LED headlights recommendations
Discussion in '2nd Gen Tundras (2007-2013)' started by Mbril, Apr 7, 2024.
  1. Apr 7, 2024 at 3:45 PM
    Mbril
    Mbril [OP] New Member
    It's time to upgrade the headlights on my 2010 Tundra.
    I see a lot of after market options that are either really expensive or overkill for my needs.
    Lots of them can be really hit or miss in terms of quality as well.
    I'd like to get projector headlights that look as close to OEM as possible without breaking the bank.
    Any suggestions?
  2. Apr 7, 2024 at 6:34 PM
    Mike1305
    Mike1305 New Member
    2011 White SR5
    I went with the Morimoto XB’s with amber DRL. Not projector but a big improvement over stock halogen. Quality seems really good. Maybe my expectations were too high but I was hoping for a little bit better output or at least a more consistent beam. Also probably not fair to compare it to the HID retrofits i did in my 3rd gen 4runner years ago. I guess if you want projectors maybe go with alpharex? Just not sure of their quality. Never had a problem with any Morimoto product I ever purchased. As far as appearance, XB’s definitely look the best IMO.
    Medicineman likes this.
  3. Apr 7, 2024 at 6:40 PM
    Mike1305
    Mike1305 New Member
    2011 White SR5
    S0CKETMAN and Medicineman like this.
  4. Apr 8, 2024 at 2:14 AM
    Medicineman
    Medicineman Not so new member
    Western MD
    2011 MGM Rock Warrior Crewmax
    Heated Leather Seats, Morimoto XB LED and 4-Banger fogs, TRD Pro “style” grille, Bushwhacker Flares, Line-X, Leer Cap, Yak Rack
    I would also recommend Morimoto.
    S0CKETMAN and Mike1305 like this.
  5. Apr 9, 2024 at 6:06 AM
    G_phelps01
    G_phelps01 New Member
    2013 gray tundra 4.6L
    I recommend the alpha-rex ones i bought them from custom offsets they have held up nicely
    Sleeper16plat and Medicineman like this.
  6. Apr 10, 2024 at 3:20 AM
    rickyistre
    rickyistre New Member
    Ricky
    2013 5.7l SR5 tundra
    3 inch body lift, fuel wheels, after market head lights and tail lights, metal bumper w/ led light cubes
    Idk what brand they are but these are what I have on mine.
  7. Apr 10, 2024 at 8:25 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Can you do this without the amber surround? Make it white?
  8. Apr 10, 2024 at 8:51 AM
    Mike1305
    Mike1305 New Member
    2011 White SR5
    Yes, you can buy them with white instead of amber.
  9. Apr 10, 2024 at 9:46 AM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    V land sequoia lights. LED's not projectors. Can be found on eBay for close to half the price of morimotos.
    PolishedTRD likes this.
  10. Apr 10, 2024 at 11:16 AM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Yes, you can.
    You can order either white or amber DRL's.
  11. Apr 11, 2024 at 8:53 PM
    Mbril
    Did you have to get a different trim piece underneath the lights?
    Trucksun likes this.
  12. Apr 11, 2024 at 9:35 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    It comes with the lights. You do have to rattle can it if you want it color matched though. In my photo above it wasn't painted yet and that's why it's still black. Duplicolor has Toyota colors and then I just 2k clear coated them. I'll have to dig up some newer pics.
    Here is the eBay seller I bought from last year. Still happy and they still look great.
    Fronts only:
    https://www.ebay.com/itm/3951972436...USa-s1jS6u&var=&widget_ver=artemis&media=COPY
    fronts and tails included: this is the set I bought.
    https://www.ebay.com/itm/3947088688...USa-s1jS6u&var=&widget_ver=artemis&media=COPY
    everything is plug and play. Here's a fun tip for eBay shopping as well. Add an item to your watch list and usually within a few days you get a seller discount offer from anywhere between 5-10% off.
    Sleeper16plat likes this.
  13. Apr 12, 2024 at 10:06 AM
    Kerplunk
    Kerplunk New Member
    Sealights are good. Uses stock housing and has a non-blinding pattern. $100 for low beams, $130 for both. A big upgrade over stock and don't cost arm+leg.
    Danny3737 likes this.
  14. Apr 12, 2024 at 11:13 AM
    j5offroad
    j5offroad New Member
    Wisconsin
    2010 Tundra SR5 5.7L DC
    I second the Alpharex pro series. I like how the low beams are still halogen, so they don’t blind others but the high beams are super bright. The price is also hard to beat. I ordered mine through headlight revolution and had problems with the first set (probably my fault) and got a replacement set with no hassle.
  15. Apr 12, 2024 at 2:10 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    I used the Sealights as well ( have them on all my cars ). Only paid $35 for the low beams. Have been on for 2 years and have never been flashed.
  16. May 1, 2024 at 8:25 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    Medicineman and Mike1305 like this.
  17. May 1, 2024 at 8:37 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    As much as I wanted the Morimoto I went with a blackout trim halogen on my silver truck. It’s a base model. I’ve just purchased SOS suspension kit and airbags with Bilsteins. So budget restraints. But it does look cool. Both trucks got Amazon specials in Halogen. At least I can see in the dark now.
  18. May 1, 2024 at 9:23 PM
    S0CKETMAN
    Nice trucks!
  19. May 2, 2024 at 7:21 PM
    Dgravee
    Dgravee New Member
    2010 tundra sr5 crewmax
    I put oem 2018+ sequoia headlights in mine which have great light output. They are not cheap though. Sourced them used off eBay for about 800, then trim pieces 100, and harness 100… so about $1k. I’d like to get a set of morimotos as those too me are the best looking.
    Cruiserpilot likes this.
