Oil Catch Can?
Discussion in '3rd Gen Tundras (2022+)' started by Spectre, Mar 11, 2022.
  1. Mar 11, 2022 at 9:05 AM
    Spectre
    Spectre [OP] New Member
    Huntsville, AL
    2022 Tundra TRD Sport 4x4
    Just got my 2022 Tundra about a week ago and so far I’m loving it. I’ve been lurking on the threads reading potential first year issues I may have. I was wondering what your opinions were regarding oil catch cans for the turbo engine? I seen Ford Ecoboost owners install catch cans and wondered if there would be a benefit to adding it later. This is the first boosted engine I’ve had so I’m trying to learn the ins and outs. I’ve loved this forum over the years and thanks for any input. C9C31F1C-E240-401D-BBAB-28179742E4EB.jpg
    Tundrastruck91 and Leo's first like this.
  2. Mar 11, 2022 at 9:22 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    My advice would be check your intercooler and throttle body for blow-by BEFORE buying parts to modify your PCV. Learn from my experience and avoid trying to fix a problem that you may not actually have.
    pwpblue likes this.
  3. Mar 11, 2022 at 9:25 AM
    Rwaters
    Rwaters New Member
    2022 Tundra TRD SR5 Crewmax
    Catch cans are good for direct injection and boosted vehicles. If it’s a daily driver (which most are) then regular maintenance will actually suffice. They are best for preventing air from mixing with the oil. It also helps prevent blow by from any extra gases and of course it filters some of the extra trash as well. Basically if you can justify the extra cost, some are really expensive, then go for it. I do regular maintenance and it’s a street queen that doesn’t work hard. So it’s not on my top priority list right now.
  4. Mar 11, 2022 at 9:38 AM
    I would really consider it. Since your motor is DI & Port Injection it only makes sense.
    @shawn.roe24, care to show your catch can pics?
    My Duramax boost tubes were coated nicely with oil. After tearing my truck apart I seen the need for either a catch can or re-routing to atmosphere.
    mayan and Lake.Life24 like this.
  5. Mar 11, 2022 at 12:09 PM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    This was after 650miles of no towing.
    I absolutely think they are worth the $200 bucks.
    8421F9C2-D713-4C09-AD0C-B5E3515A54BF.jpg 301D468E-7C9E-434C-A810-98E7B5E0DABB.jpg
    mayan and Hbjeff like this.
  6. Mar 11, 2022 at 12:18 PM
    BecauseRacecar
    Ohio
    Is this from a Tundra?
    Lake.Life24[QUOTED] likes this.
  7. Mar 11, 2022 at 12:31 PM
    Lake.Life24
    Shawn
    Upstate, NY
    That is from a GMC sierra 3500. The new gas 6.6L. It is Direct Injection so I went ahead with a PCV reroute to catch can. If the engine has direct injection I would do two things.
    1. I would use high quality oils with dispersants and detergents to help keep things clean. I settled on Amsoil
    2. I would install a catch can to remove soot and water that the engine oil can't clean
    This will help keep the re-used gases more pure for re-burning. I think the new tundra has both port and direct. So I think a catch can is work it.
    And sorry I just read the thread. I was tagged for pictures so that's what I provided :rofl:I see you have a different story. Do you think PCV reroute isn't necessary or other things should be addressed first?
    BecauseRacecar likes this.
  8. Mar 11, 2022 at 12:44 PM
    Rwaters
    Rwaters New Member
    Definitely worth it for your setup
    Tundrastruck91 likes this.
  9. Mar 11, 2022 at 1:06 PM
    Lake.Life24
    Shawn
    Upstate, NY
    For sure! Mine engine is only direct injection. I will be honest I know very little about the new engine in the tundra. If there was ever a manufacturer you could trust it would be Toyota. Sometimes for cost reasons manufacturers put in really good parts/designs, but the buyer has to add somethings to make it the best. Auxiallary Transmission cooler is a perfect example
  10. Mar 11, 2022 at 2:43 PM
    Rwaters
    Rwaters New Member
    I agree 100%
  11. Mar 12, 2022 at 6:53 PM
    Osiris
    Osiris New Member
    20 Plat
    It includes one from the factory already.
  12. Mar 13, 2022 at 11:59 AM
    Spectre
    Huntsville, AL
    Thank you all for the insight. I plan on changing the oil and filter at 1000 miles and then at every 5000 intervals to keep things clean; not every 10,000 like the manual recommends. I may add a catch can later. Only time will tell.
  13. Mar 13, 2022 at 12:03 PM
    Spectre
    Huntsville, AL
    That’s interesting. I’ll have to try to find where that is. Will you elaborate?
  14. Mar 13, 2022 at 12:21 PM
    It’s call the “intake” tubes. :thumbsup:
    ziznack likes this.
  15. Mar 13, 2022 at 12:49 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    That's great to hear that the 3.5 TT is dual port, smart move on their part. Carbons a huge issue on DI and the MPI helps out a lot on that front.
  16. Mar 14, 2022 at 4:16 PM
    Osiris
    Osiris New Member
    20 Plat
    Tundra has DI & Port injection, meaning there is no use for a separate oil catch can because the gasoline sprays over the intake valves preventing them from carbon'ing up. The PCV blows any vapor with debris back over the intake tubes to be cleaned by port injectors.
    14burrito likes this.
  17. Mar 14, 2022 at 5:07 PM
    Spectre
    Huntsville, AL
    Thanks for that explanation. That’s good to know and makes me lean towards not needing a catch can.
  18. Mar 14, 2022 at 6:04 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Very glad they went this route.
    Does the LS500 3.5TT also use DI and MPI? Curious if they decided to add MPI after seeing carbon coking issues on the earlier 3.5.
  19. Apr 30, 2024 at 6:04 AM
    Firstlast
    Firstlast New Member
    Dual injection as well on the LS 500. Drove mine until 70k miles with no issues.
  20. Apr 30, 2024 at 4:04 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Cash can period!$$$$
    Moisture,blow-by,vapors are re-introduced to the intake and gets burned up in the normal combustion cycle vs being vented to the atmosphere! That cash can is naturally colder than anything coming out of the pvc system so it tends to condensate thus you being fooled.
    And do you take the contents in that little can to a recycling center???
    That's what I thought!
    ziznack likes this.
  21. Apr 30, 2024 at 5:03 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I have a BMS can I never installed. Wouldn't mind parting ways with it if anyone is interested
