Bumpstop question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nygmen124, May 1, 2024.
  1. May 1, 2024 at 11:42 AM
    Nygmen124
    Nygmen124 [OP] New Member
    Jesus
    KY
    2014 Silver Lifted Crewmax
    6 in lift kit on a 2wd. Done by previous owner. Don't blame me.
    I have the Rough Country 6in lift. Do I need to add extenders to the front bumpstops and add taller bumpstops in the back?20240501_143736.jpg 20240501_143655.jpg
  2. May 1, 2024 at 11:58 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I absolutely would. It will save your components if you hit a bad bump or pothole. I am not sure what you want to use at that height, but I am running a 2-2.5 inch lift and went with the durobumps and it makes a huge difference offroading.
    RobertD likes this.
  3. May 1, 2024 at 12:10 PM
    RobertD
    Robert
    DFW, Texas
  4. May 1, 2024 at 12:23 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Front you currently dont have bumpstops yes get the extenders. Rear is fine the block is under them
    _none_ likes this.
