Help! Turn signal, hazard lights not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Biedmc06, Apr 27, 2024.
  1. Apr 27, 2024 at 9:01 PM
    Biedmc06
    Biedmc06 [OP] New Member
    I have a 2018 Tundra SR5. The turn signals and flashers do not work. I’m guessing it’s a blown fuse? I can seem to locate what fuse(s) it would be. The 2018 doesn’t have a fuses labeled “HAZ” or “TURN-HAZ”.
    thank you for help!
  2. Apr 28, 2024 at 7:40 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    I have a 2018 as well and I don't see any fuse in the box under the hood that might be for hazard or turn signal lights either. The fuse(s) for these may be in the small fuse box under the left lower driver side panel, but not sure. Others here with more electrical knowledge may be able to help. Good luck, and let us know what you find out.
  3. Apr 28, 2024 at 7:46 AM
    RobertD
    Robert
    DFW, Texas
    Both the turn and the hazard are part of the driver footwell fuse box. Trying to find a useful post to help you locate it.
    Basically lay down with your head by the pedals and look up. If seated in driver seat (like normal driving position) you can feel it with your left hand if you reach under the dash and feel around. I know, shit descriptions but you should be able to see it.
    Edit: found the thread
    https://www.tundras.com/threads/interior-fuse-box-location-and-information.3720/
  4. Apr 29, 2024 at 12:21 PM
    Biedmc06
    Checked all the fuses and still nothing.
  5. Apr 29, 2024 at 12:52 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Here is your wiring diagram and associated fuses.
    Did you recently upgrade any of the bulbs to LEDs?
  6. Apr 29, 2024 at 8:31 PM
    Biedmc06
    I obviously am no expert. I checked every single fuse.. nothing. I tried changing out all the bulbs (regular, not LED), nothing.
    Open to other ideas but running out of hope.
    Starting to think I might have to make a deal with the devil. Schedule a service with the dealership
  7. May 17, 2024 at 6:40 PM
    Biedmc06
    Update: gauge cluster was believed to be In need of replacement. Prior to replacement who was discovered that a Connector was loose on the gauge cluster. Technician plugged it in and everything returned to normal
    Jsums likes this.
