Rebuilt 2005 GX470 Project + random E46 M3 and JK updates
Discussion in 'Lexus GX Builds' started by M3Tundra-JK, Oct 23, 2023.
  1. Apr 21, 2024 at 2:12 PM
    #421
    TexasGuyTX
    TexasGuyTX New Member
    2007 SR5 Super White
    PRO BOX w/ RF Mono Amp Limited 20" Wheels HID's on Low Beams Tip Delete Before Axle
    Can't wait to post a thread on the painting of my 07 tundra I inherited and the leather reconditioning on the interior :) been doing mechanic replacements ATM while we are using it till I can have it down for a week or 2 todo the paint job.. welcome back to TX BTW im about a hour away
    M3Tundra-JK[OP] likes this.
  2. Apr 21, 2024 at 2:54 PM
    #422
    hoof hearted
    hoof hearted New Member
    2018 Sequoia Limited 4WD
    Have you tried expanding your search radius to the smaller outskirts towns within the same county? I visited a smaller DMV for an in person DL renewal. In town vs. out of town shrunk my appointment scheduling from 5 months to 3 weeks.
  3. Apr 21, 2024 at 3:36 PM
    #423
    centex
    centex New Member
    I know my local dmv in Tx does online appointments. Last time I went in when I titled and registered my 4Runner (first time it was done since 2010), I hadn’t sat down before they called me back. Gave them the form, the signed title, proof of insurance, and my DL. 15mins later I was out the door good to go. Go to the tx dmv website. There is a phone number you can call and get to an actual human and they’ve been pretty nice when I worked with them.
    RobertD and M3Tundra-JK[OP] like this.
  4. Apr 25, 2024 at 9:30 AM
    #424
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    No clue about Tx, but we have DMV "stores" the service fee is reasonable & it has been walk in, transact, walk out done.
    Maybe they have them in Tx?
    Not easy to find & maybe not helpful.
    https://www.thetexasautotitlecompany.com/
  5. May 1, 2024 at 11:06 AM
    #425
    M3Tundra-JK
    M3Tundra-JK [OP] New Member
    Scott
    2005 GX470
    Borrowed some tin snips and cut out some of the quarter panel damage.
    Before/After
    Brownsfanhere and e30cabrio like this.
  6. May 1, 2024 at 11:09 AM
    #426
    M3Tundra-JK
    Scott
    2005 GX470
    Will need to pull back out some of the lower floor tub section
  7. May 1, 2024 at 12:16 PM
    #427
    e30cabrio
    Nice!
  8. May 1, 2024 at 1:17 PM
    #428
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
  9. May 1, 2024 at 1:19 PM
    #429
    Slag_Dynamics
    Slag_Dynamics Cut. Weld. Repeat.
    Arizona
    Gone
  10. May 1, 2024 at 1:53 PM
    #430
    M3Tundra-JK
    Scott
    2005 GX470
    Fobroader, The Dude and Black@Blue19 like this.
  11. May 1, 2024 at 1:55 PM
    #431
    M3Tundra-JK
    Scott
    2005 GX470
    It'd probably work better than any of the attachments in the hammer slide set
  12. May 1, 2024 at 2:06 PM
    #432
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    Definitely buy it. Who cares how well it grips at that price. Mine is a Mo-clamp brand. No telling how much that one costed when new.
  13. May 4, 2024 at 4:20 PM
    #433
    M3Tundra-JK
    Scott
    2005 GX470
    Alright, let's get back at it!
    Borrowed my brother's air compressor, and got some tools from harbor freight. I left the first belt sander and cutoff tool up in CO. But used this as an opportunity to get the slightly better, more expense versions this time. 1/2" instead of 3/8" belt sander for panel sealant and spot welds. Also some PPE
    + $200
  14. May 4, 2024 at 5:36 PM
    #434
    M3Tundra-JK
    Scott
    2005 GX470
    The 1/2" belt sander is working way better than the 3/8" for this job. Got most of the sealant removed from the bottom part of the fender. Not sure there are spot welds under this area. Which would be nice to not have to deal with.
    The Dude, Black@Blue19 and e30cabrio like this.
  15. May 4, 2024 at 6:09 PM
    #435
    M3Tundra-JK
    Scott
    2005 GX470
    First cut done, and it really wasn't that hard to do! Only spot welds left are along the rear passenger door. Knock those put and two more cuts and the panel should be free! I'm cutting short on this first go and will see how far to take it later.
  16. May 4, 2024 at 7:17 PM
    #436
    M3Tundra-JK
    Scott
    2005 GX470
    And it's off!
