bruski208 New wheels and Tires
    Idaho
    2023 "Wind Chill Pearl" Tundra Ltd. 4x4
    Dealer mods: Fuel Maverick, BFG K03 275/65R20, Leer Canopy, Paint protection film, Window visors, Side Steps (fixed), and more that I don't recall...
    I'm running the Nitto Recon Grapplers -275/65-20. I have not noticed the road noise. I usually have tunes playing but not loud. I bought them because of their light weight (47 lbs.) as I was looking for improved MPG.
    Welderdude80[QUOTED] likes this.
  22. May 4, 2024 at 1:45 PM
    #4822
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    So what are you seeing for MPG’s with those tires?
  23. May 4, 2024 at 1:54 PM
    #4823
    dadrocz
    dadrocz New Member
    Ny
    23’ TRD Pro. 18’Platinum
    These tires are a perfect fit for the Pro. Installed mine the day after I got it.
    Boerseun, kirkb, ytank1 and 2 others like this.
  24. May 4, 2024 at 3:18 PM
    #4824
    Welderdude80
    JP
    Alberta
    working on it
    Holy ! Yours are so light what a difference between them and LT’s I’m definitely gonna feel that and shouldn’t worry about mpg
  25. May 5, 2024 at 6:52 AM
    #4825
    AzTundraTrd24
    AzTundraTrd24 New Member
    2024 Tundra Limited TRD
    I have 2024 tundra limited with the TRD of road package. I’m brand new to off roading and looking forward to learning.
    I’m looking to upgrade my wheels and tires and this thread has great information. I’m looking at putting 35s on my truck and I assume I should change the spare to match, could anyone tell me if a 35 fits in the spare wheel well under the truck?
  26. May 5, 2024 at 6:59 AM
    #4826
    blkstig
    blkstig New Member
    deron
    2024 tundra sr5
    westcott lift 22 inch vossen wheels toyo r/t tires
    Vossen HFX-1 22x10
    Nitto Recon Grapplers 35x1250/22
    Wescott Designs level lift
    mikev25, Bruski208, Justinfro and 2 others like this.
  27. May 5, 2024 at 7:28 AM
    #4827
    Reef2018
    Reef2018 New Member
    Colton
    24 TRD Offroad 4x4 Limited
    Dobinson IMS lift
    Icon billet UCA’s
    RRW flow form 17s
    35” BFG KO2’s
    Tundrum74, Helo and Yaboy like this.
  28. May 5, 2024 at 8:11 AM
    #4828
    ytank1
    ytank1 New Member
    MD
    Hows the road noise?
  29. May 5, 2024 at 8:12 AM
    #4829
    ytank1
    ytank1 New Member
    MD
  30. May 5, 2024 at 9:48 AM
    #4830
    dccrens
    dccrens New Member
    Leesburg, VA
    2024 Tundra I-Force Max Hybrid, Lunar Rockin!, 6.5 Bed
    2024 Limited, iForce Max hybrid, 6.5ft bed, TRD off-road package, TRD 20in wheels, TRD Grille, TRD skid plate, blacked-out badges, NYTOP Rear Recovery Points; Red, aFe Power Front Tow Hooks Red
    Are you lifted or leveled? I have the 20" TRD wheels and factory-stock Falken Wildpeak AT3WA wheels. I'm looking for a little more aggressive tire. I wonder if these 285/60/20 Falken Wildpeak AT4W would fit and not rub.
