  1. May 1, 2024 at 9:57 AM
    Pnwtundy
    Pnwtundy New Member
    04 DC SR5 TRD, V8/4WD + LSD/Tow
    Truck officially hit 20 years old this year, so I decided to gift it a professional interior detail. They did a great job!
    G_unit3000, bmf4069, Voss and 6 others like this.
  2. May 1, 2024 at 10:09 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Puhcahn.
  3. May 1, 2024 at 10:11 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Peckin' trees. I reckon.
  4. May 1, 2024 at 10:12 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    pee-sahn
  5. May 1, 2024 at 11:56 AM
    Norcalyotaman
    Norcalyotaman New Member
    2005 Tundra Double Cab SR5
    IMG_1790.jpg Here how I mounted my brake controller. Really easy. Take out the ash tray, use it as a template to drill holes in a piece of plastic (or whatever you have) then put a sheet of good Velcro on the bottom of the plastic and top of the brake controller. I’ve never had it fall. Once in a while I have to kinda push it up a little but no big deal. Fits perfect. IMG_1789.jpg
    immediately after installing I did realize I need to trim back the plastic a bit to hide the white, and paint it black…..but it’s been 3 years and you know how that goes
  6. May 1, 2024 at 1:53 PM
    It look like they missed some dust on top of the parkingbrake pedal.
  7. May 1, 2024 at 1:57 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Courtesy light :anonymous:
  8. May 1, 2024 at 1:58 PM
    Refracting off all that dust :crapstorm:
    BroHon[QUOTED] likes this.
  9. May 1, 2024 at 2:11 PM
    Pnwtundy
    Pnwtundy New Member
    Haha, not bothered by it. Nope, not at all...
    ...so I took an impromptu break at work and rushed outside, you're all wrong.
    The paint is just a bit warn there. Nice try you CSI Miami wannabes!
  10. May 1, 2024 at 2:17 PM
    There's a looooootta dirt on that steel!
    Pnwtundy[QUOTED] and BroHon like this.
  11. May 1, 2024 at 2:28 PM
    Pnwtundy
    Pnwtundy New Member
    Ok, I'm gonna try and clean it off later today. If it doesn't work I think I'll just sell it. Can't have a truck with a dirty pedal
  12. May 1, 2024 at 2:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Paddle sanding wheel, scotchbrite, & green polishing compound. :hattip: Show the haters who's boss.
  13. May 1, 2024 at 2:54 PM
    I'll give you two-fitty.
    Pnwtundy[QUOTED] likes this.
  14. May 1, 2024 at 7:03 PM
    metalpete
    metalpete New Member
    ID
    2001 Tundra 4.7 4x4 SR5
    Toytech 2.0 Coilovers Camburg UCA's JBA headers Dynomax cat-back exhaust 90-221HD Leafs
    Very nice! Where did you mount the, uh, unit?
  15. May 1, 2024 at 8:13 PM
    Pnwtundy
    Pnwtundy New Member
    A little Windex and some elbow grease, and it's looking better!
    It's now worth about tree fiddy
  16. May 1, 2024 at 11:48 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Oops meant that as a reply to this build....
    Build thread?!
  17. May 2, 2024 at 7:19 AM
    daveeasa
    How hard is it to replace the entire antenna? I have the full kit as well as a new boot and ornament but but the nut won’t thread on because corrosion. Gotta take the fender off or can feed through without? Anyone who has done this know how big a job it is?
  18. May 2, 2024 at 7:23 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Just remove the fender liner. The antenna has a bolt on the inside and then the wire feeds through the firewall.
  19. May 2, 2024 at 7:23 AM
    daveeasa
    One hour? More?
  20. May 2, 2024 at 7:25 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I had mine off in like 10 minutes. never put it back on due to snorkel
  21. May 2, 2024 at 7:33 AM
    daveeasa
    You don’t care about FM? That’s one way to go I guess.
  22. May 2, 2024 at 7:34 AM
    daveeasa
    I was curious about the seal at the firewall and accessibility. I figure I have to cut to use the old one as a feeder, hence I’m committed once I start.
  23. May 2, 2024 at 7:35 AM
    FishNinja
    FishNinja HIDE YOUR DAUGHTERS
    Lee
    TEXAN....big surprise
    06DC2wd
    you still listen to the radio? I only use the radio for AM during football season while I'm traveling on the odd mon/thurs/sun and even then that's a last ditch effort
    oscardog86 and 455h0le_dachshund like this.
  24. May 2, 2024 at 7:37 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Not true. I mounted a new RV/Marine antenna to by brush guard
    Voss and daveeasa[QUOTED] like this.
  25. May 2, 2024 at 7:38 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    FishNinja[QUOTED] likes this.
  26. May 2, 2024 at 7:47 AM
    daveeasa
    I do. Partly because family Spotify shared with the house and the palm desert house means I often get my stream interrupted at specific times. Also because my ‘05 Tacoma doesn’t have phone connection (Oem radio needs mic to connect and the two CarPlay pioneer head units have gone to my dad’s older Toyota’s.)
    I do a lot of podcasts and audible but mix in radio sometimes. Commute is short distance wise so sometimes nice to hear local news.
  27. May 2, 2024 at 7:48 AM
    Pnwtundy
    Pnwtundy New Member
    After a little searching I found a post on Reddit with instructions. Unfortunately looks like the photo links are broken.
    https://www.reddit.com/r/mechanics/s/XCTIASTH1j
    Not sure how helpful it'll be for you
  28. May 2, 2024 at 7:51 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    It's not hard. You do have to remove the inner fender liner, and the fender flare if you have one. On the inside you'll need to remove the passenger side kick plate, door sill, glove box, and radio. No need to cut the old line to use as a feeder, you'll see the line coming in from the area behind the kick plate.
    The new antenna assembly comes with a new boot and nut. If yours is stuck you might have luck taping off around your fender and putting some vise grips on it. That's how I got mine off. Previous owner of my truck apparently tried in the past by using a screw driver and tapping it to turn the nut, didn't work out for him as there was a scratch on the fender from where I think he attempted to do that.
    The Black Mamba likes this.
  29. May 2, 2024 at 8:47 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Nothing good on the radio in TX anyways.
  30. May 2, 2024 at 8:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I only used to listen to AM for Coast To Coast
    BroHon likes this.