    The Dude, AZTundra, Busa and 4 others like this.
  17. May 5, 2024 at 1:23 PM
    #437
    M3Tundra-JK
    Scott
    2005 GX470
    Gonna see if I can't get the old bent support post off today. But I really need to look over that area better now that I have the qp skin off. I may just try and pull some of it out first. Also I'm not sure I have anything, like an adjustable post, to support that corner of the roof once I do cut into this more. It would be less spot welding later, to remove as much of the current support as possible.
    The Dude, Busa, Black@Blue19 and 2 others like this.
  18. May 5, 2024 at 4:50 PM
    #438
    M3Tundra-JK
    Scott
    2005 GX470
    Decided I need to try and straighten the bottom tub out before hacking out the corner reinforcement. Went to harbor freight again, I love that it's less than 2 miles away! Found this ratcheting cargo support bar for $18. Perfect to support that corner when I do pull the reinforcement part out
  19. May 29, 2024 at 8:46 AM
    #439
    e30cabrio
    Did you get flooded?
  20. May 29, 2024 at 8:53 AM
    #440
    M3Tundra-JK
    Scott
    2005 GX470
    My area got hit pretty gard but luckily no real damage to the place I'm staying at. Which I won't be here for long. Having a bad experience with this property and things failing every week. I like to describe it as a shit hole with fresh paint. It's seriously a comedy of errors in how they decided to "fix" and "renovate" this place. Don't get me started lol
  21. May 29, 2024 at 8:56 AM
    #441
    M3Tundra-JK
    Scott
    2005 GX470
    I did get some work done the other weekend. Got some of the damage pulled out. I need to remove more metal before continuing though. I may even get a mobile body guy to come assist with this core part.
  22. May 29, 2024 at 9:13 AM
    #442
    Slag_Dynamics
    Arizona
    Gone
    Does that little clamp I recommended work well?
  23. May 29, 2024 at 9:17 AM
    #443
    M3Tundra-JK
    Scott
    2005 GX470
    It works really well so long as the metal it's clamping to is straight. I need to pull against the curved part also but can't. The 2k lbs winch puller I got is barely adequate though.
    But I think the main issue is the technician lol.
    Also I need to work the metal in other ways before it'll true out enough to spot weld the new corner support piece to it.
  24. May 29, 2024 at 9:19 AM
    #444
    Slag_Dynamics
    Arizona
    Gone
    I wonder, if the metal you’re trying to pull is NOT straight, if you could tack weld a straight piece of scrap to the curved portion for the tool to clamp to.
    I’ve only used the tool myself a few times, but I do think they’re cool! Lol
  25. May 30, 2024 at 7:43 PM
    #445
    e30cabrio
    Sorry the place is no good. Glad you didn't get flooded.
    Fobroader and M3Tundra-JK[OP] like this.
  26. May 30, 2024 at 8:35 PM
    #446
    Black@Blue19
    Ken
    SE Texas
    Slowly but surely!!:) WOW! You are gettin er!!
    I would never tackle a job like that. It is neat to see how you are doing things!:)
    I’d pull on a piece and ruin another trying to straighten it.
    Thanks for posting the repair journey.
  27. Jun 2, 2024 at 4:18 PM
    #447
    M3Tundra-JK
    Scott
    2005 GX470
    I posted on Reddit, but looking for mobile body shop recommendations to help me finish part this out.
    The stupid jeep has a Cylinder 5 misfire that I'm trying to chase down. Between that and the intermittent "small evap leak" I can't get the jeep inspected.
    And here's why that matters...TX is dumb! In order to get my license transfered from CO to TX, I first have to have a vehicle registered in TX...And in order to register, I have to pass the emissions test. Which can't be done with a check engine light on. That seems so backwards to me. LIke why do I have to have a vehicle first before you'll transfer my License?? lol. And my M3 is still in CO. I've got about a month left, if I don't get it transfered before then, I have to go through the whole process of getting a drivers license in TX from scratch...end rant for that...
    I've also given 60 days notice to move out of this leaky mold ridden townhouse. So that's a whole other issue I'm dealing with atm too. Won't even go into the details on that rabbit hole.
  28. Jun 2, 2024 at 8:35 PM
    #448
    e30cabrio
    Wow, that's alot of suck.
    Sorry.
    M3Tundra-JK[OP] and Sean492 like this.
  29. Jun 5, 2024 at 3:22 PM
    #449
    M3Tundra-JK
    Scott
    2005 GX470
    Found the source of the jeeps misfire...
  30. Jun 5, 2024 at 3:26 PM
    #450
    Well that was easy
    The Dude likes this.
